VIXIA HF R72
- 57x (32.5–1853mm) Advanced Zoom and SuperRange Optical Image Stabilizer helps provide outstanding, steady video.
- Canon 3.28 Megapixel Full HD CMOS Image Sensor.
- DIGIC DV 4 Image Processor captures video at 1920 x 1080 resolution and helps provide outstanding imaging performance.
- Record up to 12 hours of video to a 32GB internal flash drive or directly to a removable SD memory card.
- 1080/60p recording in MP4 (35 Mbps) and AVCHD Progressive (28 Mbps) helps ensure high-quality capture of moving subjects.
- Built-in Wi-Fi® and NFC allows for easy sharing and transferring of images and videos.
Terms
Service
Eligible Products
Offers, Orders and Returns
Enrollment
Payment and Cancellation
Changes to Terms
Return Policy
The Canon Online Store will accept, for return or exchange, defective or unopened merchandise purchased at the Canon Online Store, subject to the exceptions and timeframe for returns listed below: All merchandise returned to the Canon Online Store must be in the original packaging with all original items (such as manuals, cables, etc.) accompanying the merchandise and a copy of the invoice/packing slip included to be eligible for return or exchange. Shipping and handling fees from your original order will not be refunded, unless the merchandise is determined by the Canon Online Store, in its sole discretion, to be defective.
See Return Policy for complete information.
Overview
The VIXIA HF R72 camcorder makes it easy to capture high-quality, creative Full HD video with amazing zoom power for up to 12 hours! Record subjects near and far with a remarkable 57x Advanced Zoom that lets you capture the shot you want without interrupting the scene, and a SuperRange Optical Image Stabilizer that helps keep your video smooth, clear and steady even if you shoot while walking. You can record to the 32GB internal flash drive or directly to a removable SD memory card for flexibility and convenience. Zoom Framing Assist keeps it simple by helping to prevent you from losing a distant subject while shooting, and now features both Auto and Manual modes for expanded versatility. Newly added features include a Highlight Priority mode which helps recreate the rich range of color seen by the naked eye, as well as a redesigned LCD screen that stays bright and clear even outdoors. What's more, it also has a new user interface with a layout that makes shooting, navigating menus and viewing your video simple and fun, right from the start. Ideal for families to take on trips, sports games, school performances and more, the VIXIA HF R72 can help you record fantastic videos you'll treasure for years.
View Full Technical Specs PDF
Main Unit Specs
Photo: Approx. 2.07 Megapixels (1920 x 1080)
LP (1440 x 1080)**: 12 hrs. 15 min.
FXP (1920 x 1080)**: 4 hrs. 10 min.
MXP (1920 x 1080)**: 2 hrs. 55 min.
NTSC 60p (1920 x 1080)**: 2 hrs. 30 min. 32GB Internal Flash Drive in MP4*:
4 Mbps (1280 x 720)**: 17 hrs. 20 min.
17 Mbps (1920 x 1080)**: 4 hrs. 10 min.
24 Mbps (1920 x 1080)**: 2 hrs. 55 min.
35 Mbps (1920 x 1080)**: 2 hrs. * Variable bit rate.
** When recording has continued for 12 hours, it will automatically stop and then start.
Focal Length: 2.8 - 89.6mm
35mm Film Equivalent:
Optical Zoom: Approx. 38.5 - 1232mm
Advanced Zoom Off: Approx. 38.5 - 1232mm
Advanced Zoom On: Approx. 32.5 - 1853mm
Zoom Speed: Variable / 3 Fixed Zoom Speeds
Max. F/Stop: f/1.8 - 4.5
*1 Portrait, Sports, Snow, Beach, Sunset, Night, Low Light, Spotlight, Fireworks
*2 Cinema Standard, Vivid, Cool, Sepia, Old Movies
Still Image: 1/500 sec.
All other modes: 10mm (WIDE end), 1m across entire zooming range (from edge of lens). However, approx. 50cm at tele macro setting established at this time (automatic movement to TELE end)
MP4: 60P/30P/24P
Low Light mode: Approx. 0.4 lux
Intelligent IS in Auto/Baby mode Dynamic IS (default) Powered IS Macro IS Tripod Mode IS Modes other than Intelligent IS; Dynamic IS and Powered IS settings can be made manually in P/High-brightness priority/SCN*1/ Cinema Mode: Standard IS IS Off Angular velocity detection (using piezoelectric vibration sensor) and hybrid by sensor based movement vector detection supported. *1 Portrait, Sports, Snow, Beach, Sunset, Night, Low Light, Spotlight, Fireworks
MP4: MPEG-4 AAC-LC (2ch)
Sampling Frequency: 48 KHz
32° to 104°F (0° to 40°C) 85% relative humidity (performance)
Approx. 10.9 oz. / 310g (Including Battery BP-727, memory card, grip belt)
1
Reviews
