VIXIA HF R80 Refurbished
HFR80RFD
As low as $0.00
Out Of Stock
  • 57x (32.5-1853mm) Advanced Zoom and Super Range OIS.
  • SuperRange Optical Image Stabilization
  • Canon 3.28 Megapixel Full HD CMOS Image Sensor
  • DIGIC DV 4 Image Processor
Return Policy
VIXIA HF R80 Refurbished Compatible Products
Batteries & Grips
Batteries & Grips
Batteries & Grips
Product Disclaimer
* * Saving a still image from a single movie frame does not result in the same image quality as a normal still image.
** Continuous shooting speed may vary depending on the shutter speed, the aperture, the lens being used, the battery charge and various camera settings.
*** When lens diaphragm setting is fully open, adjustment volume and compensation effect are emphasized. Sufficient adjustment volume and compensation effect may not be achieved, depending on lens in use and shooting conditions. Adjustment volume and compensation effect vary depending on camera position (landscape or portrait).
^ Compatible with iOS® versions 8.0/8.1/8.2/8.3/8.4/9.0/9.1/9.2/9.3, Android™ smartphone and tablet versions 4.1/4.2/4.3/4.4/5.0/5.1/6.0. Data charges may apply with the download of the free Canon Camera Connect app. This app helps enable you to upload images to social media services. Please note that image files may contain personally identifiable information that may implicate privacy laws. Canon disclaims and has no responsibility for your use of such images. Canon does not obtain, collect or use such images or any information included in such images through this app.
^^ Compatible with Android™ smartphone and tablet versions 4.0/4.1/4.2/4.3/4.4/5.0/5.1/6.0.
^^^ In certain countries and regions, the use of GPS may be restricted. Therefore be sure to use GPS in accordance with the laws and regulations of your country or region. Be particularly careful when traveling outside your home country. As a signal is received from GPS satellites, take sufficient measures when using in locations where the use of electronics is regulated.
