VIXIA HF W10
- Full HD 1920x1080
- Dustproof
- Long Life
- 1.5m / 4.9ft Shockproof
- -10 degrees celsius / 14 degrees fahrenheit - Freezeproof
- 5m / 16.4ft Waterproof
Terms
Service
Eligible Products
Offers, Orders and Returns
Enrollment
Payment and Cancellation
Changes to Terms
Return Policy
The Canon Online Store will accept, for return or exchange, defective or unopened merchandise purchased at the Canon Online Store, subject to the exceptions and timeframe for returns listed below: All merchandise returned to the Canon Online Store must be in the original packaging with all original items (such as manuals, cables, etc.) accompanying the merchandise and a copy of the invoice/packing slip included to be eligible for return or exchange. Shipping and handling fees from your original order will not be refunded, unless the merchandise is determined by the Canon Online Store, in its sole discretion, to be defective.
See Return Policy for complete information.
Overview
The robust, lightweight VIXIA HF W10 camcorder is the ideal companion for capturing everything you do as a family, anywhere you go. With a design that's waterproof up to 16.4 feet and shockproof up to 4.9 feet, it records your most action-packed moments with stunning video quality. Whether you're recording your family and friends catching stellar waves at the beach or skiing down snowy slopes, you can be sure that the VIXIA HF W10 will keep up with you in virtually any environment. Not only does it withstand just about everything, it also has an approx. 4.5-hour rechargeable battery so you can record vacations, day trips and more all day long.
A flexible 40x Optical and 60x Dynamic Zoom and clever image stabilization feature let you stay up close and moving with the action for clear, steady results. What's more, an autofocus function with Face Tracking helps ensure that no moment gets lost to blurriness. Start recording all your adventures and create lasting video memories with the VIXIA HF W10 camcorder.
View Full Technical Specs PDF
Main Unit Specs
Photo: Approx. 2.29 Megapixels (1920x1080)
• 4.8 Mbps (1920x1080)**: 1 hr. 20 min.
• 17 Mbps (1920x1080)**: 20 min.
• 24 Mbps (1920x1080)**: 15 min.
* Variable bit rate.
** When recording has continued for approximately 12 hours, it will automatically stop.
* When Image Stabilization set to OFF.
Focal Length: 2.9–116.0mm
35mm Film Equivalent:
• Video: Approx. 40.5–1620mm (image stabilizer: Off)
• Photo: 40.5–1620mm (16:9), 49.5–1980mm (4:3)
Max. F/Stop: f/1.8–6.3
Still Image: 1/500 sec.
- OFF: Deactivates image stabilizer.
- ON: Reduces camera shake under normal shooting conditions.
- ON (AIS): Reduces camera shake more effectively when shooting bright scenes on the wide-angle end. Only on the wide-angle end (approx. 5x).
- Enhanced AIS: The area of correction in the enhanced AIS-mode is greater than that in the AIS mode. Camera shake can be reduced more effectively even when recording is performed by zooming from wide-angle to telephoto.
* When a lens filter or conversion lens is attached, vignetting may occur
Impedance: 75 Ω
Signal level: 1.0 V (p-p)
Impedance: 1 kΩ
Frequency characteristic: 48kHz, 256 kbps
-4-122°F (-20-50°C) 35-80% relative humidity (storage)
50-95°F (10-35°C) 35-80% relative humidity (charging)
Continuous Recording Time (Maximum Recording Time): Approx. 4 hrs. 20 min.
Reviews
