VIXIA HF W11
- -10 degrees celsius / 14 degrees fahrenheit - Freezeproof
- 1.5m / 4.9ft Shockproof
- 5m / 16.4ft Waterproof
- Dustproof
- Full HD 1920x1080
- Long Life
Terms
Service
Eligible Products
Offers, Orders and Returns
Enrollment
Payment and Cancellation
Changes to Terms
Return Policy
The Canon Online Store will accept, for return or exchange, defective or unopened merchandise purchased at the Canon Online Store, subject to the exceptions and timeframe for returns listed below: All merchandise returned to the Canon Online Store must be in the original packaging with all original items (such as manuals, cables, etc.) accompanying the merchandise and a copy of the invoice/packing slip included to be eligible for return or exchange. Shipping and handling fees from your original order will not be refunded, unless the merchandise is determined by the Canon Online Store, in its sole discretion, to be defective.
See Return Policy for complete information.
Overview
Durable, reliable and as ready for every adventure as you are. Featuring a design that's waterproof up to 16.4 feet and shockproof up to 4.9 feet, the rugged VIXIA HF W11 camcorder is up to the challenge to record vivid, eye-catching video, anytime and virtually anywhere. Capture your family heading down the rapids during a whitewater rafting trip or friends performing their best balancing act while waterskiing, or simply cherish the view at the beach. The powerful 40x Optical and 60x Dynamic Zoom gives you great perspective both up close and from a distance. Plus, the shockproof design gives you the peace of mind that you'll be able to look back at these moments, forever.
The VIXIA HF W11 has a built-in LED light that automatically turns on in the dark, so even nighttime campfire stories can be remembered. With these impressive features, plus an approx. 4.5-hour rechargeable battery, 32GB of internal memory and an SD card slot for additional storage, you can feel empowered and confident that the VIXIA HF W11 will capture the journey.
View Full Technical Specs PDF
Main Unit Specs
Photo: Approx. 2.29 Megapixels (1920x1080)
4.8 Mbps (1920x1080)**: 13 hrs. 30 min.
17 Mbps (1920x1080)**: 3 hrs. 40 min.
24 Mbps (1920x1080)**: 2 hrs. 40 min.
28 Mbps (1920x1080)**: 2 hrs. 20 min.
* Variable bit rate.
** When recording has continued for approximately 12 hours, it will automatically stop.
* When Image Stabilization set to OFF.
Focal Length: 2.9–116.0mm
35mm Film Equivalent:
• Video: Approx. 40.5–1620mm (image stabilizer: Off)
• Photo: 40.5–1620mm (16:9), 49.5–1980mm (4:3)
Max. F/Stop: f/1.8–6.3
- OFF: Deactivates image stabilizer.
- ON: Reduces camera shake under normal shooting conditions.
- ON (AIS): Reduces camera shake more effectively when shooting bright scenes on the wide-angle end. Only on the wide-angle end (approx. 5x).
- Enhanced AIS: The area of correction in the enhanced AIS-mode is greater than that in the AIS mode. Camera shake can be reduced more effectively even when recording is performed by zooming from wide-angle to telephoto.
Signal level: 1.0 V (p-p)
Impedance: 1 kΩ
Frequency characteristic: 48kHz, 256 kbps
-4-122°F (-20-50°C) 35-80% relative humidity (storage)
50-95°F (10-35°C) 35-80% relative humidity (charging)
Continuous Recording Time (Maximum Recording Time): Approx. 4 hrs. 20 min.
Reviews
