Filter & Sort
Download Type
<p><span class="h2"><b><span class="h6">Find Software & Drivers</span></b></span></p> <p>Software & drivers are specific to your operating system. Not all software &amp; drivers are compatible with operating systems and versions.</p>
0 of 0
Date 11.24.23
File Size 37.30 MB
Date 11.24.23
File Size 66.22 MB
Date 07.10.18
File Size 96.0 MB
Date 07.10.18
File Size 104.0 MB
Product
Product Category EFP Lens
Product Series CJ45ex13.6B
Image Composition
Object Image Format 2/3 inch
Aspect Ratio 16:9
Zoom Ratio 45x
Focal Length Range 13.6 , 612mm
Focal Length Range with 2x Extender 27.2 , 1224mm
Angular Field of View 38.9&deg; x 22.5&deg; at 13.6mm
0.90&deg; x 0.51&deg; at 612mm
Angular Field of View with 2x Extender 20.0&deg; x 11.3&deg; at 27.2mm
0.45&deg; x 0.25&deg; at 1224mm
Optical Brightness
Maximum Relative Aperture (F-Number) 1:2.8 at 13.6 , 312mm
1:5.5 at 612mm
Maximum Relative Aperture (F-Number) with 2x Extender 1:5.6 at 27.2 , 624mm
1:11.0 at 1224mm
Scene Composition
MOD From Front of Lens 2.8m (10mm with macro)
Scene Object Dimensions at MOD 182.9 x 102.9cm at 13.6mm
4.2 x 2.4cm at 612mm
Scene Object Dimensions at MOD with 2x Extender 91.5 x 51.5cm at 27.2mm
2.1 x 1.2cm at 1224mm
Physical Attributes
Width 6.8in (173.2mm)
Height 5.8in (147.5mm)
Length 14.0in (355.0mm)
Weight 12.4lbs (5.64kg)
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
