Canon Support for CX-G6400 Card & Badge Printer | Canon U.S.A., Inc.
Language
Type
Our software & drivers for your product are specific to your operations system. We've detected your operating system as {{os}}. If you need software or drivers for a different operating system make sure to select the correct operating system & version with the dropdowns below. Not all our software & drivers are compatible with all operating systems and versions.
of
There are no results for the OS Version you selected.
Date 12.16.21
File Size 5.24 MB
Date 12.17.21
File Size 3.81 MB
Date 06.25.19
File Size 4.99 MB
Printer
Printing Method Dye-based Inkjet
Print Mode Single Sided (Simplex)
Print Speed (up to) First Print Out Time: Business Card: 12 seconds or less1
Business Card: 100 Cards/minute (6,000 Cards Per Hour (CPH)) 1
Plastic Card (CR80): 45 Cards/minute (2,700 Cards Per Hour (CPH)) 1
4"x6" Postcard: 45 Cards/minute (2,700 Cards Per Hour (CPH)) 1
Envelope: 28 Envelopes/minute
Number of Nozzles 5,185 dots
Print Resolution (Up to) 1200x1200 dpi
Ink Compatibility 4 (1 x Black, 1 x Cyan, 1 x Magenta, 1 x Yellow)
Maximum Printable Area Width: 107.8 mm / 4.2"
Length: 297.0 mm / 11.7"
Minimum Margin Top/Bottom: 1.5 mm
Left/Right: 2.0 mm
Paper Thickness Paper/Plastic: 0.21 - 0.76 mm / 8.27 - 30 mil
Envelope: 0.24 - 0.48 mm / 9.45 - 18.9 mil
Automatic Sheet Feeder Paper feed capacity2
Plastic & Paper Card: 400 Cards
Envelope: 100 Envelopes
Paper Compatibility Paper Card: Business Cards, Credential, Envelope, Postcard
Plastic Card: 2" x 3.5" PVC (CR80, CR100)
Custom Size: Paper/Plastic within Maximum Printable Size & Up to 30 mil"
Body Durability 1.5 Million Sheets / 5 Years
Estimated Output Number Approx. 24,000 Sheets per cartridge set2
Maximum Paper Size Width: 85.0 - 120.0 mm / 3.3 - 4.7"
Length: 49.0 - 300 mm / 1.9 - 11.8"
General
OS Compatibility Windows 10 (64/32 bit), 8.1 (64/32 bit), 7 SP1 (64/32 bit)3
Standard Interface USB 2.0
Ethernet (10/100/1000Base-T)
Power Source AC 100v - 240v, 50/60 Hz
Power Consumption (approx.) Maximum: Approx. 229 W
Operating: Approx. 135 W
Sleep Mode: Approx. 8.5 W or Less
Dimension (W x D x H) 23.4" (W) x 16.1" (D) x 18.3" (H)6
Weight 55.1lbs.6
Operating Temperature: Temperature: 41° - 95°F (5° - 35°C)
Operating Humidity: Humidity: 10-90% RH (Non-Condensing)
Noise Acoustic Information4:
Operating Noise (Max.): 58dB or less
Standby Noise: 35dB or less
Cartridge Fill Volume Black / Cyan / Magenta / Yellow: 105 ml
Maintenance Cartridge Info & Fill Volume WT-X401 Maintenance Cartridge 1
Approx. 72,000 Sheets1
Operational Method LCD: No
Buttons/LEDs: 3 Buttons / 8 LEDs
Warranty 2 Year Warranty5
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
