Canon Support for EOS R5 + RF24-105mm F4 L IS USM Kit | Canon U.S.A., Inc.
Filter & Sort
Download Type
<p><b>Find Software &amp; Drivers</b></p> <p>Software &amp; drivers are specific to your operating system. Not all software &amp; drivers are compatible with operating systems and versions.</p>
0 of 0
Results will appear after selecting an Operating System and Version above
Date 06.13.24
File Size 142.00 B
Date 07.08.21
File Size 6.16 MB
Date 08.21.24
File Size 142.00 B
Date 08.21.24
File Size 142.00 B
Date 08.21.24
File Size 142.00 B
Date 06.13.24
File Size 142.00 B
Date 11.01.22
File Size 145.00 B
Date 06.13.24
File Size 142.00 B
Type
Digital single-lens non-reflex AF/AE camera
Recording Media
CFexpress card
  • Type B: Card slot
  • SD card speed class-compatible
SD card
  • Compatible with UHS-II
  • Eye-Fi cards and Multimedia cards (MMC) are not supported.
Compatible Lenses
Canon RF lens group (excluding EF, EF-S and EF-M lenses)
When using Mount Adapter EF-EOS R: Canon EF or EF-S lenses (excluding EF-M lenses)
Lens Mount
Canon RF mount
Type
CMOS sensor (compatible with Dual Pixel CMOS AF)
Effective pixels
Approx. 45.0 megapixels
Pixel Unit
Approx. 4.40 µm square
Total Pixels
Approx. 47.1 megapixels
Aspect Ratio
3:2 (Horizontal:Vertical)
Color Filter System
RGB primary color filters
Low Pass Filter
Installed in front of the image sensor, non-detachable
Dust Deletion Feature
  1. Self Cleaning Sensor Unit
    • Removes dust adhering to the low-pass filter.
    • At power off only / Enable / Disable. Performed automatically (taking about approx. 2 sec. as indi-cated on the screen) or manually (taking about approx. 8 sec. as indicated on the screen).
    • After manually activated cleaning, the camera will automatically restart (Power OFF to ON).
    • When [Multi Shot Noise Reduction], [Multiple exposures], or [HDR mode] is set, [Clean now] and [Clean manually] cannot be selected.
  2. Dust Delete Data acquisition and appending
    • The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images.
    • The dust coordinate data appended to the image is used by the EOS Canon Digital Professional Software (v. 4.14 and higher) to automatically erase the dust spots.
    • Not available with EF-S lenses, in cropped shooting or multi-exposure shooting.
  3. Manual cleaning (by hand)
Recording Format
Compliant to Design rule for Camera File system 2.0 and Exif 2.3*.
*Supports time difference information in Exif 2.31.
File Size
3:2 Aspect Ratio
Large/RAW/C-RAW: 8192 x 5464
Medium: 5808 x 3872
Small 1: 4176 x 2784
Small 1: 2976 x 1984
Small 2: 2400 x 1600
1.6x (Crop)*
Large/RAW/C-RAW: 5088 x 3392
4:3 Aspect Ratio
Large: 7280 x 5464
Medium: 5152 x 3872
Small 1: 3712 x 2784
Small 2: 2112 x 1600
16:9 Aspect Ratio
Large: 8192 x 4608
Medium: 5808 x 3264
Small 1: 4176 x 2344
Small 2: 2400 x 1344
1:1 Aspect Ratio
Large: 5456 x 5456
Medium: 3872 x 3872
Small 1: 2784 x 2784
Small 2: 1600 x 1600
  • Values for Recording Pixels are rounded to the nearest 100,000 or 10,000.
  • For RAW and JPEG images, information outside the cropping area is not retained.
  • JPEG images are generated in the set aspect ratio.
  • RAW images are generated in [3:2], and the set aspect ratio is appended.
* Indicate an inexact proportion.
File Numbering
The following file numbers can be set:
  1. File numbering methods
    • Continuous numbering
      • The numbering of captured images continues even after you replace the card.
    • Auto reset
      • When you replace the card, the numbering will be reset to start from 0001. If the new SD card already contains images, the numbering will continue from the last recorded image in the card.
  2. Manual reset
    • Resets the file number to 0001, and creates a new folder automatically.
*When manually resetting the file number, folders can also be renamed.
RAW + JPEG Simultaneous Recording / HEIF Simultaneous Recording
Simultaneous recording of any combination of RAW/C-RAW and JPEG/HEIF image-recording quality is supported.
Color Space
Selectable between sRGB and Adobe RGB
Picture Style
  1. Auto
  2. Standard
  3. Portrait
  4. Landscape
  5. Fine Detail
  6. Neutral
  7. Faithful
  8. Monochrome
  9. User Defined 1-3
    • In Scene Intelligent Auto, [Auto] will be set automatically.
    • [Standard] is the default setting for [User Def. 1-3].
Settings
  1. Auto
  2. Day Light
  3. Shade
  4. Cloudy*
  5. Tungsten light
  6. White fluorescent light
  7. Flash
  8. Custom (Custom WB)
  9. Color temperature
* Effective also in twilight and sunset.
Auto White Balance
Option between ambience priority and white priority settings.
Color Temperature Compensation
Blue/amber bias: ±9 levels
Magenta/green bias: ±9 levels
Corrected in reference to the current WB mode's color temperature.
Type
OLED color electronic viewfinder; approx. 5.76 million dots resolution
Coverage
Approx. 100% vertically and horizontally relative to the shooting image area (with image quality L, at approx. 23mm eyepoint).
Magnification / Angle of View
Approx. 0.76x / Approx. 35.5 degrees (with 50mm lens at infinity, -1 m-1)
Eye Point
Approx. 23mm (at -1 m-1 from the eyepiece lens end)
Viewfinder Information
  1. Maximum burst
  2. Possible shots/Sec. until self-timer shoots
  3. Focus Bracketing/ Multiple-exposure/HDR shooting/Multi Shot Noise Reduction/Bulb time/Interval timer
  4. Shooting mode
  5. AF method
  6. AF operation
  7. Image quality
  8. Card
  9. Drive mode
  10. Metering mode
  11. No. of remaining shots for focus bracketing, multiple exposures, or interval timer
  12. Electronic level
  13. Movie recording time available
  14. Battery level
  15. Image Stabilizer (IS mode)
  16. Histogram (Brightness/RGB)
  17. Quick Control button
  18. Anti-flicker shooting
  19. White balance/White balance correction
  20. Picture style
  21. Auto Lighting Optimizer
  22. Still photo cropping / Aspect ratio
  23. AF point (1-point AF)
  24. AEB/FEB
  25. View Assist
  26. HDR PQ
  27. Flash ready / FE lock / High-speed sync
  28. Electronic shutter
  29. Touch shutter / Create folder
  30. AE lock
  31. Shutter speed / Multi-function lock warning
  32. Aperture value
  33. Wi-Fi® function
  34. Wi-Fi® signal strength
  35. Bluetooth® function
  36. Exposure simulation
  37. Magnify button
  38. ISO speed
  39. Highlight tone priority
  40. Exposure compensation
  41. Exposure level indicator
Type
Dual Pixel CMOS AF
AF Working Range
EV -6 to 20 (f/1.2 lens*, center AF point, One-Shot AF, at 73°F/23°C, ISO 100, One-Shot AF)
* Except RF lenses with a Defocus Smoothing (DS) coating.
AF Methods
AF Method
Face+Tracking AF
Spot AF
1-point AF
Expand AF Area
(Above, below, left and right/Around)
Zone AF
Large Zone AF (Vertical/Horizontal)
Metering Modes
Real-time metering with image sensor (384 [24x16 zone metering])
  1. Evaluative metering (AF point-linked)
  2. Partial metering (approx. 6.1% of the area at the center of the screen)
  3. Spot metering (approx. 3.1% of the area at the center of the screen)
  4. Center-weighted average metering
Metering Range
EV -3 - 20 (at 73°F/23°C, ISO 100) (Still Photo Shooting)
Exposure Control Modes
  1. Scene Intelligent Auto
  2. Flexible-priority AE (Fv)
  3. Program AE (P)
  4. Shutter-priority AE (Safety shift possible) (Tv)
  5. Aperture-priority AE (Safety shift possible) (Av)
  6. Manual exposure (M)
  7. Bulb
  8. Custom shooting mode C1, C2, C3
ISO Speed Range
Available ISO speeds; user-set
Normal ISO 100-51200 (1/3- or 1-stop increments)
Expanded L: equivalent to ISO 50, H: 102400
  • For [Highlight tone priority], the minimum ISO speed limit will be ISO 200 to 51200.
  • Expanded ISO cannot be set for HDR mode or during HDR PQ shooting.
User-defined ISO range - still photo shooting
ISO Speed Range ISO Speed
Minimum L (50)51200 (in 1-stop increments)
Maximum ISO 100H (102400) (in 1-stop increments)
* Expanded ISO speeds are noted as being equivalent to these speeds.
User-defined Auto ISO range - still photo shooting
Auto Range ISO Speed
Minimum ISO 10025600 (in 1-stop increments)
Maximum ISO 20051200 (in 1-stop increments)
ISO Auto details in still photo shooting
Shooting Mode No Flash Using Flash
Auto ISO 100-12800 ISO 100-1600*3
P  ISO 100*1*2-51200*2  ISO 100*1*2-6400*24
TV
AV
M
B ISO 4003
*1 ISO 200 when [Highlight tone priority] is set to [Enable] or [Enhanced].
*2 Varies depending on [Maximum] and [Minimum] of [Auto range].
*3 If outside the setting range, changed to the value most close to ISO 400.
*4ISO 1600 when using a lens that is not compatible with "Variable control of maximum ISO Auto limit for E-TTL".
Exposure Compensation
Manual ±3 stops in 1/3- or 1/2-stop increments
AEB ±3 stops in 1/3- or 1/2-stop increments
AE Lock
  1. Auto AE lock
    • The metering mode for AE lock after focus can be customized.
  2. User-applied AE lock
    • In the Fv, P, Tv, Av and M modes, enabled with the AE lock button. (Press again to update.)
    • Enabled in all metering modes.
Type
Electronically controlled focal-plane shutter
  1. Electronic first curtain or mechanical shutter
  2. Electronic shutter*
*Cannot be used in conjunction with the following functions: flash photography, HDR shooting,multiple exposures, Multi Shot Noise Reduction, AEB, HDR PQ, anti-flicker shooting, Dual Pixel RAW shooting, Digital Lens Optimizer [High].
* A shutter release sound is not generated. However, note that the sounds other than the shutter release sound (aperture, focusing lens drive sound/electronic sound, etc.) may be generated.
* In electronic shutter shooting under conditions such as flash firing by other cameras or with fluores-cent lighting or other flickering light sources, a strip of light or banding due to the brightness difference may be recorded in the image.
Shutter Speeds
When [Mechanical] or [Elec. 1st- curtain] is set: 1/8000-30 sec, bulb
When [Electronic] is set: 1/8000-0.5 sec.
Shutter Release
Soft-touch electromagnetic release
Self Timer
10-sec. delay, 2-sec. delay
Shutter Lag Time
  Flash Mechanical Shutter Electronic 1st Curtain Electronic shutter
Shutter-release time lag *Measured with shutter button pressed fully from half-pressed position
Not used Approx. 81 ms Approx. 50 ms Approx. 50 ms
Used N/A N/A -
E-TTL balance
Ambience priority, standard, flash priority
Compatible E-TTL Speedlites
Canon EX- and EL-series Speedlites
E-TTL II Flash Metering
  1. Evaluative (Face Priority)
  2. Evaluative
  3. Average
Flash Exposure Compensation
FE Lock
Provided
External Flash Settings
The camera can set the following with EX series Speedlites:
  1. External flash control
    • Flash firing, E-TTL II Flash metering, Slow synchro, Safety FE, Flash mode, Wireless function, Flash zoom, Shutter synchronization and Flash exposure compensation
  2. Flash Custom Function setting
    • The setting options for both (1) and (2) will differ depending on the Speedlite used.
Shooting Times
Resolution and Frame Rate Mode Approx. shooting time (23°C / 73°F)*1 Recommended scene
8K 30p Full Sensor Width 20 min 8K productions where a full-frame mirrorless can be utilized to get unique angles alongside a main camera or additional cropping for 4K productions.
Full Sensor Width RAW 20 min As above but with the additional workflow flexibility of RAW.
4K 120p Full Sensor Width 15min*2 Shorter bursts of slow motion.
4K 60p Full Sensor Width 35min*3 High-frame rate high resolution productions and independent films.
APS-C Crop
(5.1K Oversampled)
25 min When additional reach is required with higher frame rates e.g. wildlife and sports and news gathering within a 4K production or even for tighter Full HD crops in post.
4K 30p Full Sensor Width Not limited by heat Interviews, longer duration capture such as weddings.
Full Sensor Width Hig Quality
(8.2K oversampling)
30 min When additional resolution is required with a 4K30p production or for a Full HD workflow where cropping can be desirable with high resolution.
APS-C Crop
(5.1K Oversampled)
Not limited by heat When additional reach is required e.g. wildlife and sports and news gathering within a 4K production or even for tighter Full HD crops in post.
*1 Time available for continuous shooting in 23°C / 73°F environment, from a cold start. If the camera is in LV mode standby before shooting or the ambient temperature is high, the shooting time may be shorter.
*2 Recording stops at 7minutes and 30seconds for high frame rate video. Indicates the time when recording can be resumed immediately.
*3 Recording is limited to 29 minutes 59 seconds. Indicates the time when recording can be resumed immediately.
Estimated Camera Recovery Time
Estimated recovery times are indicated below. These are affected by various factors such as ambient temperature, continued camera operation and the selected shooting resolution.The time until full record time is available will vary with ambient temperature.
Resolution and Frame Rate Waiting period (minutes)
(23°C / 73°F)*
Approximate maximum recording time after waiting period (minutes)
8K 30p 10 3
20  8
4K 60p 10 10
Focusing
Dual Pixel CMOS AF
Type
TFT color, liquid-crystal monitor
Monitor Size
3.2-inch (screen aspect ratio of 3:2)
3.15 in./8.01cm diagonal (2.63 in./6.67cm width, 1.75 in./4.44cm height)
Dots
Approx. 2.1 million dots
Coverage
Approx. 100% vertically/horizontally
Brightness Control
Manually adjustable to one of seven brightness levels
Coating
Clear View LCD II
  • Anti-smudge coating applied.
  • Anti-reflection coating not applied.
Interface Languages
29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, Japanese)
Display Format
Item Still Photo Movie
Magnify zoom display 1.5x-10x (5 levels)
AF point display Yes -
Grid display Off / 3×3 / 6×4 / 3×3+diag
Rating OFF / 1 to 5 Stars
Select images / Select range / All images in folder / All images on card /
All found images
Image Search Search conditions
Rating / Date / Folder / Protect / Type of file
Protect Select images / Select range / All images in folder / Unprotect all images in folder / All images on card /
Unprotect all images on card /All found images
In-camera RAW image processing Supported -
Resizing Supported -
Cropping Supported -
Highlight Alert
The white areas with no image data will blink.
Function
The Quick Control screen is accessed by pressing the Quick Control button during still photo shooting.
Protection
  1. Single image (select image)
  2. Select range
  3. All images in a folder
  4. All images on card
    • Image browsing and image search can be based on ratings.
    • Ratings-based image selections also possible with DPP.
  5. All found images (only during image search)
Erase
Except protected images
  1. Select images to erase
  2. Select range
  3. All images in folder
Compatible Printers
Not supported
DPOF
Compliant to DPOF Version 1.1
Custom Controls
Customizable Buttons
Shutter button
Movie button
MODE button
AF-ON button
AE lock button
AF point selection button
Depth of field preview button
Lens AF stop button
Multi-function button
LCD panel illumination button
Set button
Multi-controller
Customizable Dials
Main dial
Quick control dial 1 and 2
Control ring
My Menu Registration
  • Up to six top-tier menu items and Custom Functions can be registered.
  • Up to five My Menu tabs can be added.
My Menu tab overall operations
  • Adding a tab
  • Deleting tabs in a batch
  • Deleting all tab items
  • Setting the menu display
My Menu tab detailed operations
  • Selecting a registered item
  • Sorting registered items
  • Deleting selected registered items
  • Deleting registered items in a batch
  • Deleting tabs
  • Changing a tab name (16 ASCII characters)
USB Terminal
Equivalent to Hi-Speed USB (USB 3.1 Gen 2)
  • For PC communication
  • Terminal type: USB Type-C
  • Shared with terminal for in-camera charging with USB Power Adapter PD-E1.
  • In-camera Charging: Equivalent to USB type-C (5 V/1.5 A), but use should be restricted to USB Power Adapter PD-E1.
Video Out Terminal
HDMI micro OUT terminal Type D (Resolution switches automatically) / CEC not compatible
  • Images can be displayed through the HDMI output and on screen at the same time.
  • Images will not be displayed unless [NTSC] or [PAL] is properly set according to the video system of the TV set.
Microphone Input Terminal
3.5mm diameter stereo mini jack
Headphone Terminal
Battery
LP-E6NH/LP-E6N/LP-E6
  • With the AC Adapter AC-E6N + DC Coupler DR-E6, AC power is possible.
  • With the USB Power Adapter PD-E1, in-camera charging of LP-E6NH is possible. The USB Power Adapter PD-E1 is not compatible with powering the camera.
Battery Check
Automatic battery check when the power switch is turned ON.
Displayed in 6 levels on top LCD panel.
  • Battery level can be checked on the LCD panel and in the viewfinder.
    attery Info display in Set-up Menu:
  • Type of power source used.
  • Remaining capacity (percentage of battery charge remaining).
  • Recharge performance: (3-level display of battery's ability to hold a charge)
Start-up Time
Approx. 0.4 sec.
  • Based on CIPA testing standards.
Dimensions (W x H x D)
Approx. 5.45 x 3.84 x 3.46 in. / 138 x 97.5 x 88.0mm
  • Based on CIPA standards.
Weight
Approx. 1.63 lbs. / 738g (including battery, CFexpress card; without body cap)
Approx. 1.43 lbs. / 650g (body only; without battery, card or body cap)
Working Temperature Range
32-104° F / 0-+40°C
Working Humidity
85° or less
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
