Canon Support for EOS R50 Content Creator Kit | Canon U.S.A., Inc.
Filter & Sort
Download Type
<p><span class="h2"><b><span class="h6">Find Software & Drivers</span></b></span></p> <p>Software & drivers are specific to your operating system. Not all software &amp; drivers are compatible with operating systems and versions.</p>
0 of 0
image icon
Camera Connect
image icon
image icon
image.canon
Software Development Kit
Type Digital interchangeable lens, mirrorless camera
Image Processor DIGIC X
Recording Media (One) SD card slot
  • Compatible with UHS-I
  • Eye-Fi cards and Multimedia cards (MMC) are not supported.
Compatible Lenses Canon RF lens group (including RF-S lenses)
When using Mount Adapter EF-EOS R: Canon EF or EF-S lenses (excluding EF-M lenses)
Lens Mount Canon RF mount
Type APS-C CMOS sensor (compatible with Dual Pixel CMOS AF)
Effective pixels Approx. 24.2 megapixels
Screen Size Approx. 36.0 x 24.0 mm
Pixel Unit Approx. 3.72 µm square
Total Pixels Approx. 25.5 megapixels
Aspect Ratio 3:2 (Horizontal:Vertical)
Color Filter System RGB primary color filters
Low Pass Filter Installed in front of the image sensor, non-detachable
Dust Deletion Feature
Self Cleaning Sensor Unit not provided.
Manual cleaning (by hand) not supported.
  • Dust Delete Data acquisition and appending
    • The coordinates of the dust adhering to the low-pass filter are detected by a test shot and append-ed to subsequent images.
    • The dust coordinate data appended to the image is used by the EOS software to automatically erase the dust spots.
    • Not available during focus bracket shootin
Recording Format Compliant to Design rule for Camera File system 2.0 and Exif 2.31*. *Supports time offset information
Image Format JPEG (.JPG), HEIF (.HIF), RAW, C-RAW (.CR3)
Movies: ALL-I (Time-lapse video only), IPB (Light)
File Size Please click here for full specifications.
Maximum Burst Please click here for full specifications.
File Numbering The following file numbers can be set:
  1. File numbering methods
    • Continuous numbering
      • The numbering of captured images continues even after you replace the card.
    • Auto reset
      • When you replace the card, the numbering will be reset to start from 0001. If the new SD card already contains images, the numbering will continue from the last recorded image in the card.
  2. Manual reset
    • Resets the file number to 0001, and creates a new folder automatically.
      * When manually resetting the file number, folders can also be renamed.
RAW + JPEG / HEIF Simultaneous Recording Simultaneous recording of any combination of RAW/C-RAW and JPEG/HEIF image-recording quality is supported.
Color Space Selectable between sRGB and Adobe RGB
Picture Style
  1. Auto
  2. Standard
  3. Portrait
  4. Landscape
  5. Fine Detail
  6. Neutral
  7. Faithful
  8. Monochrome
  9. User Defined 1-3
    * Picture Style files can be registered to user-defined settings 1-3.
Settings
  1. Auto (Ambience priority/White priority)
  2. Day Light
  3. Shade
  4. Cloudy*1
  5. Tungsten light
  6. White fluorescent light
  7. Flash
  8. Custom (Custom WB)
  9. Color temperature*2
*1: Effective also in twilight and sunset.
*2: With an EX / EL-series Speedlite having the color temperature information transmission feature, the color temperature setting changes to match the color temperature when the flash is fired. Set to approx. 6000 K if the flash unit does not have the color tem-perature communication feature.
Auto White Balance Option between ambience priority and white priority settings, using SET button
White Balance Shift Blue/amber bias: ±9 levels
Magenta/green bias: ±9 levels
•Shifted from the color temperatue of the current WB mode.
•Blue/amber and magenta/green shift can be set at the same time.
WB Bracketing available, up to ±3 levels Blue/amber or magenta/green, via Quick Control Dial
Type OLED color electronic viewfinder; 0.39-inch, approx. 2.36 million dots
Coverage Approx. 100% (at JPEG Large image quality, 3:2 aspect ratio, approx. 22 mm eyepoint)
Magnification / Angle of View Approx. 0.96× / Approx. 28.0° (3:2 aspect ratio, with 50mm lens at infinity,1 m1)
Eye Point Approx. 22 mm (at 1 m1 from eyepiece lens end)
Dioptric Adjustment Range Approx. 3.0 to +1.0 m1 (dpt)
Viewfinder Information
  1. Maximum burst
  2. Possible shots/Sec. until self-timer shoots
  3. Focus Bracketing/ Multiple-exposure/HDR shooting/Multi Shot Noise Reduction/Bulb time/Interval timer
  4. Shooting mode
  5. AF method
  6. AF operation
  7. Image quality
  8. Card
  9. Drive mode
  10. Metering mode
  11. No. of remaining shots for focus braketing, multiple exposures, or interval timer
  12. Electronic level
  13. Movie recording time available
  14. Battery level
  15. Image Stabilizer (IS mode)
  16. Histogram (Brightness/RGB)
  17. Quick Control button
  18. Anti-flicker shooting
  19. White balance/White balance correction
  20. Picture style
  21. Auto Lighting Optimizer
  22. Still photo cropping / Aspect ratio
  23. AF point (1-point AF)
  24. AEB/FEB
  25. View Assist
  26. HDR PQ
  27. Flash ready / FE lock / High-speed sync
  28. Electronic shutter
  29. Touch shutter / Create folder
  30. AE lock
  31. Shutter speed / Multi-function lock warning
  32. Aperture value
  33. Wi-Fi® function
  34. Wi-Fi® signal strength
  35. Bluetooth® function
  36. Exposure simulation
  37. Magnify button
  38. ISO speed
  39. Highlight tone priority
  40. Exposure compensation
  41. Exposure level indicator
Focus Method Dual Pixel CMOS AF
Number of AF zones available for Automatic Selection AF area: Horizontal: Approx. 100% x Vertical: Approx. 100%
(100% x 100% AF coverage in Face Detect + Tracking AF; coverage can vary, depending upon lens being used)
Stills: Max. 651 zones (31 x 21)
Movies: Max. 527 zones (31 x17)
Selectable Positions for AF Point AF area: Horizontal: Approx. 90% x Vertical: Approx. 100%
Stills: Max. 4503 positions (79 x 57)
Movies: Max 3713 positions (79 x 47)
Focusing brightness range (still photo shooting) EV -4.0 to 20 (with an f/1.2 lens,* center AF point, One-Shot AF at room temperature, and ISO 100)
* Except RF lenses with a Defocus Smoothing (DS) coating.
Focusing brightness range (movie recording) EV -3.5 to 20 (with an f/1.2 lens,* center AF point, One-Shot AF at room temperature, ISO 100, and 29.97 / 25.00 fps.)*
Available AF Areas
  • Spot AF
  • 1-point AF
  • Expand AF area: Above/below/left/right
  • Expand AF area: Around
  • Flexible Zone AF 1
  • Flexible Zone AF 2
  • Flexible Zone AF 3
  • Whole area AF
Available Subject Detection
  • Auto
  • People
  • Animals (dogs / cats / birds)
  • Vehicles (motorsports cars or motorcycles)
    * Certain types of animals or vehicles may not be detected, depending on shape and appearance
Eye Detection Auto:
  1. Selects the eye closer to the camera (as detected from the angle of the face).
  2. At the same distance from the camera, selects the eye closer to the center of the image.
Left/right eye detection: Not supported
Metering Modes Real-time metering from CMOS image sensor (384 [24x16] metering zones)
  1. Evaluative metering (AF point-linked)
  2. Partial metering (approx. 5.8% of the area at the center of the screen)
  3. Spot metering (approx. 2.9% of the area at the center of the screen)
  4. Center-weighted average metering
Metering Range Still Photo Shooting: EV -2 to 20
Movie Recording: EV 0 to 20
Exposure Modes Still Photo Shooting:
  1. Scene Intelligent Auto
  2. Hybrid Auto
  3. Special Scenes
  4. Creative Filters
  5. Flexible-priority AE
  6. Program AE
  7. Shutter-priority AE
  8. Aperture-priority AE
  9. Manual Exposure
  10. Bulb Exposure
Movie Recording:
  1. Movie for close-up demos
  2. Movie IS mode
  3. HDR movies
  4. Movie auto exposure
  5. Movie manual exposure
  6. Custom Shooting mode (C mode)
ISO Speed Range
Normal ISO 100-32000 (in 1/3- or 1-stop increments)
Expanded H: (equivalent to ISO 51200)
When set to [Highlight tone priority], the available manual setting range is ISO 200-32000.
Expanded ISO speeds cannot be set in HDR mode or for HDR shooting (HDR PQ).
ISO Auto setting range for still photo shooting: Not suppored
Exposure Compensation
User-set ±3 stops (in 1/3-stop increments)
AEB ±3 stops (in 1/3-stop increments)
AE Lock
  1. Automatic AE lock
    • In One-Shot AF mode, AE is locked as soon as subjects are in focus.
    • Manual AE lock
      • By using the AE Lock button in P, Tv, Av, and M mode.
        Toggling: Press again to cancel and once more to refresh.
      • Enabled in all metering modes.
Type Electronically controlled focal-plane shutter.
Rolling shutter, using the image sensor.
(1) Electronic first curtain
(2) Electronic shutter
* When set to [Electronic], the camera makes no mechanical shutter sound. (An electronic shutter sound can be configured in [Beep] and [Volume: Shutter volume]). Note that the camera may make sounds other than the shutter release sound, such as sounds for aperture adjustment or the lens focus drive, or beeps. Moreover, using long exposure noise reduction with shutter speeds of 1 sec. or longer involves a mechanical second-curtain shutter, which produces a mechanical sound.
* Bands of light may be displayed and captured images may be affected by light and dark banding when shooting under fluorescent lighting or other flickering light sources with the camera set to [Anti-flicker shoot.: Disable].
Shutter Speeds Electronic 1st-curtain shutter:
1/4000th sec - 30 seconds, in 1/3-step increments
Electronic shutter:
1/8000th sec - 30 seconds, in 1/3-step increments
X-sync Speed Elec. 1st-curtain: 1/250 sec.
Shutter Release Soft-touch electromagnetic release
Self Timer 10-sec. delay, 2-sec. delay, Continuous
Still Photo IS In-body IS not provided.
Still Photo IS not suppored.
Accessory Shoe Canon Multi-function accessory shoe •Optional Canon AD-E1 adapter required for conventional shoe-mount flashes and accessories
E-TTL balance Ambience priority, standard, flash priority
Flash Exposure Compensation ±3 (in 1/3-stop increments)
Continuous flash control E-TTL each shot / E-TTL 1st shot
Drive Modes and Continuous Shooting Speed Please click here for full specifications.
HDR Shooting (HDR PQ) Disable / Enable
* Can be used in conjunction with Auto Lighting Optimizer.
Still Photo HDR PQ
Recording format Bit depth Color sampling method HDR specification
HEIF 10 bit YCbCr 4:2:2 ITU-R BT.2100 (PQ)
Movie HDR PQ
mp4 10 bit YCbCr 4:2:2 ITU-R BT.2100 (PQ)
Continuous HDR Shooting (still images) 1 shot only / Every shot
File Format Please click here for full specifications.
Estimated Recording time, Movie Bit Rate and File Size Please click here for full specifications.
Estimated Recording Time, Continued. Please click here for full specifications.
Card Performance Requirements Please click here for full specifications.
Video AF Dual Pixel CMOS AF; Movie Servo AF available in AF Menu
Exposure Compensation ±3 stops (in 1/3-stop increments)
Time Code Yes (Count up, Start time setting, Movie recording count, Movie play count, HDMI time code on/off, HDMI rec. command on/off, Drop frame enable/disable)
Movie Pre-recording (On/Off) Not supported
Time-lapse Movie Setting Please click here for full specifications.
Time-lapse Playback Frame Rate 29.97 (set to NTSC); 25.00fps (set to PAL)
Type TFT color, liquid-crystal monitor
Monitor Size 3.0-inch (screen aspect ratio of 3:2) 2.95 in./7.5cm diagonal (2.44 in./6.2cm width, 1.65 in./4.2cm height)
Dots Approx. 1.62 million dots
Coverage Approx. 100% vertically/horizontally
Brightness Control Manually adjustable to one of seven brightness levels
Touch-screen Operation Supported for AF Point selection; Touch AF; Touch Shutter; Menu selection; Quick Control Menu; Magnified View; Volume Touch Sounds: 0 (silent) to 5
Coating Anti-smudge coating not provided.
Anti-reflection coating not provided.
Interface Languages 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, Japanese)
Display Format Please click here for full specifications.
Highlight Alert Not supported
Histogram Brightness and RGB
Function The Quick Control screen can be accessed by pressing the Quick Control button during shooting, recording, or playback.
Quick Control Screen Users can customize setting items shown on the Quick Control screen.
  • Items shown: Up to 11
  • Edit layout / Reset settings / Clear all items
* Separate Quick Control screens can be set up for use in still photo shooting and movie recording. (Users can select and rearrange the items shown.)
* Customizable from the [Customize Quick Controls] menu item or by pressing and holding the button with the Quick Control screen displayed.
Protection
  1. Single image (select image)
  2. Select range
  3. All images in folder
  4. All images on card
    • Image browsing and image search can be based on ratings.
    • Ratings-based image selections also possible with DPP.
  5. All found images (only during image search)
Erase Except protected images
  1. Select images to erase
  2. Select range
Compatible Printers Images can be sent via Wi-Fi to a PictBridge-compatible (wireless LAN) printer and printed.
DPOF Compliant to DPOF Version 1.1
Supporting Standards Equivalent to IEEE 802.11b/g/n Standards
Transmission Method DS-SS modulation (IEEE 802.11b)
OFDM modulation (IEEE 802.11g/n)
Transition Frequency (Central Frequency) 2.4 GHz band
Frequency: 2412 to 2462 MHz
Channels: 1 to 11 channels
5.0 GHz band
Not supported
Connection Method (1) Camera access point mode
(2) Infrastructure mode
Security Please click here for full specifications.
Communication with a Smartphone
  • Images can be viewed, controlled, and received using a smartphone.
  • Remote control of the camera using a smartphone is possible depending on the Camera Connect specifications.
  • Images can be sent to a smartphone.
  • NFC connection: Not supported
  • Supported images: JPEG, HEIF, RAW/C-RAW, MP4 video files
  • Transcoding while sending: Size to send (original / reduced size); Quality to send (original / compressed)
Remote Operation Using EOS Utility The camera can be controlled via Wi-Fi® or USB, with Canon EOS Utility software installed in a compatible Mac or Windows computer.
Print from Wi-Fi® Printers Supported.
Send Images to a Web Service image.canon: Video files (MP4) and JPEG, HEIF, RAW or C-RAW still images can be uploaded to image.canon servers.
From image.canon, images can be sent to specific social media and 3rd-party cloud image services.
Standards Compliance Bluetooth Specification Version 4.2 compliant (Bluetooth Low Energy technology)
Transmission Method GFSK modulation
Bluetooth Pairing Smartphone up to 10 devices; BR-E1 remote controller 1 unit
Available Functions Dial direction during Tv/Av; Control ring rotation direction; Customize buttons; Customize dials
Customize Buttons Functions can be assigned to the following camera controls.
  • Shutter button (half-press)
  • Movie shooting button
  • ISO speed button
  • AE lock button
  • Cross keys: Up button
  • Cross keys: Left button
  • Cross keys: Right button
  • Cross keys: Down button
  • Lens function button
  • Speedlite menu direct button
Customizable Dials Customize control ring supported.
My Menu Registration Please click here for full specifications.
USB Video Class (UVC) Available
* The camera is accessible to software (such as Zoom, MS Teams, Skype, etc.) on a computer once connected via USB.
USB Terminal Equivalent to Hi-Speed USB (USB 2.0)
  • For PC communication / smartphone communication
  • Terminal type: USB Type-C
  • Shared with terminal for in-camera charging with USB Power Adapter PD-E1.
HDMI Out Terminal HDMI micro OUT terminal Type D
* Resolution switches automatically
* HDMI CEC not supported
* Images not displayed unless [For NTSC] or [For PAL] is set correctly for the TV video system
Clean HDMI Output Provided
Microphone terminal 3.5mm diameter stereo mini jack
Headphone terminal Compatible with 3.5mm diameter stereo mini-plug
Battery Canon LP-E17 battery pack
  • With the AC Adapter AC-E6N + DC Coupler DR-E18, AC power is possible (AC Adapter Kit ACK-E18 can also be used).
  • USB Power Adapter PD-E1 supports in-camera charging of Battery Pack LP-E17 when the camera is turned off and can supply power when the camera is turned on.
Optional Battery Grip Not supported
Battery Check Automatic battery check with 4-level display when the power switch is turned ON.
Start-up Time Approx. 0.4 sec.
  • Based on CIPA testing standards.
Dimensions (W x H x D) Approx. 4.58 x 3.37 x 2.71 in. / 116.3 x 85.5 x 68.8mm
Based on CIPA standards.
Weight Please click here for full specifications.
Working Temperature Range 32-104°F / 0-+40°C
Focal Length 18-45mm
Maximum and Minimum Aperture f/4.5 - f/32
Lens Mount Type RF Mount
Compatible Cameras Canon EOS R-series, APS-C and full-frame (automatic APS-C sensor cropping if used on full-frame EOS R-series cameras)
Minimum Focusing Distance 0.20 m (at 18 mm)
Maximum Magnification 0.16x (at 45 mm)
Field of View, at Minimum Focus Distance Approx. 153 × 102 mm (at 18 mm) to approx. 137 × 92 mm (at 45 mm)
Angle of View (Diagonal) Approx. 74° 20 - 33° 40
Lens Construction 7 elements in 7 groups
Special Elements (Two) Aspherical elements
Lens Coating Canon SSC (Super Spectra Coating)
Filter Size Diameter ø49 mm
Aperture Blades 7
Image Stabilization 4 stops correction with In-lens Optical Image Stabilization (6 stops correction with EOS R5 in-body coordinated Image stabilization)
Focusing Drive System Canon STM (Leadscrew type STM)
Full-time Manual Focusing Yes
(Supports both ONE SHOT AF and SERVO AF with compatible EOS R-series cameras)
Dual Pixel CMOS AF Coverage (Horizontal x Vertical) EOS R Approx. 80% x 80%
EOS R5 Approx. 80% x 80%
EOS R7/R10 Approx. 100% x 100%
Control Ring Dual-function Manual focus ring / Control Ring (selected using camera menu)
Manual Focus Ring Electronic ring system
Full-time Manual focus possible
No physical limit to ring rotational angle
AF/MF Switch None focus mode selected in camera menu
MF/Control Ring Switch None must be selected in camera menu
Distance Scale None
Distance scale available in EVF or Live View LCD screen of compatible EOS R-series cameras
Distance Limiter Switch None
Dust / Weather Resistant Construction None
Maximum Outer Diameter x Length Approx. ø2.7 in. x 1.7 in. (ø68.9mm x 44.3mm)
Weight Approx. 4.6 oz. / 0.3 lb. / 130g
Lens hood Canon EW-53
Bayonet-mount, petal-shaped hood
Optional accessory, sold separately
Lens Cap (Front) Canon E-49 (center pinch-type) (Bundled)
Dust Cap Canon Lens Dust Cap RF (Bundled)
Lens Case Canon Lens Case LP814
Extension Tubes None (No Canon RF mount extension tubes)
Close-up Lenses 250D / 500D None (No ø49mm size available)
Canon RF Extender 1.4x/2x Not compatible
Canon Gelatin Filter Holder III/IV Not compatible
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
