Canon Support for EOS R6 Mark II RF24-105mm F4 L IS USM Lens Kit | Canon U.S.A., Inc.
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows NT
- Linux
0 of 0
Results will appear after selecting an Operating System and Version above
File Name
Picture Style Editor Instruction Manual
File Name
EOS Utility Instruction Manual
File Name
VR Recording Guide
RECOMMENDED
File Name
EOS R6 Mark II Advanced User Guide
RECOMMENDED
File Name
EOS VR Utility Instruction Manual
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | Digital interchangeable lens, mirrorless camera |
Image Processor | DIGIC X |
Recording Media | (Two) SD card slots
Compatible Lenses | Canon RF lens group (including RF-S lenses) When using Mount Adapter EF-EOS R: Canon EF or EF-S lenses (excluding EF-M lenses) |
Lens Mount | Canon RF mount |
Type | Full-frame CMOS sensor (compatible with Dual Pixel CMOS AF) |
Effective pixels | Approx. 24.2 megapixels |
Screen Size | Approx. 36.0 x 24.0 mm |
Pixel Unit | Approx. 6.00 µm square |
Total Pixels | Approx. 25.6 megapixels |
Aspect Ratio | 3:2 (Horizontal:Vertical) |
Color Filter System | RGB primary color filters |
Low Pass Filter | Installed in front of the image sensor, non-detachable |
Dust Deletion Feature |
Recording Format | Compliant to Design rule for Camera File system 2.0 and Exif 2.31*. *Supports time difference information in Exif 2.31. |
Image Format | JPEG, HEIF, RAW / C-RAW / Dual Pixel RAW/ RAW burst (CR3), C-RAW (Canon original) ; Movies: ALL-I (Time-lapse video only), IPB (MP4) |
File Size | * At H+ Drive setting (12 fps), using Mechanical or 1st-curtain Electronic shutter. *1: Number of shots using a 32 GB card that conforms to Canon testing standards. *2: Number of shots using a 32 GB UHS-II card that conforms to Canon testing standards. *3: When set to [HDR shooting (HDR PQ): Disable]. *4: When set to [HDR shooting (HDR PQ): Enable]. |
File Numbering | The following file numbers can be set:
RAW + JPEG / HEIF Simultaneous Recording | Simultaneous recording of any combination of RAW/C-RAW and JPEG/HEIF image-recording quality is supported. |
Color Space | Selectable between sRGB and Adobe RGB |
Picture Style |
Settings |
*2: White balance can be adjusted during movie recording. |
Auto White Balance | Option between ambience priority and white priority settings, using SET button |
White Balance Shift | Blue/amber bias: ±9 levelsMagenta/green bias: ±9 levelsCorrected in reference to the current WB mode's color temperature. |
Type | OLED color electronic viewfinder; 0.5-inch, approx. 3.69 million dots |
Coverage | Approx. 100% vertically and horizontally relative to the shooting image area (with image quality L, at approx. 23mm eyepoint). |
Magnification / Angle of View | Approx. 0.76x / Approx. 35.2 degrees (with 50mm lens at infinity, -1 m-1) |
Eye Point | Approx. 23mm (at -1 m-1 from the eyepiece lens end) |
Dioptric Adjustment Range | Approx. -4.0 to + 2.0 m-1 (dpt) |
Viewfinder Information |
Focus Method | Dual Pixel CMOS AF |
Number of AF zones available for Automatic Selection | AF area: Horizontal: Approx. 100% x Vertical: Approx. 100% (100% x 100% AF coverage in Face Detect + Tracking AF; coverage can vary, depending upon lens being used) Stills: Max. 1053 zones (39 x 27) Movies: Max. 1053 zones (39 x27) |
Selectable Positions for AF Point | AF area: Horizontal: Approx. 90% x Vertical: Approx. 100% Stills: Max. 4897 positions (83 x 59) Movies: Max 4067 positions (83 x 49) |
AF Working Range | EV -6.5 to 20 (f/1.2 lens*, center AF point, One-Shot AF,at 73°F/23°C, ISO 100 * Except RF lenses with a Defocus Smoothing (DS) coating. |
Focusing brightness range (still photo shooting) | EV 6.5 to 21 (with an f/1.2 lens,* center AF point, One-Shot AF at room temperature, and ISO 100) * Except RF lenses with a Defocus Smoothing (DS) coating. |
Focusing brightness range (in movie recording) | 4K: EV 4.0 to 21 Full HD: EV 4.5 to 21 (with an f/1.2 lens,* center AF point, One-Shot AF at room temperature, ISO 100, and 29.97 / 25.00 fps.) * Except RF lenses with a Defocus Smoothing (DS) coating. |
Available AF Areas |
Available Subject Detection |
Eye Detection | Auto:
Metering Modes | Real-time metering from CMOS image sensor (384 [24x16] metering zones)
Metering Range | EV -3 - 20 (at 73°F/23°C, ISO 100)(Still Photo Shooting) |
Exposure Modes |
ISO Speed Range | Manually Set
ISO Auto range settings in still photo shooting *1: ISO 200 when set to [Highlight tone priority: Enable/Enhanced]. *2: Varies depending on the [Maximum] and [Minimum] settings for [Auto range]. *3: If outside the setting range, changed to the value closest to ISO 400. |
Exposure Compensation | Click here to view the full specifications PDF. |
AE Lock |
Type | Electronically controlled focal-plane shutter
Shutter Speeds | Mechanical / 1st-curtain Electronic shutter: 1/8000th sec 30 seconds, in 1/3 or 12-step increments Electronic shutter: 1/8000th sec 30 seconds, in 1/3 or 12-step increments (1/16,000th possible, if user-set in Tv or M shooting modes) |
X-sync Speed | Mechanical Shutter: 1/200 sec. Elec. 1st-curtain: 1/250 sec. |
Shutter Release | Soft-touch electromagnetic release |
Self Timer | 10-sec. delay, 2-sec. delay |
Still Photo IS | In-body IS operation can be selected when using a non-IS lens.
Accessory Shoe | Canon Multi-function accessory shoe Optional Canon AD-E1 adapter required for conventional shoe-mount flashes and accessories |
E-TTL balance | Ambience priority, standard, flash priority |
Flash Exposure Compensation | ±3 stops in 1/3- or 1/2-stop increments |
Continuous flash control | E-TTL each shot / E-TTL 1st shot |
Drive Modes and Continuous Shooting Speed | Click here to view the full specifications PDF. |
HDR Shooting (HDR PQ) | Disable / Enable |
Still Photo HDR PQ | Click here to view the full specifications PDF. |
Movie HDR PQ | Click here to view the full specifications PDF. |
Continuous HDR Shooting (still images) | 1 shot only / Every shot |
Shooting Times | Click here to view the full specifications PDF.
*1 Time available for continuous shooting in 23°C / 73°F environment, from a cold start. If the camera is in LV mode standby before shooting or the ambient temperature is high, the shooting time may be shorter.
*2 According to Canon measurement conditions when using UHS-II cards conforming to Canon testing standards.
*3 The maximum duration of shooting may be shorter under some circumstances even if recording begins from cold start, due to a rise in temperature inside the camera caused by pre-shooting camera setting operations or by prolonged use of the Live View mode. When the card is full, movie recording stops automatically. In this case, duration time when you erase the data and restart shooting. |
File Format | Normal Movies
Click here to view the full specifications PDF. * Recording in AAC when [Audio compression] (C.Fn4) is set to [Enable] or Linear PCM when set to [Disable]. |
Estimated Recording time, Movie Bit Rate and File Size | H.264/AVC (Canon Log: Off, HDR PQ: Off) Click here to view the full specifications PDF. * Bit rate only applies to video output, not audio or metadata. * Audio is recorded when [C.Fn4 audio compression:Enable] (Audio: AAC) is set. * Movie recording stops when the maximum recording time per movie is reached. * No audio is recorded for approx. the last two frames with the compression method for movie recording quality set to IPB (Standard) or IPB (Light) and the camera set to [C.Fn4 Audio compression: Enable]. Moreover, the video and sound may be slightly out of sync when movies are played back in Windows. * Mbps megabits per second (8 megabits = 1 megabyte) |
Estimated Recording Time, Continued. | H.265/HEVC (Canon Log: On or HDR PQ: On) Click here to view the full specifications PDF. * Bit rate only applies to video output, not audio or metadata. * Audio is recorded when [C.Fn4 audio compression:Enable] (Audio: AAC) is set. * Movie recording stops when the maximum recording time per movie is reached. 31 min. * No audio is recorded for approx. the last two frames with the compression method for movie recording quality set to IPB (Standard) or IPB (Light) and the camera set to [C.Fn4 Audio compression: Enable]. Moreover, the video and sound may be slightly out of sync when movies are played back in Windows. * Mbps megabits per second (8 megabits = 1 megabyte) |
Card Performance Requirements | Click here to view the full specifications PDF. |
Video AF | Dual Pixel CMOS AF; Movie Servo AF available in AF Menu |
Time Code | Yes (Count up, Start time setting, Movie recording count, Movie play count, HDMI time code on/off, HDMI rec. command on/off, Drop frame enable/disable) |
Movie Pre-recording (On/Off) | 3 or 5 seconds; user-selectable |
Time-lapse Movie Setting | Interval 2 sec 99:59:59; Number of frames 23,600; Movie recording size 4K/Full HD; Auto exposure fixed @ first frame/auto for each frame; Beep per frame recorded (volume setting 0/silent 5) |
Time-lapse Playback Frame Rate | 29.97 (set to NTSC); 25.00fps (set to PAL) |
Type | TFT color, liquid-crystal monitor |
Monitor Size | 3.0-inch (screen aspect ratio of 3:2) 2.95 in./7.5cm diagonal (2.44 in./6.2cm width, 1.65 in./4.2cm height) |
Dots | Approx. 1.62 million dots |
Coverage | Approx. 100% vertically/horizontally |
Brightness Control | Manually adjustable to one of seven brightness levels |
Touch-screen Operation | Supported for AF Point selection; Touch AF; Touch Shutter; Menu selection; Quick Control Menu; Magnified view |
Coating | Clear View LCD II
Interface Languages | 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, Japanese) |
Highlight Alert | The white areas with no image data will blink. |
Histogram | Brightness and RGB |
Function | The Quick Control screen can be accessed by pressing the Quick Control button during shooting, recording, or playback. |
Quick Control Screen | The following settings are available for the [Quick Control screen] during movie recording.
Protection |
Erase | Except protected images
Compatible Printers | Not supported |
DPOF | Compliant to DPOF Version 1.1 |
Supporting Standards | Equivalent to IEEE 802.11 b/g/n/a/ac Standards |
Transmission Method | DS-SS modulation (IEEE 802.11b) OFDM modulation (IEEE 802.11g/n/a/ac) |
Transition Frequency (Central Frequency) | 2.4 GHz band Frequency: 2412 to 2462 MHz Channels: 1 to 11 channels 5.0 GHz band Frequency: 5180 to 5825 MHz Channels: 36 to 165 channels1 |
Connection Method | (1) Camera access point mode (2) Infrastructure mode |
Communication with a Smartphone |
Remote Operation Using EOS Utility | The camera can be controlled via Wi-Fi® or USB, with Canon EOS Utility software installed in a compatible Mac or Windows computer. |
Print from Wi-Fi® Printers | Not supported. |
Send Images to a Web Service | image.canon: Video files (MP4) and JPEG, HEIF, RAW or C-RAW still images can be uploaded to image.canon servers. From image.canon, images can be sent to specific social media and 3rd-party cloud image services. |
Standards Compliance | Bluetooth Specification Version 5.0 compliant (Bluetooth Low Energy technology) |
Transmission Method | GFSK modulation |
Bluetooth Pairing | Smartphone up to 10 devices; BR-E1 remote controller 1 unit |
Available Functions | Dial direction during Tv/Av; Control ring rotation direction; Customize buttons; Customize dials |
Custom Controls | Customizable Buttons Click here to view the full specifications PDF. |
Customizable Dials | Click here to view the full specifications PDF. |
My Menu Registration |
• Up to six top-tier menu options and Custom Function settings can be registered.
• Up to five My Menu tabs can be added.
USB Terminal | Equivalent to SuperSpeed USB (USB 3.1 Gen 1)
HDMI Out Terminal | HDMI micro OUT terminal Type D (Resolution switches automatically) / CEC not compatible
Microphone terminal | 3.5mm diameter stereo mini jack |
Headphone terminal | Compatible with 3.5mm diameter stereo mini-plug |
Battery | Canon LP-E6NH battery pack (also compatible with LP-E6N and LP-E6 battery packs)
Optional Battery Grip | Compatible with Canon Battery Grip BG-R10 (Accepts one or two LP-E6NH, LP-E6N, or LP-E6 battery packs) |
Battery Check | Automatic battery check when the power switch is turned ON.
Displayed in 5 levels in viewfinder, and on LCD screen.
Battery info display in Set-up Menu:
Start-up Time | Approx. 0.4 sec.
Dimensions (W x H x D) | Approx. 5.45 x 3.87 x 3.48 in. / 138 x 98.4 x 88.4mm Based on CIPA standards. |
Weight | Approx. 1.5 lbs. / 680g (including battery, SD memory card; without body cap) Approx. 1.3 lbs. / 598g (body only; without battery, card or body cap) |
Working Temperature Range | 32-104° F / 0-+40° C |
Working Humidity | 85% or less |
ADDITIONAL SUPPORT
CONTACT US
