Canon Support for EOS R6 Mark II | Canon U.S.A., Inc.
EOS R6 Mark II
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Date 05.07.25
File Size 142.00 B
Date 11.09.22
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type Digital interchangeable lens, mirrorless camera
Image Processor DIGIC X
Recording Media (Two) SD card slots
  • Compatible with UHS-II
  • Eye-Fi cards and Multimedia cards (MMC) are not supported.
Compatible Lenses Canon RF lens group (including RF-S lenses) When using Mount Adapter EF-EOS R: Canon EF or EF-S lenses (excluding EF-M lenses)
Lens Mount Canon RF mount
Type Full-frame CMOS sensor (compatible with Dual Pixel CMOS AF)
Effective pixels Approx. 24.2 megapixels
Screen Size Approx. 36.0 x 24.0 mm
Pixel Unit Approx. 6.00 µm square
Total Pixels Approx. 25.6 megapixels
Aspect Ratio 3:2 (Horizontal:Vertical)
Color Filter System RGB primary color filters
Low Pass Filter Installed in front of the image sensor, non-detachable
Dust Deletion Feature
  1. Self Cleaning Sensor Unit
    • Removes dust adhering to the low-pass filter.
    • At power off only / Enable / Disable. Performed automatically (taking about approx. 2 sec. as indicated on the screen) or manually (taking about approx. 8 sec. as indicated on the screen).
    • After manually activated cleaning, the camera will automatically restart (Power OFF to ON).
    • When [Multi Shot Noise Reduction], [Multiple exposures], or [HDR mode] is set, [Clean now] and [Clean manually] cannot be selected.
  2. Dust Delete Data acquisition and appending
    • The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images.
    • The dust coordinate data appended to the image is used by the EOS software to automatically erase the dust spots.
    • Not available with RF-S/EF-S lenses, in cropped shooting, during focus bracket shooting, in FAW burst mode, or multiple-exposure shooting.
  3. Manual cleaning (by hand)
Recording Format Compliant to Design rule for Camera File system 2.0 and Exif 2.31*. *Supports time difference information in Exif 2.31.
Image Format JPEG, HEIF, RAW / C-RAW / Dual Pixel RAW/ RAW burst (CR3), C-RAW (Canon original) ;Movies: ALL-I (Time-lapse video only), IPB (MP4)
File Size
Quality
File Size
[Approx. MB]
Possible Shots
[Approx.]*1
Maximum Burst [Approx.]*
Standard Card*¹ High-speed Card*² (UHS-II)
JPEG*3 L (fine)  8.2 3700  540 1000 or more
L (Normal) 4.4   68201000 or more1000 or more
M (fine) 4.6   33601000 or more1000 or more
M (Normal) 2.6  11450 1000 or more1000 or more
S1 (Fine)  3.1  9820 1000 or more 1000 or more
S1 (Normal)  1.9  12840 1000 or more 1000 or more
S2  1.8  16290 1000 or more 1000 or more
HEIF* L (fine)  8.3 3600  470 1000 or more
L (Normal) 6.3   4690 1000 or more 1000 or more
M (fine)  5.0 5830 1000 or more 1000 or more
M (Normal) 3.9   7400 1000 or more 1000 or more
S1 (Fine)  3.5  8390 1000 or more 1000 or more
S1 (Normal)  2.8  10270 1000 or more 1000 or more
S2  1.8  14250 1000 or more 1000 or more
RAW  RAW  26.1  1170 85 110
C-RAW  13.2  2350 240 1000 or more
RAW+JPEG*3 RAW + L (fine) 26.1 + 8.2   890 85 110
C-RAW + L (fine) 13.2 + 8.2   1430 170 390
RAW+HEIF* RAW + L (fine)  28.6 + 8.3  820 85 95
C-RAW + L (fine)  15.8 + 8.3  1260 160 180
* At H+ Drive setting (12 fps), using Mechanical or 1st-curtain Electronic shutter.
*1: Number of shots using a 32 GB card that conforms to Canon testing standards.
*2: Number of shots using a 32 GB UHS-II card that conforms to Canon testing standards.
*3: When set to [HDR shooting (HDR PQ): Disable].
*4: When set to [HDR shooting (HDR PQ): Enable].
File Numbering The following file numbers can be set:
  1. File numbering methods
    • Continuous numbering
      • The numbering of captured images continues even after you replace the card.
    • Auto reset
      • When you replace the card, the numbering will be reset to start from 0001. If the new SD card already contains images, the numbering will continue from the last recorded image in the card.
  2. Manual reset
    • Resets the file number to 0001, and creates a new folder automatically.
RAW + JPEG / HEIF Simultaneous Recording Simultaneous recording of any combination of RAW/C-RAW and JPEG/HEIF image-recording quality is supported.
Color Space Selectable between sRGB and Adobe RGB
Picture Style
  1. Auto
  2. Standard
  3. Portrait
  4. Landscape
  5. Fine Detail
  6. Neutral
  7. Faithful
  8. Monochrome
  9. User Defined 1-3
    • In Scene Intelligent Auto, [Auto] will be set automatically.
    • [Standard] is the default setting for [User Def. 1-3].
Settings
  1. Auto (Ambience priority/White priority)
  2. Day Light
  3. Shade
  4. Cloudy*1
  5. Tungsten light
  6. White fluorescent light
  7. Flash
  8. Custom (Custom WB)
  9. Color temperature*2
*1: Effective also in twilight and sunset.
*2: White balance can be adjusted during movie recording.
Auto White Balance Option between ambience priority and white priority settings, using SET button
White Balance Shift Blue/amber bias: ±9 levelsMagenta/green bias: ±9 levelsCorrected in reference to the current WB mode's color temperature.
Type OLED color electronic viewfinder; 0.5-inch, approx. 3.69 million dots
Coverage Approx. 100% vertically and horizontally relative to the shooting image area (with image quality L, at approx. 23mm eyepoint).
Magnification / Angle of View Approx. 0.76x / Approx. 35.2 degrees (with 50mm lens at infinity, -1 m-1)
Eye Point Approx. 23mm (at -1 m-1 from the eyepiece lens end)
Dioptric Adjustment Range Approx. -4.0 to + 2.0 m-1 (dpt)
Viewfinder Information
  1. Maximum burst
  2. Possible shots/Sec. until self-timer shoots
  3. Focus Bracketing/ Multiple-exposure/HDR shooting/Multi Shot Noise Reduction/Bulb time/Interval timer
  4. Shooting mode
  5. AF method
  6. AF operation
  7. Image quality
  8. Card
  9. Drive mode
  10. Metering mode
  11. No. of remaining shots for focus braketing, multiple exposures, or interval timer
  12. Electronic level
  13. Movie recording time available
  14. Battery level
  15. Image Stabilizer (IS mode)
  16. Histogram (Brightness/RGB)
  17. Quick Control button
  18. Anti-flicker shooting
  19. White balance/White balance correction
  20. Picture style
  21. Auto Lighting Optimizer
  22. Still photo cropping / Aspect ratio
  23. AF point (1-point AF)
  24. AEB/FEB
  25. View Assist
  26. HDR PQ
  27. Flash ready / FE lock / High-speed sync
  28. Electronic shutter
  29. Touch shutter / Create folder
  30. AE lock
  31. Shutter speed / Multi-function lock warning
  32. Aperture value
  33. Wi-Fi® function
  34. Wi-Fi® signal strength
  35. Bluetooth® function
  36. Exposure simulation
  37. Magnify button
  38. ISO speed
  39. Highlight tone priority
  40. Exposure compensation
  41. Exposure level indicator
Focus Method Dual Pixel CMOS AF
Number of AF zones available for Automatic Selection AF area: Horizontal: Approx. 100% x Vertical: Approx. 100%(100% x 100% AF coverage in Face Detect + Tracking AF; coverage can vary, depending upon lens being used)Stills: Max. 1053 zones (39 x 27)Movies: Max. 1053 zones (39 x27)
Selectable Positions for AF Point AF area: Horizontal: Approx. 90% x Vertical: Approx. 100%Stills: Max. 4897 positions (83 x 59)Movies: Max 4067 positions (83 x 49)
AF Working Range EV -6.5 to 20 (f/1.2 lens*, center AF point, One-Shot AF,at 73°F/23°C, ISO 100 * Except RF lenses with a Defocus Smoothing (DS) coating.
Focusing brightness range (still photo shooting) EV 6.5 to 21 (with an f/1.2 lens,* center AF point, One-Shot AF at room temperature, and ISO 100)* Except RF lenses with a Defocus Smoothing (DS) coating.
Focusing brightness range (in movie recording) 4K: EV 4.0 to 21Full HD: EV 4.5 to 21(with an f/1.2 lens,* center AF point, One-Shot AF at room temperature, ISO 100, and29.97 / 25.00 fps.)* Except RF lenses with a Defocus Smoothing (DS) coating.
Available AF Areas
  • Spot AF
  • 1-point AF
  • Expand AF area: Above/below/left/right
  • Expand AF area: Around
  • Flexible Zone AF 1
  • Flexible Zone AF 2
  • Flexible Zone AF 3
  • Whole area AF
Available Subject Detection
  • Auto
  • People
  • Animals (dogs / cats / birds / horses)
  • Vehicles (motorsports cars or motorcycles / aircraft / trains)
    * Certain types of animals or vehicles may not be detected, depending on shape and appearance
Eye Detection Auto:
  1. Selects the eye closer to the camera (as detected from the angle of the face).
  2. At the same distance from the camera, selects the eye closer to the center of the image.
Manual:
  1. Can be selected by touch.
  2. Can be selected with the Multi-controller.
Metering Modes Real-time metering from CMOS image sensor (384 [24x16] metering zones)
  1. Evaluative metering (AF point-linked)
  2. Partial metering (approx. 5.9% of the area at the center of the screen)
  3. Spot metering (approx. 3.0% of the area at the center of the screen)
  4. Center-weighted average metering
Metering Range EV -3 - 20 (at 73°F/23°C, ISO 100)(Still Photo Shooting)
Exposure Modes
  1. Scene Intelligent Auto
  2. Hybrid Auto
  3. Special Scenes
  4. Creative Filters
  5. Flexible-priority AE
  6. Program AE
  7. Shutter-priority AE
  8. Aperture-priority AE
  9. Manual Exposure
  10. Bulb Exposure
  11. Custom Shooting Modes C1, C2, C3
ISO Speed Range Manually Set
Normal ISO 100102400 (in 1/3- or 1-stop increments)
Expanded L: equivalent to ISO 50, H: 204800
  • For [Highlight tone priority], the settable ISO speed range will be ISO 200 to 102400.
  • Expanded ISO cannot be set for HDR mode or during HDR PQ shooting.
ISO Auto range settings in still photo shooting
Auto Range ISO Speed
Minimum ISO 10051200 (in 1-stop increments)
Maximum ISO 200102400 (in 1-stop increments)
ISO Auto details in still photo shooting
Shooting mode No Flash Using Flash
Compatible Lens Incompatible Lens
Auto / Hybrid Auto ISO 10025600 ISO 1006400 ISO 1001600
Special Scenes Varies by shooting mode
Creative Filters Varies by shooting mode
Fv / P / Tv / Av / M -ISO 100*1 *2 102400*2 ISO 100*1 *26400*2 ISO 100*1 *21600*2
B ISO 400*3 ISO 400*3
*1: ISO 200 when set to [Highlight tone priority: Enable/Enhanced].
*2: Varies depending on the [Maximum] and [Minimum] settings for [Auto range].
*3: If outside the setting range, changed to the value closest to ISO 400.
Exposure Compensation
User-set ±3 stops in 1/3- or 1/2-stop increments
AEB ±3 stops in 1/3- or 1/2-stop increments
AE Lock
  1. Auto AE lock
    • AE is locked as soon as subjects are in focus using One-Shot AF when set to selected metering mode in [C.Fn2: AE lock meter. mode after focus].
    • User-set AE lock.
      • Use the AE lock button (update by pressing the button again) in Fv, P, Tv, Av, and M mode.
      • Enabled in all metering modes.9
Type Electronically controlled focal-plane shutter
  1. Electronic first curtain
  2. Mechanical shutter
  3. Electronic shutter*
* Cannot be used in conjunction with the following functions: flash photography, HDR shooting, multiple exposures, Multi Shot Noise Reduction, AEB, HDR PQ, anti-flicker shooting, Dual Pixel RAW shooting, Digital Lens Optimizer [High]. * A shutter release sound is not generated. However, note that the sounds other than the shutter release sound (aperture, focusing lens drive sound/electronic sound, etc.) may be generated. * In electronic shutter shooting under conditions such as flash firing by other cameras or with fluorescent lighting or other flickering light sources, a strip of light or banding due to the brightness difference may be recorded in the image.
Shutter Speeds Mechanical / 1st-curtain Electronic shutter: 1/8000th sec 30 seconds, in 1/3 or 12-step increments
Electronic shutter: 1/8000th sec 30 seconds, in 1/3 or 12-step increments (1/16,000th possible, if user-set in Tv or M shooting modes)
X-sync Speed Mechanical Shutter: 1/200 sec.Elec. 1st-curtain: 1/250 sec.
Shutter Release Soft-touch electromagnetic release
Self Timer 10-sec. delay, 2-sec. delay
Still Photo IS In-body IS operation can be selected when using a non-IS lens.
  • Always on
  • Only for shot (no stabilization in viewfinder/LCD screen between shots)Coordinated IS when used with Canon RF or RF-S lenses having optical Image Stabilization
Accessory Shoe Canon Multi-function accessory shoe Optional Canon AD-E1 adapter required for conventional shoe-mount flashes and accessories
E-TTL balance Ambience priority, standard, flash priority
Flash Exposure Compensation ±3 stops in 1/3- or 1/2-stop increments
Continuous flash control E-TTL each shot / E-TTL 1st shot
Drive Modes andContinuous Shooting Speed
Drive Modes Operating Modes Mechanical Shutter Electronic 1st curtain Electronic shutter
Single Shooting Yes Yes Yes
High-speed Continuous Shooting + *¹ Mode A Approx. 12 shots/sec.*², Approx. 40 shots/sec
Mode B Approx. 9.2 shots/sec.*²
Mode C Approx. 6.6 shots/sec.
High-speed Continuous Shooting *¹ Mode A Approx. 5.5 shots/sec.*² ² Approx. 7.0 shots/sec.*² Approx. 20 shots/sec
Mode B Approx. 5.2 shots/sec.*² Approx. 6.6 shots/sec.*²
Mode C Approx. 3.5 shots/sec. Approx. 4.3 shots/sec.
Low-speed Continuous Shooting Approx. 3.0 shots/sec.*² Approx. 5 shots/sec
Self-timer: 10 sec / remote control Yes
Self-timer: 2 sec / remote control Yes
Self-timer: Continuous Yes
1. Continuous shooting speed is lower under certain shooting and measurement conditions: shutter speed, aperturevalue subject conditions, brightness, type of lens, timing when internal memory becomes full (temporarily disables shooting)
- Mechanical / electronic 1st curtain: use of flash, anti-flicker shooting: Enable, Dual Pixel RAW shooting- Enable, type of battery, battery level, temperature, use of a battery grip, use of WFT, use of built-in Wi-Fi.
- Electronic shutter: State of aperture in continuous shooting
* With Certain lenses, zooming during continuous shooting with electronic shutter may cause changes in exposure even at the same f/number.
2. Automatically switches among modes A (drive mode icon lit in green), B (drive mode icon lit in white), and C (drive mode icon flashing in white).
Operating Mode is for reference only automatically set by camera, is dependent on factors such as battery power level, battery type, and lens in use, and cannot be set by user.
* For flash shooting, values for AE, flash metering, and WB do not change after the first shot.
HDR Shooting (HDR PQ) Disable / Enable
Still Photo HDR PQ
Recording format Bit depth Color sampling method HDR specification
HEIF 10 bit YCbCr 4:2:2 ITU-R BT.2100 (PQ)
Movie HDR PQ
mp4 10 bit YCbCr 4:2:2 ITU-R BT.2100 (PQ)
Continuous HDR Shooting (still images) 1 shot only / Every shot
Shooting Times
Resolution and Frame Rate Mode Approx. Continuous Shooting Time*1,2,3
4K 59.94p
(without crop)
100% sensor width
(6K oversampling)
40 min. or longer
4K 59.94p (crop) APS-C Crop 50 min. or longer
4K 29.97p
(without crop)
100% sensor width
(6K oversampling)
No limit with heating
Full HD 179.82p 100% sensor width 60 min. or longer
*1 Time available for continuous shooting in 23°C / 73°F environment, from a cold start. If the camera is in LV mode standby before shooting or the ambient temperature is high, the shooting time may be shorter.
*2 According to Canon measurement conditions when using UHS-II cards conforming to Canon testing standards.
*3 The maximum duration of shooting may be shorter under some circumstances even if recording begins from cold start, due to a rise in temperature inside the camera caused by pre-shooting camera setting operations or by prolonged use of the Live View mode. When the card is full, movie recording stops automatically. In this case, duration time when you erase the data and restart shooting.
File Format Normal Movies
Canon Log OFF ON (Canon Log 3)
HDR PQ OFF ON OFF
Container format MP4
Bit depth 8 bit 10 bit
Compression H.264 / MPEG-4 AVC H.265 / HEVC
Video signal recording range Full range (0-255) Full range (0-1023) Full range (128-1020)
Color sampling method YCbCr 4:2:0 YCbCr 4:2:2
Standards compliance Rec.ITU-R BT.709 Rec. ITU-R BT.2100
Color gamut Rec.709 Rec.2020 Rec.709 / Rec.2020 / Cinema Gamut
Audio IPB (Standard)* AAC / Linear PCM
IPB (Light) AAC
* Recording in AAC when [Audio compression] (C.Fn4) is set to [Enable] or Linear PCM when set to [Disable].
Estimated Recording time, Movie Bit Rate and File Size H.264/AVC (Canon Log: Off, HDR PQ: Off)
Video Recording Size Total Recording Time (approx.) Bit Rate/File Size (approx.)
32 GB 128 GB 512 GB
4K UHD
4K UHD cropped
59.94 fps
50.00 fps
IPB (Standard) 18 min. 1 hr.14 min. 4 hr.56 min. 230 Mbps
1647 MB/min.
IPB (Light) 35 min. 2 hr. 21 min. 9 hr. 27 min. 120 Mbps
860 MB/min.
29.97 fps
25.00 fps
23.98 fps
IPB (Standard) 35 min. 2 hr. 21 min. 9 hr. 27 min. 120 Mbps
860 MB/min.
IPB (Light) 1 hr. 10 min. 4 hr. 43 min. 18 hr. 52 min. 60 Mbps
431 MB/min.
4K UHD
(Time-lapse movie)
29.97 fps
25.00 fps
ALL-I 9 min. 36 min. 2 hr.25 min. 470 Mbps
3362 MB/min.
Full UHD (High Frame Rate movie) 172.82 fps
150.00 fps
IPB (Standard) 23 min. 1 hr.34 min. 6 hr.19 min. 180 Mbps
1287 MB/min
IPB (Light) 40 min. 2 hr.42 min. 10 hr.50 min. 105 Mbps
751 MB/min
119.88 fps
100.00 fps
IPB (Standard) 35 min. 2 hr. 22 min. 9 hr. 28 min. 120 Mbps
858 MB/min
IPB (Light) 1 hr. 0 min. 4 hr. 3 min. 16 hr. 15 min. 70 Mbps
501 MB/min
Full HD Full HD cropped 59.94 fps
50.00 fps
IPB (Standard) 1 hr. 10 min. 4 hr. 43 min. 18 hr. 52 min. 60 Mbps
431 MB/min.
IPB (Light) 2 hr. 0 min. 8 hr. 3 min. 32 hr. 15 min. 35 Mbps
252 MB/min.
29.97 fps
25.00 fps
23.98 fps
IPB (Standard) 2 hr. 20 min. 9 hr. 23 min. 37 hr. 35 min. 30 Mbps
216 MB/min.
IPB (Light) 5 hr. 47 min. 23 hr. 11 min. 92 hr. 47 min. 12 Mbps
88 MB/min.
Full HD (Time-lapse movie) 29.97 fps
25.00 fps
ALL-I 47 min. 3 hr. 9 min. 12 hr. 38 min. 90 Mbps
644 MB/min.
* Bit rate only applies to video output, not audio or metadata.
* Audio is recorded when [C.Fn4 audio compression:Enable] (Audio: AAC) is set.
* Movie recording stops when the maximum recording time per movie is reached.
* No audio is recorded for approx. the last two frames with the compression method for movie recording quality set to IPB (Standard) or IPB (Light) and the camera set to [C.Fn4 Audio compression: Enable]. Moreover, the video and sound may be slightly out of sync when movies are played back in Windows.
* Mbps megabits per second (8 megabits = 1 megabyte)
Estimated Recording Time, Continued. H.265/HEVC (Canon Log: On or HDR PQ: On)
32 GB 128 GB 512 GB
4K UHD
4K UHD cropped
59.94 fps
50.00 fps
IPB (Standard) 12 min. 50 min. 3 hr. 20 min. 340 Mbps
2434 MB/min.
IPB (Light) 25 min. 1 hr. 40 min. 6 hr. 40 min. 170 Mbps
1218 MB/min.
29.97 fps
25.00 fps
23.98 fps
IPB (Standard) 25 min. 1 hr. 40 min. 6 hr. 40 min. 170 Mbps
1218 MB/min.
IPB (Light) 50 min. 3 hr. 20 min. 13 hr. 20 min. 85 Mbps
610 MB/min.
4K UHD
(Time-lapse movie)
29.97 fps
25.00 fps
3362 MB/min.
150.00 fps
IPB (Standard) 15 min. 1 hr. 3 min. 4 hr. 12 min. 270 Mbps
1931 MB/min
IPB (Light) 28 min. 1 hr. 53 min. 7 hr. 35 min. 150 Mbps
1073 MB/min
119.88 fps
100.00 fps
IPB (Standard) 23 min. 1 hr. 34 min. 6 hr. 19 min. 180 Mbps
1287 MB/min
IPB (Light) 42 min. 2 hr. 50 min. 11 hr. 22 min. 100 Mbps
715 MB/min
50.00 fps
IPB (Standard) 47 min. 3 hr. 9 min. 12 hr. 36 min. 90 Mbps
646 MB/min.
IPB (Light) 1 hr. 24 min. 5 hr. 39 min. 22 hr. 38 min. 50 Mbps
360 MB/min.
29.97 fps
25.00 fps
23.98 fps
IPB (Standard) 1 hr. 34 min. 6 hr. 17 min. 25 hr. 8 min. 45 Mbps
324 MB/min.
IPB (Light) 2 hr. 30 min. 10 hr. 3 min. 40 hr. 15 min. 28 Mbps
202 MB/min.
25.00 fps
ALL-I 31 min. 2 hr. 6 min. 8 hr. 25 min. 135 Mbps
966 MB/min.
31 min.
Card Performance Requirements
Movie Recording Size SD Card
Resolution Frame rate (fps) Compression Method H.264/ MPEG-4 AVC
(Canon Log: OFF, HDR PQ: OFF)
H.264/ MPEG-4 AVC
(Canon Log: ON, HDR PQ: ON)
4K UHD
4K UHD Cropped
59.94 fps
50.00 fps
IPB (Standard) UHS Speed Class 3 or higher Video Speed Class V60 or higher
IPB (Light) UHS Speed Class 3 or higher
29.97 fps
25.00 fps
23.98 fps
IPB (Light) SD Speed Class 10 or higher UHS Speed Class 3 or higher
4K UHD
(Time-lapse movie)
29.97 fps
25.00 fps
ALL-I Read speed of 60 MB/sec. or higher
Full HD
High Frame Rate movies
179.82 fps
150.00 fps
IPB (Light) UHS Speed Class 3 or higher UHS Speed Class 3 or higher
119.88 fps
100.00 fps
Full HD
Full HD cropped
59.94 fps
50.00 fps
IPB (Standard) SD Speed Class 10 or higher UHS Speed Class 3 or higher
IPB (Light) SD Speed Class 6 or higher SD Speed Class 10 or higher
29.97 fps
25.00 fps
23.98 fps
IPB (Standard) SD Speed Class 6 or higher
IPB (Light) SD Speed Class 4 or higher
Full HD
(Time-lapse movie)
29.97 fps
25.00 fps
ALL-I Read speed of 30 MB/s or higher
Video AF Dual Pixel CMOS AF; Movie Servo AF available in AF Menu
ExposureCompensation ±3 stops in 1/3- or 1/2-stop increments
Time Code Yes (Count up, Start time setting, Movie recording count, Movie play count, HDMI time code on/off, HDMI rec. command on/off, Drop frame enable/disable)
Movie Pre-recording (On/Off) 3 or 5 seconds; user-selectable
Time-lapse Movie Setting Interval 2 sec 99:59:59; Number of frames 23,600; Movie recording size 4K/Full HD; Auto exposure fixed @ first frame/auto for each frame; Beep per frame recorded (volume setting 0/silent 5)
Time-lapse Playback Frame Rate 29.97 (set to NTSC); 25.00fps (set to PAL)
Type TFT color, liquid-crystal monitor
Monitor Size 3.0-inch (screen aspect ratio of 3:2) 2.95 in./7.5cm diagonal (2.44 in./6.2cm width, 1.65 in./4.2cm height)
Dots Approx. 1.62 million dots
Coverage Approx. 100% vertically/horizontally
Brightness Control Manually adjustable to one of seven brightness levels
Touch-screen Operation Supported for AF Point selection; Touch AF; Touch Shutter; Menu selection; Quick Control Menu; Magnified view
Coating Clear View LCD II
  • Anti-smudge coating applied.
  • Anti-reflection coating not applied.
Interface Languages 29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, Japanese)
Display Format
Item Still Photo Movie
Magnify zoom display 1.5x10x (15 levels) -
AF point display Yes -
Grid display Off / 3×3 / 6×4 / 3×3+diag -
Zebra display - Yes
False Color display - Yes
Rating OFF / 1 to 5 Stars
Select images / Select range / All images in folder / All images on card / All found images
Image Search Search conditions
Rating / Date / Folder / Protection / Type of file
Protect Select images / Select range / All images in folder / Unprotect all images in folder / All images on card / Unprotect all images on card / All found images
Shooting information display No information display / Basic information display / Detailed shooting information display
Highlight Alert The white areas with no image data will blink.
Histogram Brightness and RGB
Function The Quick Control screen can be accessed by pressing the Quick Control button during shooting, recording, or playback.
Quick Control Screen The following settings are available for the [Quick Control screen] during movie recording.
  • View 1: Conventional Quick Control screen
  • View 2: Cinema EOS-style Quick Control screen
Protection
  1. Single image (select image)
  2. Select range
  3. All images in folder
  4. All images on card
    • Image browsing and image search can be based on ratings.
    • Ratings-based image selections also possible with DPP.
  5. All found images (only during image search)
Erase Except protected images
  1. Select images to erase
  2. Select range
Compatible Printers Not supported
DPOF Compliant to DPOF Version 1.1
Supporting Standards Equivalent to IEEE 802.11 b/g/n/a/ac Standards
Transmission Method DS-SS modulation (IEEE 802.11b)OFDM modulation (IEEE 802.11g/n/a/ac)
Transition Frequency (Central Frequency) 2.4 GHz bandFrequency: 2412 to 2462 MHzChannels: 1 to 11 channels5.0 GHz bandFrequency: 5180 to 5825 MHzChannels: 36 to 165 channels1
Connection Method (1) Camera access point mode(2) Infrastructure mode
Security
Connection Method Authentication Encryption
Encryption Key Format and Length
Camera Access Point WPA2 / WPA3-Personal AES ASCII 8 characters
Open Disable
Infrastructure Open WEP Hexadecimal 10 digits
Hexadecimal 26 digits
ASCII 5 characters
ASCII 13 characters
Disable
Shared key WEP Same as WEP above
WPA / WPA2 / WPA3-Personal TKIP
AES
1127 characters
WPA / WPA2 / WPA3-Enterprise
Communication with a Smartphone
  • Images can be viewed, controlled, and received using a smartphone.
  • Remote control of the camera using a smartphone is possible depending on the Camera Connect specifications.
  • Images can be sent to a smartphone.
  • NFC connection: Not supported
  • Supported images: JPEG, HEIF, RAW/C-RAW, MP4 video files
  • Transcoding while sending: Size to send (original / reduced size); Quality to send (original / compressed)
Remote Operation Using EOS Utility The camera can be controlled via Wi-Fi® or USB, with Canon EOS Utility software installed in a compatible Mac or Windows computer.
Print from Wi-Fi® Printers Not supported.
Send Images to a Web Service image.canon: Video files (MP4) and JPEG, HEIF, RAW or C-RAW still images can be uploaded to image.canon servers.From image.canon, images can be sent to specific social media and 3rd-party cloud image services.
Standards Compliance Bluetooth Specification Version 5.0 compliant (Bluetooth Low Energy technology)
Transmission Method GFSK modulation
Bluetooth Pairing Smartphone up to 10 devices; BR-E1 remote controller 1 unit
Available Functions Dial direction during Tv/Av; Control ring rotation direction; Customize buttons; Customize dials
Custom Controls Customizable Buttons
Shutter button
Movie button
AF-ON button
AE lock button
AF point button
Depth of field preview button
Lens AF stop button
Multi-function button
Set button
Multi-controller
Lens function button
Speedlite menu direct button
Customizable Dials Main dial
Quick control dial 1 & 2
Lens Control ring
My Menu Registration
• Up to six top-tier menu options and Custom Function settings can be registered. • Up to five My Menu tabs can be added.
My Menu tab overall operations Adding a tab
Deleting tabs in a batch
Deleting all tab items
Setting the menu display
My Menu tab detailed operations Selecting a registered item
Sorting registered items
Deleting selected registered items
Deleting registered items in a batch
Deleting tabs
Changing a tab name (16 ASCII characters)
USB Terminal Equivalent to SuperSpeed USB (USB 3.1 Gen 1)
  • For PC communication
  • Terminal type: USB Type-C
  • Shared with terminal for in-camera charging with the USB Power Adapter PD-E1.
  • In-camera Charging: Equivalent to USB type-C (5 V/1.5 A), but use should be restricted to USB Power Adapter PD-E1.
HDMI Out Terminal HDMI micro OUT terminal Type D (Resolution switches automatically) / CEC not compatible
  • Images can be displayed through the HDMI output and on screen at the same time.
  • Images will not be displayed unless [NTSC] or [PAL] is properly set according to the video system of the TV set.
Microphone terminal 3.5mm diameter stereo mini jack
Headphone terminal Compatible with 3.5mm diameter stereo mini-plug
Battery Canon LP-E6NH battery pack (also compatible with LP-E6N and LP-E6 battery packs)
  • With the AC Adapter AC-E6N + DC Coupler DR-E6, AC power is possible.
  • With the USB Power Adapter PD-E1, in-camera charging of LP-E6NH is possible. The USB Power Adapter PD-E1 is not compatible with powering the camera.
Optional Battery Grip Compatible with Canon Battery Grip BG-R10 (Accepts one or two LP-E6NH, LP-E6N, or LP-E6 battery packs)
Battery Check Automatic battery check when the power switch is turned ON. Displayed in 5 levels in viewfinder, and on LCD screen. Battery info display in Set-up Menu:
  • Remaining capacity percentage
  • Shutter count, on current battery charge
  • Recharge performance (battery's ability to hold charge; displayed in 3 levels)
Start-up Time Approx. 0.4 sec.
  • Based on CIPA testing standards.
Dimensions (W x H x D) Approx. 5.45 x 3.87 x 3.48 in. / 138 x 98.4 x 88.4mm Based on CIPA standards.
Weight Approx. 1.5 lbs. / 680g (including battery, SD memory card; without body cap) Approx. 1.3 lbs. / 598g (body only; without battery, card or body cap)
Working Temperature Range 32-104° F / 0-+40° C
Working Humidity
85% or less
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
What is the Stop Motion Animation Service?
We have released a new upgrade service for various EOS R series cameras.
This upgrade enables you to capture Stop Motion Animation.
For more details of the service and compatible camera’s click Learn More.
Pricing
Model Price*
Various EOS R cameras $100
*Tax and shipping fees are NOT included
*All pricing is subject to change Thank you,
Customer Support Operations
Canon U.S.A., Inc.
Contact Information for Inquiries
Canon Customer Support Center
Phone: 1-800-OK-CANON (toll free), 1-800-652-2666
For additional support options: https://www.usa.canon.com/support
Title Firmware Notice: EOS R6 Mark II Firmware Version 1.1.1
Advisory Type Firmware Notice
Date 01.18.23
Title Firmware Notice: EOS R6 Mark II: Firmware Version 1.1.2
Date 05.31.23
Title Firmware Notice: EOS R6 Mark II: Firmware Version 1.4.0.
Date 06.06.24
Title Firmware Notice: EOS R6 Mark II: Firmware Version 1.2.0
Date 09.26.23
Title Service Notice: EOS Webcam Utility Pro v2.3
Advisory Type Service Notice
Date 11.13.24
Title Firmware Notice: EOS R6 Mark II: Firmware Version 1.3.0
Date 12.05.23
Title Service Notice: EOS Webcam Utility Pro Software for macOS: Version 2.1.18
Date 05.01.24
Title Firmware Notice: EOS R6 Mark II: Firmware Version 1.5.0
Date 09.26.24
Title Firmware Notice: EOS R6 Mark II: Firmware Version 1.6.0
Date 07.17.25
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
