Canon Support for EOS R6 + RF24-105mm F4-7.1 IS STM Kit | Canon U.S.A., Inc.
Filter & Sort
Download Type
<p><b>Find Software &amp; Drivers</b></p> <p>Software &amp; drivers are specific to your operating system. Not all software &amp; drivers are compatible with operating systems and versions.</p>
0 of 0
Results will appear after selecting an Operating System and Version above
Date 07.08.21
File Size 6.16 MB
Date 08.21.24
File Size 142.00 B
Date 08.21.24
File Size 142.00 B
Date 08.21.24
File Size 142.00 B
Date 11.01.22
File Size 145.00 B
Type
Digital interchangeable lens, mirrorless camera
Recording Media
(Two) SD card slots
  • Compatible with UHS-II
  • Eye-Fi cards and Multimedia cards (MMC) are not supported.
Compatible Lenses
Canon RF lens group (excluding EF, EF-S and EF-M lenses)
When using Mount Adapter EF-EOS R: Canon EF or EF-S lenses (excluding EF-M lenses)
Lens Mount
Canon RF mount
Type
CMOS sensor (compatible with Dual Pixel CMOS AF)
Effective pixels
Approx. 20.1 megapixels
Screen Size
Approx. 36.0 x 24.0 mm
Pixel Unit
Approx. 6.56 µm square
Total Pixels
Approx. 21.4 megapixels
Aspect Ratio
3:2 (Horizontal:Vertical)
Color Filter System
RGB primary color filters
Low Pass Filter
Installed in front of the image sensor, non-detachable
Dust Deletion Feature
  1. Self Cleaning Sensor Unit
    • Removes dust adhering to the low-pass filter.
    • At power off only / Enable / Disable. Performed automatically (taking about approx. 2 sec. as indicated on the screen) or manually (taking about approx. 8 sec. as indicated on the screen).
    • After manually activated cleaning, the camera will automatically restart (Power OFF to ON).
    • When [Multi Shot Noise Reduction], [Multiple exposures], or [HDR mode] is set, [Clean now] and [Clean manually] cannot be selected.
  2. Dust Delete Data acquisition and appending
    • The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images.
    • The dust coordinate data appended to the image is used by the EOS software to automatically erase the dust spots.
    • Not available with EF-S lenses, in cropped shooting or multi-exposure shooting.
  3. Manual cleaning (by hand)
Recording Format
Compliant to Design rule for Camera File system 2.0 and Exif 2.31*.
*Supports time difference information in Exif 2.31.
Image Format
JPEG, HEIF, RAW / C-RAW (CR3), C-RAW (Canon original) ; Movies: ALL-I (Time-lapse video only), IPB, MP4
File Numbering
The following file numbers can be set:
  1. File numbering methods
    • Continuous numbering
      • The numbering of captured images continues even after you replace the card.
    • Auto reset
      • When you replace the card, the numbering will be reset to start from 0001. If the new SD card already contains images, the numbering will continue from the last recorded image in the card.
  2. Manual reset
    • Resets the file number to 0001, and creates a new folder automatically.
RAW + JPEG / HEIF Simultaneous Recording
Simultaneous recording of any combination of RAW/C-RAW and JPEG/HEIF image-recording quality is supported.
Color Space
Selectable between sRGB and Adobe RGB
Picture Style
  1. Auto
  2. Standard
  3. Portrait
  4. Landscape
  5. Fine Detail
  6. Neutral
  7. Faithful
  8. Monochrome
  9. User Defined 1-3
    • In Scene Intelligent Auto, [Auto] will be set automatically.
    • [Standard] is the default setting for [User Def. 1-3].
Settings
  1. Auto (Ambience priority/White priority)
  2. Day Light
  3. Shade
  4. Cloudy*
  5. Tungsten light
  6. White fluorescent light
  7. Flash
  8. Custom (Custom WB)
  9. Color temperature
* Effective also in twilight and sunset.
Auto White Balance
Option between ambience priority and white priority settings, using SET button
White Balance Shift
Blue/amber bias: ±9 levels
Magenta/green bias: ±9 levels
Corrected in reference to the current WB mode's color temperature.
Type
OLED color electronic viewfinder
Coverage
Approx. 100% vertically and horizontally relative to the shooting image area (with image quality L, at approx. 23mm eyepoint).
Magnification / Angle of View
Approx. 0.76x / Approx. 35.2 degrees (with 50mm lens at infinity, -1 m-1)
Eye Point
Approx. 23mm (at -1 m-1 from the eyepiece lens end)
Viewfinder Information
  1. Maximum burst
  2. Possible shots/Sec. until self-timer shoots
  3. Focus Bracketing/ Multiple-exposure/HDR shooting/Multi Shot Noise Reduction/Bulb time/Interval timer
  4. Shooting mode
  5. AF method
  6. AF operation
  7. Image quality
  8. Card
  9. Drive mode
  10. Metering mode
  11. No. of remaining shots for focus braketing, multiple exposures, or interval timerv
  12. Electronic level
  13. Movie recording time available
  14. Battery level
  15. Image Stabilizer (IS mode)
  16. Histogram (Brightness/RGB)
  17. Quick Control button
  18. Anti-flicker shooting
  19. White balance/White balance correction
  20. Picture style
  21. Auto Lighting Optimizer
  22. Still photo cropping / Aspect ratio
  23. AF point (1-point AF)
  24. AEB/FEB
  25. View Assist
  26. HDR PQ
  27. Flash ready / FE lock / High-speed sync
  28. Electronic shutter
  29. Touch shutter / Create folder
  30. AE lock
  31. Shutter speed / Multi-function lock warning
  32. Aperture value
  33. Wi-Fi function
  34. Wi-Fi signal strength
  35. Bluetooth function
  36. Exposure simulation
  37. Magnify button
  38. ISO speed
  39. Highlight tone priority
  40. Exposure compensation
  41. Exposure level indicator
Focus Method
Dual Pixel CMOS AF
Number of AF zones available for Automatic Selection
AF area: Horizontal: Approx. 100% x Vertical: Approx. 100%
(100% x 100% AF coverage in Face Detect + Tracking AF; coverage can vary, depending upon lens being used)
Stills: Max. 1053 zones (39 x 27)
Movies: Max. 819 zones (39 x21)
Selectable Positions for AF Point AF area: Horizontal: Approx. 90% x Vertical: Approx. 100%
Stills: Max. 6072 positions (92 x 66)
Movies: Max 4968 positions (92 x 54)
AF Working Range
EV -6.5 to 20 (f/1.2 lens*, center AF point, One-Shot AF,at 73°F/23°C, ISO 100
* Except RF lenses with a Defocus Smoothing (DS) coating.
Focusing brightness range (in movie recording)
EV -5 to 20 (f/1.2 lens*, center AF point, One-Shot AF,at 73°F/23°C, ISO 100
Available AF Detection zones
Zone AF
9 x 9
Large Zone AF: Vertica
Max. 9 x 21
Large Zone AF: Horizontal
Max. 31 x 9
Face+Tracking(Auto selection with nothing detected)
Max. 39 x 27
Eye Detection
Auto:
  1. Selects the eye closer to the camera (as detected from the angle of the face).
  2. At the same distance from the camera, selects the eye closer to the center of the image.
Manual:
  1. Can be selected by touch.
  2. Can be selected with the Multi-controller.
Metering Modes
Real-time metering with image sensor (384 [24x16] metering zones)
  1. Evaluative metering (AF point-linked)
  2. Partial metering (approx. 5.8% of the area at the center of the screen)
  3. Spot metering (approx. 2.9% of the area at the center of the screen)
  4. Center-weighted average metering
Metering Range
EV -3 - 20 (at 73°F/23°C, ISO 100)(Still Photo Shooting)
Exposure Modes
  1. Scene Intelligent Auto
  2. Flexible-priority AE (Fv)
  3. Program AE (P)
  4. Shutter-priority AE (Safety shift possible) (Tv)
  5. Aperture-priority AE (Safety shift possible) (Av)
  6. Manual exposure (M)
  7. Bulb
  8. Custom shooting mode C1, C2, C3
Exposure Compensation
User-set ±3 stops in 1/3- or 1/2-stop increments
AEB ±3 stops in 1/3- or 1/2-stop increments
AE Lock
  1. Auto AE lock
    • The metering mode for AE lock after focus can be customized.
  2. User-set AE lock
    • In the Fv, P, Tv, Av and M modes, enabled with the AE lock button. (Press again to update.)
    • Enabled in all metering modes.
Type
Electronically controlled focal-plane shutter
  1. Electronic first curtain
  2. Mechanical shutter
  3. Electronic shutter*
* Cannot be used in conjunction with the following functions: flash photography, HDR shooting, multiple exposures, Multi Shot Noise Reduction, AEB, HDR PQ, anti-flicker shooting, Dual Pixel RAW shooting, Digital Lens Optimizer [High].
* A shutter release sound is not generated. However, note that the sounds other than the shutter release sound (aperture, focusing lens drive sound/electronic sound, etc.) may be generated.
* In electronic shutter shooting under conditions such as flash firing by other cameras or with fluorescent lighting or other flickering light sources, a strip of light or banding due to the brightness difference may be recorded in the image.
Shutter Speeds
When [Mechanical] or [Elec. 1st- curtain] is set: 1/8000-30 sec, bulb
When [Electronic] is set: 1/8000-0.5 sec.
Shutter Release
Soft-touch electromagnetic release
Self Timer
10-sec. delay, 2-sec. delay
Still Photo IS
In-body IS operation can be selected when using a non-IS lens.
  • Always on
  • Only for shot (no stabilization in viewfinder/LCD screen between shots)
E-TTL balance
Ambience priority, standard, flash priority
Flash Exposure Compensation
Continuous flash control
  1. E-TTL each shot
  2. E-TTL locked after first shot in sequence
Shooting Times
Resolution and Frame Rate Mode Approx. shooting time (23°C / 73°F)*1 Recommended scene
4K 60p 94% sensor width
(5.1K oversampling)
30 min Independent films shooting action or with the option of slow motion at high resolution.
APS-C Crop 35 min*2 Independent films shooting action at high resolution with the need for additional reach for sports or wildlife or tighter crops.
4K 30p 94% sensor width
(5.1K oversampling)
40 min*3 General purpose.
*1 Time available for continuous shooting in 23°C / 73°F environment, from a cold start. If the camera is in LV mode standby before shooting or the ambient temperature is high, the shooting time may be shorter.
*2 Recording stops at 7minutes and 30seconds for high frame rate video. Indicates the time when recording can be resumed immediately.
*3 Recording is limited to 29 minutes 59 seconds. Indicates the time when recording can be resumed immediately.
Estimated Camera Recovery Time
Estimated recovery times are indicated below. These are affected by various factors such as ambient temperature, continued camera operation and the selected shooting resolution.The time until full record time is available will vary with ambient temperature.
Resolution and Frame Rate Waiting period (minutes)
(23°C / 73°F)
Approximate maximum recording time after waiting period (minutes)
4K 60p 10 5
Type
TFT color, liquid-crystal monitor
Monitor Size
3.0-inch (screen aspect ratio of 3:2)
2.95 in./7.5cm diagonal (2.44 in./6.2cm width, 1.65 in./4.2cm height)
Dots
Approx. 1.62 million dots
Coverage
Approx. 100% vertically/horizontally
Brightness Control
Manually adjustable to one of seven brightness levels
Touch-screen Operation
Supported for AF Point selection; Touch AF; Touch Shutter; Menu selection; Quick Control Menu; Magnified view
Coating
Clear View LCD II
  • Anti-smudge coating applied.
  • Anti-reflection coating not applied.
Interface Languages
29 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Ukraine, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi, Romanian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Malay, Indonesian, Japanese)
Highlight Alert
The white areas with no image data will blink.
Histogram
Brightness and RGB
Function
The Quick Control screen is accessed by pressing the Quick Control button during still photo shooting.
Protection
  1. Single image (select image)
  2. Select range
  3. All images in folder
  4. All images on card
    • Image browsing and image search can be based on ratings.
    • Ratings-based image selections also possible with DPP.
  5. All found images (only during image search)
Erase
Except protected images
  1. Select images to erase
  2. Select range
Compatible Printers
Not supported
DPOF
Compliant to DPOF Version 1.1
Available Functions
Dial direction during Tv/Av; Control ring rotation direction; Customize buttons; Customize dials
Custom Controls
Customizable Buttons
Shutter button
Movie button
MODE button
AF-ON button
AE lock button
AF point button
Depth of field preview button
Lens AF stop button
Multi-function button
LCD panel illumination button
Set button
Multi-controller
Customizable Dials
Main dial
Quick control dial 1 & 2
Control ring
My Menu Registration
• Up to six top-tier menu options and Custom Function settings can be registered.
• Up to five My Menu tabs can be added.
My Menu tab overall operations
   • Adding a tab
   • Deleting tabs in a batch
   • Deleting all tab items
   • Setting the menu display
My Menu tab detailed operations
   • Selecting a registered item
   • Sorting registered items
   • Deleting selected registered items
   • Deleting registered items in a batch
   • Deleting tabs
   • Changing a tab name (16 ASCII characters)
USB Terminal
Equivalent to SuperSpeed USB (USB 3.1 Gen 1)
  • For PC communication
  • Terminal type: USB Type-C
  • Shared with terminal for in-camera charging with the USB Power Adapter PD-E1.
  • In-camera Charging: Equivalent to USB type-C (5 V/1.5 A), but use should be restricted to USB Power Adapter PD-E1.
HDMI Out Terminal
HDMI micro OUT terminal Type D (Resolution switches automatically) / CEC not compatible
  • Images can be displayed through the HDMI output and on screen at the same time.
  • Images will not be displayed unless [NTSC] or [PAL] is properly set according to the video system of the TV set.
Microphone terminal
3.5mm diameter stereo mini jack
Headphone terminal
Compatible with 3.5mm diameter stereo mini-plug
Battery
Canon LP-E6NH battery pack (also compatible with LP-E6N and LP-E6 battery packs)
  • With the AC Adapter AC-E6N + DC Coupler DR-E6, AC power is possible.
  • With the USB Power Adapter PD-E1, in-camera charging of LP-E6NH is possible. The USB Power Adapter PD-E1 is not compatible with powering the camera.
Optional Battery Grip
Compatible with Canon Battery Grip BG-R10
(Accepts one or two LP-E6NH, LP-E6N, or LP-E6 battery packs)
Battery Check
Automatic battery check when the power switch is turned ON.
Displayed in 5 levels in viewfinder, and on LCD screen.
Battery info display in Set-up Menu:
  • Remaining capacity percentage
  • Shutter count, on current battery charge
  • Recharge performance (battery's ability to hold charge; displayed in 3 levels)
Start-up Time
Approx. 0.4 sec.
  • Based on CIPA testing standards.
Dimensions (W x H x D)
Approx. 5.45 x 3.84 x 3.48 in. / 138 x 97.5 x 88.4mm
Based on CIPA standards.
Weight
Approx. 1.5 lbs. / 680g (including battery, SD memory card; without body cap)
Approx. 1.3 lbs. / 598g (body only; without battery, card or body cap)
Working Temperature Range
32-104° F / 0-+40° C
Working Humidity
85° or less
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
