Canon Support for imageFORMULA DR-C230 Office Document Scanner | Canon U.S.A., Inc.
Language
Type
Our software & drivers for your product are specific to your operations system. We've detected your operating system as {{os}}. If you need software or drivers for a different operating system make sure to select the correct operating system & version with the dropdowns below. Not all our software & drivers are compatible with all operating systems and versions.
of
There are no results for the OS Version you selected.
Date 11.21.18
File Size 2.11 MB
Date 05.14.20
File Size 6.10 MB
Date 02.13.19
File Size 2.16 MB
Date 11.21.18
File Size 4.21 MB
Products Windows 8 Windows 10 Windows 10s Windows 11
Products Big Sur V11.0 Monterey V12.0 Ventura V13.0
Model Name imageFORMULA DR-C230
Type Office Document Scanner
Document Feeding Automatic or Manual
Document Size Width: 2.0" - 8.5"
Length: 2.1" - 14.0"
Long Document Mode Up to 118.1"
Document Weight 7 lb. - 56 lb. Bond Plain Paper
Feeder Capacity Up to 60 Sheets
Grayscale 8-bit
Color 24-bit
Light Source RGB LED
Scanning Element Contact Image Sensor (CMOS)
Scanning Modes Color, Grayscale, Black and White
Optical Resolution Up to 600 dpi
Output Resolution 100/150/200/240/300/400/600 dpi
Scanning Speeds (Simplex/Duplex):* Black and White/Grayscale/Color: Up to 30 ppm/Up to 60 ipm
Interface Hi-Speed USB 2.0
Dimensions (H x W x D) 9.1" x 11.5" x 10.0" (with trays closed)
Weight 6.17 lb.
Power Consumption 19 W or less (Sleep Mode: 1.4 W or less)
Suggested Daily Volume 3,500 scans**
Bundled Software ISIS/TWAIN Driver, CaptureOnTouch, CapturePerfect (windows only), Cardiris (windows only)
Supported Operating Systems Windows 8.1 (32bit/64bit), Windows 10 (32bit/64bit), Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Mac OS 10.13, Mac OS 10.14, Mac OS 10.15
Options Flatbed Scanner Unit 102/201, BarCode Module, 2D Code Module, Exchange Roller Kit (Feed Roller and Retard Roller), Carrier Sheet (Passport), Carrier Sheet (A4), eCarePAK Extended Service
Other Features Auto Color Detection, Auto Page Size Detection, Auto Resolution, Background Smoothing, Deskew, Edge Emphasis, Moiré Reduction, Prevent Bleed-Through/Remove Background, Shadow Cropping, Skip Blank Page, Text Enhancement, Text Orientation Recognition, Three-Dimensional Color Correction, Double-Feed Detection, User Preferences
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
