Canon Support for imageRUNNER 1435iF+ | Canon U.S.A., Inc.
imageRUNNER 1435iF+
Language
Type
Our software & drivers for your product are specific to your operations system. We've detected your operating system as {{os}}. If you need software or drivers for a different operating system make sure to select the correct operating system & version with the dropdowns below. Not all our software & drivers are compatible with all operating systems and versions.
of
There are no results for the OS Version you selected.
image icon
Canon PRINT Business - iOS
Easily print from and scan to your iCloud accounts right from your smartphone or tablet with the Canon PRINT Business app. Available for select imageRUNNER ADVANCE and imageCLASS printers.
image icon
Canon PRINT Business - Android
Easily print from and scan to your Dropbox, Google Drive accounts right from your smartphone or tablet with the Canon PRINT Business app. Available for select imageRUNNER ADVANCE and imageCLASS printers.
imageRUNNER 1435+ Series Brochure
imageRUNNER 1435iF+
MAIN UNIT
TYPEDigital Multifunction Imaging System
CORE FUNCTIONS Print, Copy, Scan, Send, Fax
PROCESSORCanon Dual Custom Processor (Shared)
OPERATION PANEL 5-line LCD
MEMORY RAM 512 MB, Standard USB Port
INTERFACE CONNECTION Network:1000Base-T/100Base-TX/10Base-T
Optional:USB2.0 x1 (Host), USB1.1 x1 (Host),USB (Device)
PAPER SOURCES (LTR, 20LB BOND) Standard:500-sheet Paper Cassette,100-sheet Stack Bypass
Optional:500-sheet CASSETTE MODULE-AC1
Maximum:1,100 Sheets
PAPER OUTPUT CAPACITY (LTR, 20LB BOND) Maximum:100 Sheets
SUPPORTED MEDIA SIZES Cassette:Letter, Legal
Bypass:Letter, Legal, Statement, Executive,Custom size (3" x 5" to 8-1/2" x 14"), Envelope (C5/DL/ COM-10/Monarch)
SUPPORTED MEDIA WEIGHTS Cassette:17 lb. Bond to 24 lb. Bond (64 to 90 g/m2)
Bypass:16 lb. Bond to 34 lb. Bond (60 to 128 g/m2)
COPY SPEED (BW) Up to 37 ppm (Letter);Up to 30 ppm (Legal)
PRINT SPEED (BW) Up to 37 ppm (Letter);Up to 30 ppm (Legal)
WARM-UP TIME From Power On:20 Seconds or Less1
From Sleep Mode:7.8 Seconds or Less
DIMENSIONS (W X D X H) 18-3/4" x 21-1/2" x 18"(475.3 mm x 545 mm x 457 mm)
INSTALLATION SPACE (WXD) 30-3/8" x 18" (772.1 mm x 457 mm)when multipurpose tray is extended
WEIGHT2 Approx. 52.3 lb. (23.74 kg)
PRINT SPECIFICATIONS
FIRST-PRINT-OUT TIME (LTR) As fast as 5 Seconds
PRINT RESOLUTION (dpi) 600 x 600; 1200 x 600 (Enhanced)
STANDARD PAGE DESCRIPTION LANGUAGES UFR II, PCL®5e/6, Adobe® PS® 3
Optional:Barcode Printing Kit
DIRECT PRINT SUPPORT Standard: TIFF, JPEG, PDF
Available from USB, Advanced Box, Remote UI,and Web Access3
OPERATING SYSTEM UFR II LT, PCL 5e/6, Adobe PS 3, Windows®(XP/Windows Vista®/7/8/8.1), Windows Server (2003/2003R2/2008/2008 R2/ 2012/2012 R2),Windows Terminal Server (2003/2003R2/2008/2008 R2/2012/2012 R2), Microsoft ClusteringServer 2003/2003R2/2008/ 2008 R2/2012/2012 R2), Microsoft App-V, Citrix (Presentation Server 4.5, XenApp 5.0/6.0/6.5/7.5, XenDesktop 4.0/5.0/5.5/5.6/7.0/7.1/7.5), VMware (vSphere 4/5/5.1), SAP (PS3, PCL), Macintosh®(OS X 10.5.8 or later) (UFR II LT, PS 3)
PRINT FEATURES Secured Print, Watermark, Page Border, Header/Footer, Page Layout, Two-Sided Printing, Collating, Booklet Printing, Grouping, Printing on Transparencies, Front/Back Covers, Objective, Toner Reduction, Poster Printing
COPY SPECIFICATIONS
FIRST-COPY-OUT TIME (LTR) As fast as 6.9 Seconds (via Platen)
COPY RESOLUTION (dpi) Reading/Printing:Up to 600 x 600
COPY SPECIFICATIONS Automatic or Manual (9 Levels)
MULTIPLE COPIES Up to 999
MAGNIFICATION 25% - 400% (1% Increments) from Platen Glass
PRESET REDUCTIONS 25%, 50%, 64%, 78%
PRESET ENLARGEMENTS 129%, 200%, 400%
BASIC COPY FEATURES Preset R/E Ratios by Area, Two-Sided, Exposure Adjustment, Original Type Selection, Setting Confirmation/Cancel, Standard Keys, Reset, ID Management, Counter Check
SPECIAL COPY FEATURES ID Card Copy, Frame Erase, Mode Memory, Sharpness, Image Combination, Different Size Original
SCAN SPECIFICATIONS
TYPE Duplexing Automatic Document Feeder
DOCUMENT FEEDER PAPER CAPACITY Up to 50 Sheets (20 lb. Bond)
MAXIMUM ORIGINAL SIZE Up to 8-1/2" x 14"
DOCUMENT FEEDER SUPPORTED MEDIA SIZES 5-1/2" x 5" to 8-1/2" x 14"
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHT Simplex:13 lb. to 28 lb. Bond (50 to 105 g/m2)
Duplex:17 lb. to 28 lb. Bond (64 to 105 g/m2)
PLATEN ACCEPTABLE ORIGINALS Sheet, Book, 3-Dimensional ObjectsWeight Up to 4.4 lb. (2 kg)
NETWORK TWAIN SCAN Standard
NETWORK SCAN UTILITY ScanGear MF
SCAN RESOLUTION Up to 600 x 600
SCAN SPEED (LTR) 300 dpi Simplex:Up to 29 ipm (BW)/10 ipm (Color)
Duplex:Up to 10 ipm (BW)/6 ipm (Color)
SEND SPECIFICATIONS
DESTINATION Email, USB, File Server (FTP, SMB)
COLOR MODE Color, BW
SCAN RESOLUTION Color:300 dpi, 200 dpi, 150 dpiBW:300 dpi, 150dpi
ADDRESS BOOK Max. 300 Destinations (Incl. 19 One-Touch Buttons)
COMMUICATION PROTOCOL File:FTP (TCP/IP), SMB (TCP/IP)Email:SMTP, POP3
FILE FORMAT Standard:TIFF, JPEG, PDF, PDF (Compact),PDF (Compact/OCR), PDF (OCR),Encrypted PDF, Digital Signature PDF
UNIVERSAL SEND FEATURES Two Sided Original, Original Type Selection, Density Adjustment, Sharpness, Subject/Message, Reply-to,Email Priority, Senders Name
FAX SPECIFICATIONS
MAXIMUM NUMBER OF CONNECTION LINES One
MODEM SPEED Super G3:33.6 Kbps
G3:14.4 Kbps
COMPRESSION METHOD MH, MR, MMR, JBIG
RESOLUTION 400 x 400, 200 x 400, 200 x 200, 200 x 100
SENDING / RECORDING SIZE Letter, Legal, Statement
FAX FEATURES Job Forwarding, Adjusting Density, Sharpness, Specifying the Sender’s Name, Selecting the Telephone Line Type, Two-Sided Original, TX Archive, Distinctive Ring Detection
STORE SPECIFICATIONS
MEMORY MEDIA Standard: USB
SECURITY SPECIFICATIONS
AUTHENTICATION Standard:Department ID Management, IPv6, Restricting Features (Restricting New Addresses on Address Book, Allow Fax Driver TX, Restrict Recall, Confirm Entered Fax Numbers, Restrict Sequential Broadcast, Restrict USB Interface),Memory Lock, MAC/IP Address Filtering, SMTP Authentication POP Authentication before SMTP, IEEE802.1x, Authentication Feature for Send Operation (AuSend), Secured Print, SNMP v1/v3, SSL Encrypted Communication, Fax Forwarding, Fax Destination Confirmation, USB Block, TLS Support for Email, Fax TX Archive, Encrypted PDF, Digital Signature PDF
Optional:uniFLOW
ENVIRONMENTAL SPECIFICATIONS
POWER REQUIREMENTS 120-127 V, 60 Hz, 7.8 A
PLUG (MAIN UNIT) NEMA 5-15P
POWER CONSUMPTION Maximum:1,500 W
Sleep Mode:2.0 W or Less4
STANDARDS ENERGY STAR® Certified
Rated EPEAT® Silver5
WEEE Directive5
CONSUMABLES
TONER GPR-54 Toner
TONER YIELD (ESTIMATED @ 6% COVERAGE) Black: 17,600 Copies/Case
FOOTNOTES
1 Time from device power-on until copy ready(not print reservation).
2 Includes consumables.
3 PDF print from Web sites is supported.
4 2.0 W sleep mode not available in all circumstancesdue to certain settings.
5 For current EPEAT rating (Gold/Silver/Bronze),please visit www.epeat.net.
Title Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date 05.31.22
Title Service Notice: Google Termination of Support for Google Cloud Print will be ending December 31, 2020.
Advisory Type
Date 12.01.20
ADDITIONAL SUPPORT
image icon
CONTACT US
