Canon Support for imageRUNNER ADVANCE C5560i II | Canon U.S.A., Inc.
Language
Type
Our software & drivers for your product are specific to your operations system. We've detected your operating system as {{os}}. If you need software or drivers for a different operating system make sure to select the correct operating system & version with the dropdowns below. Not all our software & drivers are compatible with all operating systems and versions.
of
There are no results for the OS Version you selected.
image icon
Canon PRINT Business - iOS
Easily print from and scan to your iCloud accounts right from your smartphone or tablet with the Canon PRINT Business app. Available for select imageRUNNER ADVANCE and imageCLASS printers.
image icon
Canon PRINT Business - Android
Easily print from and scan to your Dropbox, Google Drive accounts right from your smartphone or tablet with the Canon PRINT Business app. Available for select imageRUNNER ADVANCE and imageCLASS printers.
imageRUNNER ADVANCE C5500i II Series Spec Sheet
MAIN UNIT
TYPEColor Laser Multifunctional
CORE FUNCTIONSStandard: Print, Copy, Scan, Send, Store
Optional: Fax
PROCESSORCanon Dual Custom Processor (Shared)
CONTROL PANEL10.1" TFT LCD WSVGA Color Flat-panel
MEMORY4.0 GB RAM
HARD DISK DRIVEStandard: 250 GB
Maximum: 1 TB
MIRRORING HARD DISK DRIVEOptional (250 GB, 1 TB)
Method: Raid1
INTERFACE CONNECTIONNetwork: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n)
Others Standard: USB 2.0 x2 (Host), USB 3.0 x1 (Host), USB 2.0 x1 (Device)
Optional: Serial Interface, Copy Control Interface
PAPER CAPACITY (LTR, 20LB BOND)Standard: 1,200 Sheets
Maximum: 6,350 Sheets
PAPER SOURCES (LTR, 20LB BOND)Standard: Dual 550-sheet Paper Cassettes, 100-sheet Stack Bypass
Optional: Dual 550-sheet Paper Cassettes (CASSETTE FEEDING UNIT-AM1), 2,450-sheet High-Capacity Paper Cassette (HIGH CAPACITY CASSETTE FEEDING UNIT-A1), 2,700-sheet Paper Deck (PAPER DECK UNIT-F1)
PAPER OUTPUT CAPACITY (LTR, 20LB BOND)Standard: 250 Sheets
Maximum: 3,450 Sheets (with External Finisher and Copy Tray)
FINISHING CAPABILITIESStandard: Collate, Group
With Inner Finisher: Collate, Group, Offset, Staple, Hole Punch, Staple-Free Staple, Staple On Demand
With External Finishers: Collate, Group, Offset, Staple, Booklet, Hole Punch, Staple-Free Staple, Staple On Demand
SUPPORTED MEDIA TYPESPaper Cassettes (1/2): Thin, Plain, Recycled, Color, Heavy, Pre-punched, Letterhead, Bond, Transparency, Tab, Envelope
Stack Bypass: Thin, Plain, Recycled, Color, Heavy, Pre-punched, Labels, Letterhead, Bond, Coated, Transparency,Tab, Tracing,1 Envelope
SUPPORTED MEDIA SIZESPaper Cassette 1: Letter, Executive, Statement-R, Envelope [No.10 (COM10), DL, ISO-C5], Custom Size (3-7/8" x 5-7/8" to 11-3/4" x 8-1/2")
Paper Cassette 2: 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (3-7/8" x 7-1/8" to 12" x 18")
Stack Bypass: 12" x 18", 11" x 17", Legal, Letter, Letter-R, Executive, Statement, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Envelope Custom Size (3-7/8" x 3-7/8" to 12-5/8" x 18"), Custom Size (3-7/8" x 5-1/2" to 12-5/8" x 18"), Free Size (3-7/8" x 5-1/2" to 12-5/8" x 18")
SUPPORTED MEDIA WEIGHTSCassettes: 14 lb. Bond to 140 lb. Index (52 to 256 g/m2)
Stack Bypass: 14 lb. Bond to 110 lb. Cover (52 to 300 g/m2)
Duplexing: 14 lb. Bond to 80 lb. Cover (52 to 220 g/m2)
WARM-UP TIMEFrom Power On: 10 Seconds2
From Sleep Mode: 10 Seconds
DIMENSIONS (W X D X H)24-3/8" x 29-1/4" x 37-3/8"(620 mm x 742 mm x 950 mm)3
INSTALLATION SPACE (WXD)Basic: Stack Bypass + Cassette drawers open: 37-1/8" x 46-3/8" (943 mm x 1,176 mm)3
WEIGHTApprox. 313.1 lb. (142 kg)4
PRINT SPECIFICATIONS
PRINT / COPY SPEED (BW AND COLOR)Up to 60 ppm (Letter); Up to 36 ppm (Letter-R); Up to 34 ppm (Legal); Up to 32 ppm (11" x 17")
PRINT RESOLUTION1200 dpi x 1200 dpi, 600 dpi x 600 dpi
STANDARD PAGE DESCRIPTION LANGUAGESUFR II, PCL®6, Adobe® PS® 3
DIRECT PRINTAvailable from USB, Advanced Box, Remote UI, and Web Access5
SUPPORTED FILE TYPESPDF, TIFF, JPEG, EPS,6 XPS
PRINTING FROM MOBILE DEVICES AND CLOUD-BASED SERVICESA range of software and MEAP-based solutions are available to provide printing from mobile devices or Internet-connected devices and cloud-based services depending on your requirements.
FONTSPCL fonts: 93 Roman, 10 Bitmap fonts, 2 OCR fonts, Andale Mono WT J/K/S/T (Japanese, Korean, Simplified and Traditional Chinese),7 Barcode Fonts8
PS fonts: 136 Roman
OPERATING SYSTEM9UFRII: Windows Vista®/Server 2008/Windows® 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016, MAC OS X (10.7 or later)
PCL: Windows Vista/Server 2008/Windows 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016
PS: Windows Vista/Server 2008/Windows 7/Server 2008 R2/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016, MAC OS X (10.7 or later)
PRINT FEATURESSuspend Job Timeout, Subset Finishing (PS only), Profile Settings, Secured Print, Forced Hold Printing, Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Toner Reduction, Poster Printing
COPY SPECIFICATIONS
COPY SPEED (BW AND COLOR)Up to 60 ppm (Letter);Up to 36 ppm (Letter-R); Up to 34 ppm (Legal); Up to 32 ppm (11" x 17")
FIRST-COPY-OUT-TIMEAs fast as 2.9 seconds (BW) / 4.5 seconds (Color)
COPY RESOLUTIONReading: 600 dpi x 600 dpi
Printing: 1200 dpi x 1200 dpi
MULTIPLE COPIESUp to 9,999 copies
COPY EXPOSUREAutomatic or Manual (9 Levels)
MAGNIFICATION25%-400% (1% Increments)
PRESET REDUCTIONS25%, 50%, 64%, 73%, 78%
PRESET ENLARGEMENTS121%, 129%, 200%, 400%
BASIC COPY FEATURESPreset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel
SPECIAL COPY FEATURESBook to Two Pages, Two-sided Original, Finishing, Booklet, Job Build, N on 1, Add Cover, Insert Sheets, Different Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Merge Job Blocks, Job Done Notice, Mirror Image, Print on Tab, Store in Mail Box, Superimpose Image, Copy ID Card, Detect Feeder Multi Sheet Feed, Free Size Original, Color Balance, Adjust One-Touch Color, Area Designation
SCAN SPECIFICATIONS
TYPEColor Platen and Single-pass Duplexing Automatic Document Feeder
DOCUMENT FEEDER PAPER CAPACITY150 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZES11" x 17", Legal, Letter, Letter-R, Statement, Statement-R
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS
BW Original: 13 lb. Bond to 58 lb. Cover (50 to 157 g/m2)
CL Original: 17 lb. Bond to 58 lb. Cover (64 to 157 g/m2)
PLATEN ACCEPTABLE ORIGINALSSheet, Book, 3-Dimensional Objects [Up to 4.4 lb. (2 kg)]
PULL SCANColor Network ScanGear2 for both Twain and WIA
Supported OS: Windows Vista/7/8.1/10 Server 2008/Server 2008 R2/Server 2012/Server 2012 R2/Server 2016
SCAN RESOLUTION600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100dpi
SCAN TO MOBILE DEVICES AND CLOUD-BASED SERVICESA range of solutions is available to provide scanning to mobile devices and cloud-based services depending on your requirements.
SCAN SPEED (LETTER)Single-sided Scanning (BW): 80 ipm (300 dpi)/80 ipm (600 dpi)
Single-sided Scanning (Color): 80 ipm (300 dpi)/60 ipm (600 dpi)
Double-sided Scanning (BW): 160 ipm (300 dpi)/150 ipm (600 dpi)
Double-sided Scanning (Color): 160 ipm (300 dpi)/80 ipm (600 dpi)
SEND SPECIFICATIONS
DESTINATIONE-mail/Internet Fax (SMTP), SMB, FTP, WebDAV, Mail Box, Super G3 Fax (Optional), IP Fax (Optional)
COLOR MODEAutomatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-and-White), Full color, Grayscale, and Black-and-White
ADDRESS BOOKLDAP (2,000)/Local (1,600)/Speed dial (200)
SEND RESOLUTION600 x 600 dpi, 400 x 400 dpi, 300 x 300 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 150 x 150 dpi, 100 x 100dpi
COMMUICATION PROTOCOLFile: FTP, SMB, WebDAV E-mail/I-Fax: SMTP, POP3, I-Fax (Simple, Full)
FILE FORMATStandard: TIFF, JPEG, PDF (Encrypted, Compact, Searchable, Apply Policy, Optimize for Web, PDF A/1-b), XPS (Compact, Searchable), Office Open XML (PowerPoint¿, Word, Digital Signature (PDF/XPS) Optional: PDF (Trace & Smooth)
UNIVERSAL SEND FEATURESOriginal Type Selection,Two-sided Original, Book to Two Pages, Different-size Originals, Density Adjustment, Sharpness, Copy Ratio, Erase Frame, Job Build, Direct Send, Delayed Send, Preview, Job Done Notice, File Name, Subject/Message, Reply-to, E-mail Priority, TX Report, Original Content Orientation, Skip Blank Originals, Detect Feeder Multi Sheet Feed
FAX SPECIFICATIONS
MAXIMUM NUMBER OF LINES
MODEM SPEEDSuper G3: 33.6 kbps G3: 14.4 kbps
COMPRESSION METHODMH, MR, MMR, JBIG
RESOLUTION400 x 400 dpi, 200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi
SENDING / RECORDING SIZEStatement-R to 11" x 17"
FAX MEMORYUp to 30,000 pages
SPEED DIALSMax. 200
GROUP DIALS / DESTINATIONSMax. 199 dials
SEQUENTIAL BROADCASTMax. 256 addresses
MEMORY BACKUPYes
FAX FEATURESOriginal Type Selection, Two-sided Original, Book to Two Pages, Different-size Originals, Density for Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying the Sender's Name (when sending fax), Sender's Name (TTI), Select Line, Selecting the Telephone Line (when sending fax), Direct Send, Delayed Send, Preview, Job Done Notice, TX Report, Detect Feeder Multi Sheet Feed
STORE SPECIFICATIONS
MAIL BOX SIMPLE(NUMBER SUPPORTED)100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes, 30,000 Maximum Pages Stored
ADVANCED BOXCommunication Protocol: SMB or WebDAV
Supported Client PC: Windows (Windows Vista/7/8/8.1/10)
Concurrent Connections (Max.)
SMB: 64
WebDAV: 3 (Active Sessions)
ADVANCED BOX AVAILABLE DISC SPACEApprox. 16 GB (Standard HDD)
Approx. 480 GB (1 TB HDD)
ADVANCED BOX FEATURESDisabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support
MEMORY MEDIAStandard: USB
SECURITY SPECIFICATIONS
AUTHENTICATIONStandard: Universal Login Manager, uniFLOW Online Express,10,11 User Authentication, Department ID Authentication, Access Management System, Device and Function Level Log-in Optional: uniFLOW
DATAStandard: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption(FIPS140-2 Validated) Optional: Hard Disk Drive Mirroring, Hard Disk Drive removal, IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires uniFLOW)
NETWORKStandard: Encrypted Secure Print, IP/Mac Address Filtering, IPsec, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP
DOCUMENTStandard: Secure Watermark, Encrypted PDF, Encrypted Secure Print, Digital Signatures, Adobe LiveCycle¿ Rights Management ES2.5 Integration Optional: User Signatures, Document Scan Locking
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENTTemperature: 50 to 86 ºF
Humidity: 20 to 80 % RH (no condensation)
POWER REQUIREMENTS120-127V AC 60 Hz,11.5 A
PLUG (MAIN UNIT)NEMA 5-20P
POWER CONSUMPTIONMaximum: Approx. 1.8 kWh
Standby: Approx. 66.2 W
Sleep Mode: Approx. 0.8 W12
Typical Electricity Consumption (TEC) Rating: 3.2 kWh
STANDARDSENERGY STAR® Certified Rated EPEAT® Gold13 RoHS Compliant
CONSUMABLES
TONERGPR-55 Toner14
TONER YIELD (ESTIMATED @ 5% COVERAGE)Black: 69,000 Images
Color (C,M,Y):14 60,000 Images
FOOTNOTES
1 Some types of tracing paper cannot be used.
2 Time from device power-on to when copy jobs can be programmed with Quick Start Up mode.
3 Includes main unit and either Cassette Feeding Unit-AM1, High Capacity Cassette Feeding Unit-A1, or Cabinet Type-N.
4 Includes main unit, consumables, and Cassette Feeding Unit-AM1.
5 PDF print from Web sites is supported.
6 EPS can be printed directly only from the Remote User Interface.
7 Requires the optional PCL International Font Set-A1.
8 Requires the optional Barcode Printer Kit-D1.
9 Other operating systems and environments including AS/400, UNIX, Linux and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
10 No charge for this solution; however activation is required.
11 Check for availability.
12 0.8 W sleep mode not available in all circumstances due to certain settings.
13 For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
14 GPR-55L Toner also available for Color (C, M, Y). Yield (estimated @ 5% coverage) is 26,000 images.
Title Notice of potential vulnerability in RSA key generation
Advisory Type
Date 04.04.22
Title Service Notice: Google Termination of Support for Google Cloud Print will be ending December 31, 2020.
Advisory Type
Date 12.01.20
ADDITIONAL SUPPORT
image icon
CONTACT US
