Canon Support for IX-R7000 ID Card & Badge Printer | Canon U.S.A., Inc.
Language
Type
Our software & drivers for your product are specific to your operations system. We've detected your operating system as {{os}}. If you need software or drivers for a different operating system make sure to select the correct operating system & version with the dropdowns below. Not all our software & drivers are compatible with all operating systems and versions.
of
There are no results for the OS Version you selected.
Date 12.21.21
File Size 6.22 MB
Date 06.25.19
File Size 2.09 MB
Date 10.01.21
File Size 6.01 MB
Date 07.25.22
File Size 5.76 MB
Printer
Printing Method Dye-Sublimation / Retransfer
Print Speed (up to) Single Sided: 1
Approx. 25 Seconds/Card (YMCK)
Max. Print Speed 145 Cards Per Hour (YMCK)
Dual Sided: 1
Approx. 50 Seconds/Card (YMCKK)
Max. Print Speed 72 Cards Per Hour (YMCKK)
Print Resolution (Up to) 600 x 600 dpi
Paper Sizes Card Size
CR-80 Size (2.1" x 3.4" / 54 x 86.5 mm)2
Maximum Printable Area Width: 54 mm
Length: 86.5 mm
Paper Thickness Card Thickness
30 mil - 39.3 mil (0.76 - 1.0 mm)2
Paper Compatibility Card Types
PVC Plastic Cards
Body Durability 100,000 Cards / 5 Years1
Paper Handling Hopper Capacity
250 Cards (30 mil (0.76 mm) Thickness/Card)2
General
OS Compatibility Windows 10 (64/32 bit), 8.1 (64/32 bit), 7 SP1 (64/32 bit), Server 2008 R2 (64 bit)3
Standard Interface USB 2.0
Ethernet (10/100/1000Base-T)
RS-232C
Power Source AC 100-240V, 50/60Hz
Power Consumption (approx.) Maximum: Approx. 300 W
Dimension (W x D x H) 11.7" (W) x 13.4" (D) x 17.2" (H)
Weight 42.8 lbs.
Operating Temperature: Temperature: 50° - 95°F (10° - 35°C)
Operating Humidity: Humidity: 20-80% RH (Non-Condensing)
Noise Acoustic Information
Operating Noise (Max.): 58dB or less4
Standby Noise: 35dB or less4
Warranty 2 Year Warranty5
Color/Monochrome Full Color or Monochrome Printing
Print Modes Single Sided (Simplex) / Dual Sided (Duplex)
Removable Card Hopper Yes
Consumable Types Ink Ribbons: IXR-YMCKK / IXR-YMCK
Retransfer Film: IXR-RFILM
Print Mode Detail Single Sided (Simplex): Color / Monochrome
Dual Sided (Duplex): Side 1: Color (YMCK) / Side 2: Monochrome (YMCKK)
Print Yields IXR-YMCK: 500 Cards (Single Sided: Color1)
IXR-YMCKK: 400 Cards (Double Sided: 1st Side Color, 2nd Side Monochrome)1
IXR-Film (Transfer Film): 500 Cards (Single Sided)1
Operational Method LCD: Yes (2 Line LCD - 16 Character)
Buttons/LEDs: 4 Buttons / 1 LEDs
Anti-Theft Wire Lock Security Slot Built-in
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
