Canon Support for IX-R7000 ID Card & Badge Printer | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 08.01.23
File Size 5.97 MB
Date 12.18.24
File Size 7.41 MB
Date 03.07.23
File Size 1.83 MB
Date 08.08.24
File Size 7.64 MB
Date 05.01.26
File Size 7.49 MB
Printer
Printing Method Dye-Sublimation / Retransfer
Print Speed (up to) Single Sided: Footnote1
Approx. 25 Seconds/Card (YMCK)
Max. Print Speed 145 Cards Per Hour (YMCK)
Dual Sided: Footnote1
Approx. 50 Seconds/Card (YMCKK)
Max. Print Speed 72 Cards Per Hour (YMCKK)
Print Resolution (Up to) 600 x 600 dpi
Card Sizes Card Size
CR-80 Size (2.1" x 3.4" / 54 x 86.5 mm)Footnote2
Maximum Printable Area Width: 54 mm
Length: 86.5 mm
Card Thickness Card Thickness
30 mil - 39.3 mil (0.76 - 1.0 mm)Footnote2
Card Compatibility Card Types
PVC Plastic Cards
Body Durability 100,000 Cards / 5 YearsFootnote1
Card Capacity Hopper Capacity
250 Cards (30 mil (0.76 mm) Thickness/Card)Footnote2
General
OS Compatibility Windows 10, 11 (64/32 bit), 8.1 (64/32 bit), 7 SP1 (64/32 bit), Server 2008 R2 (64 bit)Footnote3
Standard Interface USB 2.0
Ethernet (10/100/1000Base-T)
RS-232C
Power Source AC 100-240V, 50/60Hz
Power Consumption (approx.) Maximum: Approx. 300 W
Dimension (W x D x H) 11.7" (W) x 13.4" (D) x 17.2" (H)
Weight 42.8 lbs.
Operating Temperature: Temperature: 50° - 95°F (10° - 35°C)
Operating Humidity: Humidity: 20-80% RH (Non-Condensing)
Noise Acoustic Information
Operating Noise (Max.): 58dB or lessFootnote4
Standby Noise: 35dB or lessFootnote4
Warranty 2 Year WarrantyFootnote5
Color/Monochrome Full Color or Monochrome Printing
Print Modes Single Sided (Simplex) / Dual Sided (Duplex)
Removable Card Hopper Yes
Consumable Types Ink Ribbons: IXR-YMCKK or IXR-YMCK
Retransfer Film: IXR-RFILM
Print Mode Detail Single Sided (Simplex): Color / Monochrome
Dual Sided (Duplex): Side 1: Color (YMCK) / Side 2: Monochrome (YMCKK)
Print Yields IXR-YMCK: 500 Cards (Single Sided: ColorFootnote1)
IXR-YMCKK: 400 Cards (Double Sided: 1st Side Color, 2nd Side Monochrome)Footnote1
IXR-Film (Transfer Film): 500 Cards (Single Sided)Footnote1
Operational Method LCD: Yes (2 Line LCD - 16 Character)
Buttons/LEDs: 4 Buttons / 1 LEDs
Anti-Theft Wire Lock Security Slot Built-in
CANON IX-R7000 THERMAL ID CARD PRINTER LIMITED WARRANTY
The limited warranty set forth below is given by Canon U.S.A., Inc. ("Canon") with respect to the Canon IX-R7000 Thermal ID Card Printer packaged with this limited warranty and Canon branded accessories and options designed for use with the Canon IX-R7000 Thermal ID Card Printer (collectively, the "Product"). Canon warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of two (2) years after delivery to the original purchaser (“Purchaser”) by Canon or its authorized dealer. During the relevant warranty period, Canon shall, in its sole discretion and without charge, repair or replace any defective part with a new or comparable rebuilt part or replace the Product with a new or rebuilt Product. Warranty replacement shall not extend the warranty period of the defective Product. Nor shall this warranty cover other consumable parts or consumables, such as paper, Ink ribbons, and Transfer films, as to which there shall be no warranty or replacement.
  • Your local Service Provider; or call
  • 1-855-852-2666, Monday through Friday from 8 a.m. to 8 p.m. ET
You must cooperate with Canon in remotely diagnosing the Product’s malfunction. Canon may attempt to correct the malfunction remotely, with your assistance. If Canon cannot fix your Product’s malfunction through remote diagnostics, Canon shall schedule an on-site service call by an independent authorized Canon Service Provider (the "Service Provider") or Canon will send you a replacement part for any defective user replaceable item. You will be charged at the then-current service call rates of Canon or the Service Provider if the defects in the Product are not covered by this limited warranty, or if the applicable warranty period for the Product has expired or warranty coverage has not been sufficiently established by appropriate documentation.
This warranty shall only apply if this Product is used in conjunction with compatible computers, peripheral equipment and software, as to which items Canon shall have no responsibility. NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
THIS WARRANTY SHALL BE VOID AND OF NO FORCE AND EFFECT IF THE PRODUCT IS DAMAGED AS A RESULT OF (A) ABUSE, NEGLECT, MISHANDLING, ALTERATION, ELECTRIC CURRENT FLUCTUATION OR ACCIDENT, (B) IMPROPER USE, INCLUDING FAILURE TO FOLLOW OPERATING OR MAINTENANCE INSTRUCTIONS IN, OR ENVIRONMENTAL CONDITIONS PRESCRIBED IN, CANON’S USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT, (C) REPAIR BY OTHER THAN SERVICE REPRESENTATIVES QUALIFIED BY CANON WHO ARE ACTING IN ACCORDANCE WITH CANON’S SERVICE BULLETINS (D) USE OF SUPPLIES OR PARTS (OTHER THAN THOSE DISTRIBUTED BY CANON) INCLUDING NON-CANON INK RIBBONS AND TRANSFER FILMS, WHICH DAMAGE THE PRODUCT OR CAUSE ABNORMALLY FREQUENT SERVICE CALLS OR SERVICE PROBLEMS OR (E) USE OF THE PRODUCT WITH NON-COMPATIBLE COMPUTERS, PERIPHERAL EQUIPMENT OR SOFTWARE, INCLUDING THE USE OF THE PRODUCT IN ANY SYSTEM CONFIGURATION NOT RECOMMENDED IN ANY USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT. NOR DOES THIS WARRANTY EXTEND TO ANY PRODUCT ON WHICH THE ORIGINAL IDENTIFICATION MARKS OR SERIAL NUMBERS HAVE BEEN DEFACED, REMOVED, OR ALTERED.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE MEDIA ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD “AS IS” AND WITHOUT WARRANTY BY CANON. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
CONDITIONS OF WARRANTY
Canon U.S.A., Inc.
One Canon Park
Melville, NY 11747
USA
Canon is a registered trademark of Canon Inc.
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
