Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Type Inkjet Label Printer
Print Method Dye-based Inkjet
Ink Cartridges 4 (1 x Black, 1 x Cyan, 1 x Magenta, 1 x Yellow)
Print Resolution 1200 x 1200 dpi
Number of Nozzles 5184 dots
Supported Media Types Label Roll Media (with Roll Holder) & Label Fanfold Media (IJ Coated: Matte or Glossy)
Roll Media Capacity Outer Diameter: Up to 7.9 inch (200mm), Core/Inner Diameter: 3.0 inch ± 0.04inch (76.2±1.0mm), Weight: Up to 7.1lbs(3.2kg)
Ink Cartridge Fill Volume Black / Cyan / Magenta / Yellow: 8.1oz (240ml)
Maintenance Cartridge WT-X404 Maintenance Cartridge
Control Panel 4.3 inch full color touch LCD
Connectivity / Interface USB2.0 Hi-speed, USB2.0 typeB, 1000BASE-T/100BASE-TX/10BASE-T, RS-232C and External I/O (For External Devices)
Supported OS Windows 11, Windows Server 2016,2019,2022,2025Footnote2
Operating Environment Temperature 41° - 95°F (5° - 35°C)
Operating Environment Humidity 10 - 90% RH (Non-Condensing)
Chemical Safety TSCA, OSHA HCS
Power Consumption Approx. 230W (max. with RFID unit), approx. 87W (operating, average), approx. 24W (standby, average), approx. 5W (sleep mode, average), 0.3W or less(power off, average)
Electrical AC 100-240V, 50/60Hz
Max. Operating Noise 55dB or lessFootnote3
Standby Noise 35dB or lessFootnote3
Warranty 1 Year Warranty including PrintheadFootnote4
Dimensions 15.2(W) x 22.2(D) x 16.9(H) (386mm(W) x 565mm(D) x 430mm(H))
Weight 48.9lbs. (22.2kg) *excluding printhead and ink tanks
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
