Canon Support for RF 24-70mm F2.8L IS USM | Canon U.S.A., Inc.
Language
Type
Our software & drivers for your product are specific to your operations system. We've detected your operating system as {{os}}. If you need software or drivers for a different operating system make sure to select the correct operating system & version with the dropdowns below. Not all our software & drivers are compatible with all operating systems and versions.
of
There are no results for the OS Version you selected.
Date 09.10.19
File Size 757.53 KB
Focal Length & Maximum Aperture 24-70mm f/2.8
Minimum Focusing Distance Wide: 0.69 ft./0.21m
Telephoto: 1.25 ft./0.38m
Maximum Magnification 0.3x (at 32mm)
Lens Construction 21 elements in 15 groups
Special Elements 3 Aspherical lenses, 3 UD lenses
Filter Size Diameter Ø82 mm
Aperture Blades 9 (circular)
IS (CIPA Standard Correction Effect) 5 stops* (When using the EOS R camera with a 70mm focal length.)
Focus Drive System Nano USM
Minimum Overall Length Approx. 4.95 in. / 125.7 mm
Maximum Diameter Approx. Ø3.48 in. / Ø88.5 mm
Weight Approx. 1.98 lbs. / 900 g
Title Firmware Update: RF 24-70mm F2.8 L IS USM: Firmware Version 1.0.4
Advisory Type
Date 12.04.19
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
