Canon Support for RF100mm F2.8 L MACRO IS USM | Canon U.S.A., Inc.
Date 11.16.21
File Size 1.25 MB
Focal Length 100mm
Maximum and Minimum Aperture F2.8-32
Lens Mount Type RF Mount Canon RF mount; Exclusively for Canon EOS R-series cameras
Minimum Focusing Distance 0.86 ft. (10.2 in.) /0.26 m.
Maximum Magnification 1.4x (Fills frame with subject 1.0 x 0.67 inches / 25 x 17mm in size)
Angle of View Diagonal: 24°00
Lens Construction 17 elements in 13 groups
SA (Spherical Aberration) Control Provided
Special Elements N/A
Lens Coating Super Spectra Coating; Fluorine coating on front element
Filter Size Diameter Ø67 mm
Aperture Blades 9
Dust/Water Resistance Supported (Rubber Ring on lens mount, Focus Ring, Control Ring, SA Control Ring, switch panel and switches)
IS Mode Selection None; Automatic detection and correction for panning
Image Stabilization CIPA standard: 5 stops (Using an EOS R)
Shake Correction with coordinated Optical Image Stabilizer and In-Body Image Stabilization. Supported. 8 Stops (Using an EOS R5); Hybrid IS during close-focus operation
Maximum Outer Diameter x Length Approx. 3.21 in x 5.83 in. / 81.5mm x 148mm
Weight Approx. 1.6 lbs. (25.8 oz) / 730g
Lens hood ET-73C (Bundled)
Lens Cap E-67II (bundled)
Dust Cap Lens Dust Cap RF (Bundled)
Lens Case Lens Pouch LP1222 (Bundled)
Tripod Mount Tripod Mount Ring E(B) with adapter (Optional accessory, sold separately)
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
