Canon Support for RF5.2mm F2.8 L Dual Fisheye | Canon U.S.A., Inc.
Language
Type
Our software & drivers for your product are specific to your operations system. We've detected your operating system as {{os}}. If you need software or drivers for a different operating system make sure to select the correct operating system & version with the dropdowns below. Not all our software & drivers are compatible with all operating systems and versions.
of
There are no results for the OS Version you selected.
Date 12.20.21
File Size 142.00 B
Date 12.20.21
File Size 142.00 B
Date 12.20.21
File Size 142.00 B
Focal Length 5.2mm
Maximum and Minimum Aperture f/2.8 f/16 (1/3 stops, 1/2 stops)
Lens Mount Type Canon RF Mount; Metal Mount
Interpupillary Distance / Baseline Length (Distance between Left and Right Lens Centers) 60mm
Minimum Focusing Distance 0.66 ft. (7.9 in.) / 0.2 m
Maximum Magnification 0.03x
Angle of View (Diagonal) 190° 00'
Lens Construction (each lens) 12 elements in 10 groups
Special Elements (each lens) Two UD glass elements
Lens Coating Canon SSC (Super Spectra Coating)
Canon SWC (Sub-wavelength Structure Coating)
Fluorine Coating on front surface of front element
Filter Size Diameter Supported Built-in
Aperture Blades (each lens) 7
Lens Switches None
Dust/Water Resistance Provided (rubber ring on lens mount)
Focusing System Manual focusing
Left/right focus difference adjustment User-adjustable, via adjustment dial (using included 1.5mm hexagonal wrench)
Dual Pixel CMOS AF Not Supported Manual focus only
Focus Guide Supported Alternate at image center of either selected lens UI by INFO button with cameras equipped with compatible firmware.
Manual Focus Peaking Supported with compatible cameras.
Full-time Manual Focusing Not Supported
Control Ring Not Supported
IS Mode Selection Not Supported
Optical Image Stabilization Not Supported
Dimensions (width x height x length) 4.8 x 3.3 x 2.1 in. (121.1 x 83.6 x 53.5mm)
Weight Approx. 12.4 oz. (350g)
Lens hood Not Supported
Lens Cap Dedicated Canon Lens Cap 5.2 (Center pinch type; bundled)
Dust Cap Canon Lens Dust Cap RF
Lens Case Canon Lens Case LS1014 (bundled)
RF Tele Extenders Not Compatible
EF Extension Tubes Not Compatible
Close-up Lenses Not Compatible
Canon Gelatin Filter Holder IV Not compatible; Built-in gelatin filter holder at rear of lens
Left/right focus difference adjustment Hexagonal Wrench Bundled 1.5mm hexagon wrench
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
