Canon Support for SL118-55 | Canon U.S.A., Inc.
SL118-55
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 04.03.13
File Size 11.16 MB
Date 04.03.13
File Size 11.75 MB
Date 05.30.16
File Size 6.84 MB
Date 04.02.25
File Size 142.00 B
Date 04.02.25
File Size 142.00 B
Date 03.26.13
File Size 3.12 MB
Date 07.19.16
File Size 32.39 MB
Date 07.19.16
File Size 15.41 MB
Camera Connect
Camera Connect
image.canon
image.canon
Software Development Kit
Type
CMOS Sensor
Pixels
Effective pixels: Approx. 18.0 megapixels
Pixel Unit
4.3 &micro;m square
Total Pixels
Total pixels: Approx. 18.50 megapixels: 5288 (H) x 3506 (V) pixels
Aspect Ratio
3:2 (Horizontal : Vertical)
Color Filter System
RGB primary color filters
Low Pass Filter
Fixed position in front of the image sensor
Dust Deletion Feature
(1) Self Cleaning Sensor Unit
Removes dust adhering to the low-pass filter.
Self-cleaning executed automatically (taking approx. 2 sec.) when power is turned on or off. Manual execution also possible (taking approx. 5 sec.).
(2) Dust Delete Data acquisition and appending
The coordinates of the dust adhering to the low-pass filter are detected by a test shot and appended to subsequent images.
The dust coordinate data appended to the image is used by the provided software to automatically erase the dust spots.
(3) Manual cleaning
Recording Format
Complies with Design rule for Camera File system 2.0 and Exif 2.30
File Size
(1)Large: Approx. 17.90 Megapixels (5,184 x 3,456)
(2)Medium: Approx. 8.00 Megapixels (3,456 x 2,304)
(3)Small 1: Approx. 4.50 Megapixels (2,592 x 1,728)
(4)Small 2: Approx. 2.50 Megapixels (1920 x 1280)
(5)Small 3: Approx. 0.35 megapixels (720 x 480)
(6)RAW: Approx. 17.90 Megapixels (5,184 x 3,456)
Backup Recording
N/A
File Numbering
The following three types of file numbering methods can be set:
(1) Continuous numbering
* The numbering of captured images will continue even after you replace the camera's card.
(2) Auto reset
* When you replace the camera's card, the numbering will be reset to start from 0001. If the new card already contains images, the numbering will continue from the last recorded image in the card.
(3) Manual reset
* Resets the file number to 0001, and creates a new folder automatically.
RAW + JPEG Simultaneous Recording
Still: JPEG, RAW (Canon RAW 2nd edition), RAW+JPEG
Video: MOV (Image data: H.264, Audio: Linear PCM)
Color Space
sRGB, Adobe RGB
Picture Style
Auto, Standard, Portrait, Landscape, Neutral, Faithful, Monochrome, User Defined 1-3
Settings
Auto, Preset (Daylight; Shade; Cloudy, Twilight, Sunset; Tungsten Light; White Fluorescent Light; Flash), Custom (Approx. 2,000&deg; - 10,000&deg;K), White Balance Correction, and White Balance Bracketing
Auto White Balance
Auto white balance with the image sensor
Color Temperature Compensation
White balance correction:Blue/amber bias: &plusmn;9 levelsMagenta/green bias: &plusmn;9 levels* Correction based on the current WB mode's color temperature.
Color Temperature Information Transmission
Provided
Type
Eye-level SLR (with fixed pentamirror)
Coverage
Approx. 95% vertically and horizontally (with Eye point approx. 19mm)
Magnification
Approx. 0.87x / 24.5&deg; (50mm lens &infin;, -1m-1)
Eye Point
Approx. 19 mm (At -1m-1 from the eyepiece lens center)
Dioptric Adjustment Correction
-3.0 to +1.0 m-1 (dpt)
Focusing Screen
Fixed
Mirror
Quick-return half mirror (transmission: reflection ratio of 40:60)
Viewfinder Information
1) AF information (AF points and focus confirmation light)
2) Exposure information (Shutter speed, aperture, ISO speed (always displayed), AE lock, exposure level, spot metering circle, exposure warning)
3) Flash information (Flash ready, flash exposure compensation, high-speed sync, FE lock, red-eye reduction light)
4) Image information (Highlight tone priority (D+), maximum burst (1-digit display), white balance correction, SD card information)
Depth Of Field Preview
Enabled with depth-of-field preview button
Type
TTL secondary image-forming, phase-difference detection
AF Points
9 points (Center AF point is AF cross-type at f/5.6, Center AF point is vertical line-sensitive at f/2.8.)
AF Working Range
Center AF point: EV -0.5 - 18
Other AF points: EV 0.5 - 18
(At room temperature and ISO 100, based on Canon's testing standards)
Focusing Modes
(1) Autofocus
One-Shot AF
Predictive AI Servo AF
AI Focus AF (*Switches between One-Shot AF and AI Servo AF
* Automatically set to One-Shot AF when the drive mode is set to Silent Single Shooting or Silent Continuous Shooting. (AI Servo AF and AI Focus AF cannot be selected.)
(2) Manual focus (MF)
AF Point Selection
(1) Manual selection
(2) Auto selection
* Automatically set in Basic Zone modes.
Selected AF Point Display
Indicated by superimposed display in the viewfinder and on the LCD monitor
AF Assist Beam
(1) Intermittent firing of built-in flash
(2) Effective range: Approx. 13.1 ft./4 m. at center, approx. 11.5 ft /3.5 m. at periphery
* With an EOS-dedicated Speedlite attached, the Speedlite's AF-assist beam is emitted instead.
* Compatible with AF assist-beam (intermittent firing) of 320EX, 270EX II, and 270EX flashes.
Metering Modes
TTL maximum aperture metering with 63-zone metering sensor:
1)Evaluative metering (linked to all AF points)
2)Partial metering (center, approx. 9% of viewfinder)
3)Spot metering (center, approx. 4% of viewfinder)
4)Center-weighted average metering
Metering Range
EV 1.0 - EV 20.0 (at 73&deg;F/23&deg;C with 50mm f/1.8 II lens at ISO 100)
Exposure Control Systems
Creative Zone
(1) Program AE (shiftable)
(2) Shutter-priority AE
(3) Aperture-priority AE
(4) Manual exposure (including bulb)Basic zone
(1) Scene Intelligent Auto (Program AE / non-shiftable)
(2) Flash Off
(3) Creative Auto
* Effect shots cannot be set simultaneously with Ambience-based shots or background blurring. Neither can continuous shooting or 2 to 10 shots after 10-sec self-timer be used with Effect shot.
* When background blurring is set, shooting with flash is disabled. When the flash is raised, background blurring cannot be set.
(4) Portrait
(5) Landscape
(6) Close-up
(7) Sports
(8) Special scene
- Kids
- Food
- Candlelight
- Night Portrait
- Handheld Night Scene
- HDR Backlight Control mode
ISO Speed Range
For Stills:
1.Manual setting range of ISO 100-12800, expansion to ISO 25600
2.Auto, ISO 100-6400 (in whole-stop increments)
- In Creative Zone modes, the maximum ISO speed (ISO 400, 800, 1600, 3200, or 6400) for ISO Auto can be set.
- With Highlight Tone Priority, ISO 200 or higher will be set.
*1: Fixed at ISO 400 for Bulb exposures.*2: Depends on the maximum ISO speed that has been set.*3: If fill-flash will result in overexposure, the ISO speed can be set as low as ISO 100.*3: Scene Intelligent Auto, Night Portrait and Handheld Night Scene modes are excluded.*4: Not applicable to Auto, Kids, Night Portrait, or Handheld Night Scene.*5: If you use bounce flash with an external Speedlite in the Creative Auto, Portrait, Landscape, Close-up, Sports, Food, Candlelight and P modes, the ISO speed is set automatically within ISO 400&#150;1600 (or up to the maximum limit) to match the brightness.
Exposure Compensation
Manual: &plusmn;5 stops in 1/3- or 1/2-stop increments
AEB : &plusmn;2 stops in 1/3- or 1/2-stop increments
* If the exposure compensation exceeds &plusmn;2 stops, the left or right icon appears in the viewfinder.
* Manual exposure compensation and AEB can be set in combination.
* AEB is set in the following sequence: Standard exposure, decreased exposure, and increased exposure.
* If AEB is used with the self-timer, the three bracketed shots will be taken in succession after the 10-sec. or 2-sec. delay.
AE Lock
(1) Auto AE lock
* In the One-Shot AF mode with evaluative metering, AE lock takes effect when focus is achieved.
(2) Manual AE lock
* In the P, Tv, Av, and M modes, enabled with the AE lock button. (Press again to update.)
* Enabled in all metering modes.
Type
Vertical-travel, mechanical, focal-plane shutter with all speeds electronically-controlled
* Electronic 1st curtain and mechanical 2nd curtain
Shutter Speeds
1/4000 to 30 sec. (total shutter speed range; available range varies by shooting mode), bulb, X-sync at 1/200 sec.
* Settable in 1/3- or 1/2-stop increments.
Shutter Release
Soft-touch electromagnetic release
Self Timer
Shutter Lag Time
(1) During SW-1 ON, time lag between SW-2 ON and start of exposure: approx. 0.075 sec.
* Approx. 0.168 seconds in case of silent shooting.
(2) Time lag between simultaneous SW-1/SW-2 ON and start of exposure: Approx. 0.150 sec.
* Approx. 0.242 seconds in case of silent shooting.
* Time lag with the aperture stopped down by 3 stops or less (Excludes AF operation time).
Flash Metering
E-TTL II autoflash (evaluative flash metering and average flash metering), FE Lock
Flash Exposure Compensation
&plusmn;2 stops in 1/3-stop or 1/2-stop increments
FE Lock
Provided
External Flash Settings
(1) External flash function setting
* Flash firing, E-TTL II auto flash system, flash mode, wireless master, zoom, sync setting, flash exposure compensation, FEB, and clear setting.
* With the 600EX-RT, radio wireless transmission control is possible.
(2) External flash C.Fn setting
* The actual setting options for (1) and (2) will differ depending on the Speedlite used.
PC Terminal
Not Provided
Drive Modes
(1) Single shooting
(2) Continuous shooting
(3) Silent single shooting
(4) Silent continuous shooting
* Single silent shooting and continuous silent shooting are not possible when Basic Zone is selected, during Live View shooting, or when using AI Servo AF or AI Focus AF.
(5) 10-sec. self-timer/Remote control
(6) 2-sec. self-timer
(7) Continuous shooting after 10-sec. self-timer (2 to 10 shots)
Continuous Shooting Speed
High-speed continuous shooting: Max. approx. 4.0 fps
* With One-Shot AF or AI Servo AF
Silent continuous shooting: Max. approx. 2.5 fps
* One-Shot AF only
Maximum Burst
Based on 8GB memory Card:
JPEG Large/Fine: Approx. 28 Shots
RAW: Approx. 7 Shots
RAW+JPEG Large/Fine: 4 Shots
Based on UHS-I memory card:
JPEG Large/Fine: Approx. 1140 Shots
RAW: Approx. 8 Shots
RAW + JPEG Large/Fine: 4 Shots
* Figures are based on Canon's testing standards (ISO 100 and Standard Picture Style).
* At ISO 12800, maximum burst will greatly decrease due to internal processing.
Shooting Modes
Still photo shooting and video shooting
Focusing
(1) AF operation of the Hybrid CMOS AF, One-shot AF
i.Face Detection plus Tracking AF
ii.FlexiZone - Multi
* 31 zones
* AF at the touched zone
iii.FlexiZone - Single
(2) TTL secondary image-forming, phase-difference detection with AF operation, One-shot AF
i.Manual selection
ii.Auto selection
(3) Manual focus
* Manual focusing by enlarging images by approx. five to ten times
Metering Modes
Real-time evaluative metering with image sensor.
(1) Evaluative metering (315 zones)
(2) Partial metering (approx. 10.3% of Live View screen)
(3) Spot metering (approx. 2.6% of Live View screen)
(4) Center-weighted average metering
* AE lock possible. The active metering time can be changed.
Metering Range
EV 0 to EV 20 (At room temperature, 50mm f/1.4 lens, ISO 100)
Grid Display
Two grids provided:
(1) Grid 1: Pair of vertical and horizontal lines
(2) Grid 2: 5 vertical and 3 horizontal lines
Exposure Simulation
Provided
Silent Shooting
Provided
File Format
MOV:
Movie: MPEG-4 AVC / H.264
* Variable (average) bit rate
Audio: Linear PCM
* Meta information is embedded in the MOV file (no separate THM file)
File Size
Recording Size:
[Full HD]
1920 x 1080 (30 fps/25 fps/24 fps): 330 MB/min.
[HD]
1280 x 720 (60 fps/50fps): 330 MB/min.
[SD]
640 x 480 (30 fps/25fps): 82.5 MB/min.
* If the file size exceeds 4GB, a new file will be automatically created.
** SD Class 6 or higher required.
Frame Rates
1920 x 1080 (Full HD): 30p (29.97) / 24p (23.976) / 25p
1280 x 720 (HD): 60p (59.94) / 50p
640 x 480 (SD): 30p (29.97) / 25p
Continuous Shooting Time
Based on 8GB Memory Card:
[1920 x 1080] 30 fps/25 fps/24 fps: 22 min.
[1280 x 720] 60 fps/50 fps: 22 min.
[640 x 480] 30 fps/25 fps: 1 hr. 32 min.
Based on 16GB Memory Card:
[1920 x 1080] 30 fps/25 fps/24 fps: 44 min.
[1280 x 720] 60 fps/50 fps: 44 min.
[640 x 480] 30 fps/25 fps: 3 hr. 4 min.
* If recording time reaches 29 min. 59 sec., movie shooting stops automatically.
Focusing
(1) One-shot AF
(2) Servo AF
(3) Manual Focus
* Magnify the image by approx. 5x or appox. 10x and focus manually.
AF using AF point selection:
* 31 zones
Range
8 bit, 0 - 255
Exposure Control
(1) Program AE for movie shooting
* In Basic Zone modes, P, Av, and Tv modes
* Shutter speed 1/30 - 1/4000 sec. (Signal accumulation time), aperture, and ISO speed automatically set.
(2) Manual exposure
* Shutter speed (signal accumulation time), aperture, and ISO speed (auto/manual) manually set. The shutter speed (signal accumulation time) is limited to 1/4000 sec. at the maximum and to 1/30 sec. at the minimum for 24/25/30 fps or 1/60 sec. or higher for 50/60 fps.
Provided (&plusmn;3 stops in 1/3-stop increments)
* For movies, exposure compensation will not be applied beyond &plusmn;3 stops even if the exposure compensation has been set beyond &plusmn;3 stops.
* For still photo shooting, the exposure compensation can be set and applied up to &plusmn;5 stops.
Type
TFT color, liquid-crystal monitor with Touch Panel LCD (capacitive type)
Monitor Size
Wide 3.0-inch (Screen aspect ratio of 3:2)
7.7cm diagonal (6.4cm wide, 4.3cm high)
Pixels
Approx. 1,040,000 dots
Coverage
Approx. 100%
Brightness Control
Adjustable to one of seven brightness levels
Coating
Anti-smudge coating
Interface Languages
25 (English, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Romanian, Ukrainian, Turkish, Arabic, Thai, Simplified/Traditional Chinese, Korean, Japanese)
Display Format
(1) Single image displaySingle image, basic information, detailed information, histogram display(2) Index display4/9/36/100 images(3) Jump display (Image jump w/ Main Dial)1/10/100 images, by date, by folder, movies only, stills only, by rating
Highlight Alert
On the detailed information and histogram displays, highlight areas with no image data will blink.
Histogram
Brightness / RGB
Items
During shooting:
When you press the Quick Control function button under the following conditions, you can set the functions below:
*The settable functions depend on the shooting mode(1)With viewfinder shooting:
Shutter speed, aperture, ISO speed, exposure compensation/ AEB, flash exposure compensation, Picture Style, White balance, White balance correction/White balance bracketing, Auto Lighting Optimizer, Metering mode, AF operation, Drive mode/Self-timer, image-recording quality, Flash firings, Ambience-based shots, Light/scene-based shots, Extra Effect Shot, Background blurring, Special scene modes, and Color tone.(2)With Live View shooting:
AF method, Drive mode/Self-timer, Metering mode, image-recording quality, White balance, Picture Style, Auto Lighting Optimizer, Creative Filter, Flash firing, Ambience-based shots, Light/scene-based shots, Extra Effect Shot, Special scene modes, and Color tone.(3)With video shooting:
AF method, Drive mode/Self-timer, image-recording quality, movie-recording size, video snapshot, White balance, Picture Style, Auto Lighting Optimizer, and Miniature effect movie.
During Playback:
(1)During still photo playback:
Image protect, image rotate, rating, Creative Filters, resize, Cropping, and image jump with Main Dial
(2)During movie playback:
Image protect, rating, and image jump with Main Dial
Protection
Erase protection can be applied/canceled for a single image, all images in a folder, or all images on the card
Erase
Erase single image, erase selected images, erase all images in folder, erase all images on a card, or erase only unprotected images
Compatible Printers
PictBridge-compatible printers
Printable Images
RAW, JPEG, and RAW+JPEG images complying to Design rule for Camera File System
* Movies cannot be printed.
DPOF
Complies to DPOF Version 1.1
Compatible Images
Not Provided
Custom Functions
Eight Custom Functions with 24 settings settable with the camera
Custom Controls
Not Provided
My Menu Registration
Up to six top-tier menu options and Custom Function settings can be registered
USB Terminal
For personal computer communication and PictBridge (Hi-Speed USB)
Video Out Terminal
HDMI mini OUT terminal:
Type C (Switches automatically to suit the resolution)
Video output: 1080/60i, 1080/50i, 480/60p, 576/50p
* Switches automatically to 1, 2, 3, or 4 to suit the TV
Extension System Terminal
Not Provided
Battery
Battery Pack LP-E12 x 1
* With the AC Adapter Kit ACK-E15, AC power is possible.
Battery Life
1)Camera body only
Battery Check
Automatic battery level check when power is turned ON.
Battery level indicated in one of four levels on LCD monitor.
Power Saving
Power turns off after the set time of non-operation elapses
* [Auto power off] settable to 30 sec., 1 min., 2 min., 4 min., 8 min., 15 min. or disable
Date/Time Battery
Built-in secondary battery. When fully-charged, the date/time can be maintained for about three months.
Start-up Time
Approx. 0.1 sec. (Based on CIPA testing standards)
Dimensions (W x H x D)
Approx. 4.60 x 3.57 x 2.74 in.1 / 116.8 x 90.7 x 69.4mm1
1(Weight specifications and dimensions are for camera body only; does not include battery or memory card.)
Weight
Approx. 14.36 oz. / 407g (CIPA standard)
Approx. 13.06 oz.1 / 370g1 (Body only)
Approx. 13.16 oz 1 / 373g1 (White Body only)
Working Temperature Range
32-104&deg;F/0-40&deg;C
Working Humidity Range
85% or lessAll data are based on Canon's Standard Test Method. Subject to change without notice.
If a problem occurs with a non-Canon lens attached to the camera, consult the lens maker.
Canon, DIGIC and EOS Rebel are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Microsoft, Windows and Windows Vista are trademarks or registered trademarks of Microsoft Corporation in the United States and/or other countries. Mac is a trademark of Apple, Inc., registered in the United States and other countries. HDMI, the HDMI logo and High-Definition Multimedia Interface are registered trademarks or trademarks of HDMI Licensing, LLC in the United States and/or other countries. All other products and brand names are registered trademarks, trademarks or service marks of their respective owners in the United States and/or other countries.
  1. Loss of or damage to the Product due to abuse, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, failure to follow operating, maintenance or environmental instructions prescribed in Canon U.S.A.'s or Canon Canada's user's manual or services performed by someone other than Canon U.S.A. or Canon Canada, or a Canon authorized service provider for the Product. Without limiting the foregoing, water damage, sand/corrosion damage, battery leakage, dropping the Product, scratches, abrasions or damage to the body, lenses or LCD display or damage to the any of the accessories mentioned in the first paragraph above will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the operating instructions
  2. Use of parts or supplies (other than those sold by Canon U.S.A. or Canon Canada) that cause damage to the Product or cause abnormally frequent service calls or service problems
Canon U.S.A.
Canon Canada
Online Repair
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
