Canon Support for VR Content Creator Kit | Canon U.S.A., Inc.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows NT
- Linux
SELECT ERROR CODE
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Type | Digital single-lens non-reflex AF/AE camera |
Image Processor | DIGIC X |
Recording Media | CFexpress card
SD card
Compatible Lenses | Canon RF lens group (excluding EF, EF-S and EF-M lenses) When using Mount Adapter EF-EOS R: Canon EF or EF-S lenses (excluding EF-M lenses) |
Lens Mount | Canon RF mount |
Type | CMOS sensor (compatible with Dual Pixel CMOS AF) |
Effective pixels | Approx. 45.0 megapixels |
Sensor Size | Approx. 36.0 x 24.0 mm |
Pixel Size | Approx. 4.40 micro square |
Total Pixels | Approx. 47.1 megapixels |
Aspect Ratio | 3:2 (Horizontal:Vertical) |
Color Filter System | RGB primary color filters |
Low Pass Filter | Installed in front of the image sensor, non-detachable |
Dust Deletion Feature |
Recording Format | Compliant to Design rule for Camera File system 2.0 and Exif 2.3*. *Supports time difference information in Exif 2.31. |
Image Format | JPEG, HEIF, RAW (CR3, 14 bit RAW format), C-RAW (Canon original); Movies: ALL-I, IPB, RAW |
HDR Mode-Continuous Shooting | (1) 1 shot only (2) Continuously (3) Multiple Exposure |
Advanced shooting operations | (1) Focus Bracketing
(2) Interval Timer (3) Bulb Timer (4) Multi-Shot NR |
File Size | 3:2 Aspect Ratio Large/RAW/C-RAW: 8192 x 5464 Medium: 5808 x 3872 Small 1: 4176 x 2784 Small 2: 2400 x 1600 1.6x (Crop)* Large/RAW/C-RAW: 5088 x 3392 Small 2: 2400 x 1600 4:3 Aspect Ratio Large: 7280 x 5464 Medium: 5152 x 3872 Small 1: 3712 x 2784 Small 2: 2112 x 1600 RAW/C-RAW: 8192 x 5464 16:9 Aspect Ratio Large: 8192 x 4608 Medium: 5808 x 3264 Small 1: 4176 x 2344 Small 2: 2400 x 1344 RAW/C-RAW: 8192 x 5464 1:1 Aspect Ratio Large: 5456 x 5456 Medium: 3872 x 3872 Small 1: 2784 x 2784 Small 2: 1600 x 1600 RAW/C-RAW: 8192 x 5464
File Numbering | The following file numbers can be set:
RAW + JPEG / HEIF Simultaneous Recording | Simultaneous recording of any combination of RAW/C-RAW and JPEG/HEIF image-recording quality is supported. |
Color Space | Selectable between sRGB and Adobe RGB |
Picture Style |
Settings |
Auto White Balance | Option between ambience priority and white priority settings. |
White Balance Shift | Blue/amber bias: +-9 levels Magenta/green bias: +-9 levels Corrected in reference to the current WB mode's color temperature. |
Type | OLED color electronic viewfinder; approx. 5.76 million dots resolution |
Coverage | Approx. 100% vertically and horizontally relative to the shooting image area (with image quality L, at approx. 23mm eyepoint). |
Magnification / Angle of View | Approx. 0.76x / Approx. 35.5 degrees (with 50mm lens at infinity, -1 m -1) |
Eye Point | Approx. 23mm (at -1 m -1 from the eyepiece lens end) |
Dioptric Adjustment Range | Approx. -4.0 to + 2.0 m -1 (dpt) |
Viewfinder Information |
Focus Method | Dual Pixel CMOS AF II |
Number of AF zones available for Automatic Selection | AF area: Horizontal: Approx. 100% x Vertical: Approx. 100% Stills: Max. 1053 zones (39 x 27) Movies: Max. 819 zones (39 x21) |
AF Working Range | EV -6 to 20 (f/1.2 lens*, center AF point, One-Shot AF, at 73F/23C, ISO 100) * Except RF lenses with a Defocus Smoothing (DS) coating. |
AF Methods |
Subject to Detect | People, Animals, No Priority * Available with [AF method] set to Face+Tracking, Zone AF, or Large Zone AF (vertical/horizontal) |
Metering Modes | Real-time metering with image sensor (384 [24x16 zone metering])
Metering Range | EV -3 - 20 (at 73F/23C, ISO 100) (Still Photo Shooting) |
Exposure Control Modes |
ISO Speed Range | Available ISO speeds; user-set
User-defined ISO range - still photo shooting
* Expanded ISO speeds are noted as being "equivalent" to these speeds. User-defined Auto ISO range - still photo shooting
ISO Auto details in still photo shooting
1 ISO 200 when [Highlight tone priority] is set to [Enable] or [Enhanced]. |
Exposure Compensation |
AE Lock |
Type |
* A shutter release sound is not generated. However, note that the sounds other than the shutter release sound (aperture, focusing lens drive sound/electronic sound, etc.) may be generated. * In electronic shutter shooting under conditions such as flash firing by other cameras or with fluores-cent lighting or other flickering light sources, a strip of light or banding due to the brightness difference may be recorded in the image. |
Shutter Speeds | When [Mechanical] or [Elec. 1st- curtain] is set: 1/8000-30 sec, bulb When [Electronic] is set: 1/8000-0.5 sec. |
X-sync Speed | Mechanical Shutter: 1/200 sec. Elec. 1st-curtain: 1/250 sec. |
Shutter Release | Soft-touch electromagnetic release |
Self Timer | 10-sec. delay, 2-sec. delay |
Shutter Lag Time |
Still Photo IS | Optical IS with RF and EF lenses equipped with Image Stabilization.
Video IS | A narrower angle of view is used when digital image stabilization is selected in the menu. This is equivalent to approx. 1.1x longer focal length when Electronic Image Stabilization mode (Standard) is selected. Also, this is equivalent to approx. 1.43x longer focal length when Electronic Image Stabilization mode (High) is selected. |
E-TTL balance | Ambience priority, standard, flash priority |
Compatible E-TTL Speedlites | Canon EX- and EL-series Speedlites |
E-TTL II Flash Meterings |
Slow Sync (P/Av modes) |
* With mechanical shutter 1/200 sec. |
Flash Function Menu | Provided for EX- and EL-series Speedlites |
Flash Exposure Compensation | +-3 stops in 1/3- or 1/2-stop increments |
Continuous flash control |
Drive Modes and Continuous Shooting Speed |
* Continuous shooting speed is lower under certain shooting and measurement conditions: shutter speed, aperture value,subject conditions, brightness, type of lens, timing when internal memory becomes full (temporarily disables shooting) - Mechanical / electronic 1st curtain: use of flash, anti-flicker shooting: Enable, Dual Pixel RAW shooting- Enable, type of battery, battery level, temperature, use of a battery grip, use of WFT, use of built-in Wi-Fi. - Electronic shutter: State of aperture in continuous shooting * With Certain lenses, zooming during continuous shooting with electronic shutter may cause changes in exposure even at the same f/number. *1: For shooting RAW images in [High-speed continuous +], 13-bit A/D conversion will apply regardless of the mode (A, B, or C). *2: With Anti-flicker shooting, max. continuous shooting speed may drop to approx 6.2 fps (with electronic 1st curtain shutter) or approx. 4.9 fps (with mechanical shutter). * For Dual Pixel RAW shooting, Low-speed continuous shooting will apply. |
Still photo file size / Number of possible shots / Maximum burst for continuous shooting | Still Shooting with Mechanical Shutter or electronic 1st-curtain shutter, shot at approx. 12 fps
*²: The number of shots available and maximum burst (CFexpress card) apply to a 325 GB CFexpress card conforming to Canon testing standards. *³: Available when [HDR PQ] for HDR shooting is set to [Enable]. *: When [HDR PQ] for HDR shooting is set to [Disable]. *: With mechanical shutter or electronic 1st-curtain shutter, shot at approx. 12 fps. * File size, number of possible shots, and maximum burst vary depending on shooting conditions (including 1.6x crop/aspect ratio, subject, memory card brand, ISO speed, Picture Style, and Custom Function). |
HDR PQ Shooting | Disable / Enable |
HDR PQ Shooting - Still |
Focusing | Dual Pixel CMOS AF |
Canon Log | Provided (Off / Canon Log 3) |
Video Recording Size and Frame Rates | Please Click here for full specifications |
Recording Times | Please Click here for full specifications |
Type | TFT color, liquid-crystal monitor |
Monitor Size | 3.2-inch (screen aspect ratio of 3:2) 3.15 in./8.01cm diagonal (2.63 in./6.67cm width, 1.75 in./4.44cm height) |
Dots | Approx. 2.1 million dots |
Coverage | Approx. 100% vertically/horizontally |
Brightness Control | Manually adjustable to one of seven brightness levels |
Coating | Clear View LCD II
Interface Languages | 12 (English, German, Spanish, French, Portuguese, Italian, Ukraine, Russian, Polish, Simplified Chinese, Korean, Japanese) |
Display Format |
Highlight Alert | The white areas with no image data will blink. |
Histogram | Brightness and RGB |
Function | The Quick Control screen is accessed by pressing the Quick Control button during still photo shooting. |
Protection |
Erase | Except protected images
Compatible Printers | Not supported |
DPOF | Compliant to DPOF Version 1.1 |
Standards Compliance | IEEE 802.11a/ac/b/g/n |
Transmission Method | DS-SS modulation (IEEE 802.11b) OFDM modulation (IEEE 802.11g/n/a/ac) |
Transition Frequency (Central Frequency) | 2.4 GHz band Frequency: 2412 to 2462 MHz Channels: 1 to 11 channels 5 GHz band Frequency: 5180 to 5825 MHz Channels: 36 to 165 channels |
Connection Method | (1)Camera access point mode (2)Infrastructure mode |
Security |
Communication with a Smartphone | Images can be viewed, controlled, and received using a smartphone. Remote control of the camera using a smartphone is possible depending on the Camera Connect specifications. Images can be sent to a smartphone. |
Remote Operation Using EOS Utility | The camera can be controlled via Wi-Fi® using EOS Utility. |
Print from Wi-Fi® Printers | Not supported. |
Send Images to a Web Service | Still photos (RAW, C-RAW, HEIF, and JPEG) and movies (MP4) can be uploaded to image.canon server album. With the image.canon server, images can be sent to social media or a photo album link can be sent (by the image.canon specifications). |
Standards Compliance | Bluetooth Specification Version 5.0 compliant (Bluetooth low energy technology) |
Transmission Method | GFSK modulation |
Custom Functions | 22 Custom Functions are settable. |
Custom Controls | Customizable Buttons
Customizable Dials
My Menu Registration |
USB Terminal | Equivalent to Hi-Speed USB (USB 3.1 Gen 2)
Video Out Terminal | HDMI micro OUT terminal Type D (Resolution switches automatically) / CEC not compatible
Clean HDMI output | Provided |
Microphone Input Terminal | 3.5mm diameter stereo mini jack |
Headphone Terminal | 3.5mm diameter stereo mini jack |
Battery | LP-E6NH/LP-E6N/LP-E6*
Battery Check | Automatic battery check when the power switch is turned ON.
Start-up Time | Approx. 0.4 sec.
Dimensions (W x H x D) | Approx. 5.6 x 4.0 x 4.4 in. / 142 x 101 x 111mm
Weight | Approx. 1.7 lbs. / 770g (including battery, CFexpress card; without body cap) Approx. 1.5 lbs. / 680g (body only; without battery, card or body cap) |
Working Temperature Range | 32-104 F / 0-+40C |
Working Humidity | 85% or less |
Focal Length | 5.2mm |
Maximum and Minimum Aperture | f/2.8 f/16 (1/3 stops, 1/2 stops) |
Lens Mount Type | Canon RF Mount; Metal Mount |
Interpupillary Distance / Baseline Length (Distance between Left and Right Lens Centers) | 60mm |
Minimum Focusing Distance | 0.66 ft. (7.9 in.) / 0.2 m |
Maximum Magnification | 0.03x |
Angle of View (Diagonal) | 190° 00' |
Lens Construction (each lens) | 12 elements in 10 groups |
Special Elements (each lens) | Two UD glass elements |
Lens Coating | Canon SSC (Super Spectra Coating) Canon SWC (Sub-wavelength Structure Coating) Fluorine Coating on front surface of front element |
Filter Size Diameter | Supported Built-in |
Aperture Blades (each lens) | 7 |
Lens Switches | None |
Dust/Water Resistance | Provided (rubber ring on lens mount) |
Focusing System | Manual focusing |
Left/right focus difference adjustment | User-adjustable, via adjustment dial (using included 1.5mm hexagonal wrench) |
Dual Pixel CMOS AF | Not Supported Manual focus only |
Focus Guide | Supported Alternate at image center of either selected lens UI by INFO button with cameras equipped with compatible firmware. |
Manual Focus Peaking | Supported with compatible cameras. |
Full-time Manual Focusing | Not Supported |
Control Ring | Not Supported |
IS Mode Selection | Not Supported |
Optical Image Stabilization | Not Supported |
Dimensions (width x height x length) | 4.8 x 3.3 x 2.1 in. (121.1 x 83.6 x 53.5mm) |
Weight | Approx. 12.4 oz. (350g) |
Lens hood | Not Supported |
Lens Cap | Dedicated Canon Lens Cap 5.2 (Center pinch type; bundled) |
Dust Cap | Canon Lens Dust Cap RF |
Lens Case | Canon Lens Case LS1014 (bundled) |
RF Tele Extenders | Not Compatible |
EF Extension Tubes | Not Compatible |
Close-up Lenses | Not Compatible |
Canon Gelatin Filter Holder IV | Not compatible; Built-in gelatin filter holder at rear of lens |
Left/right focus difference adjustment Hexagonal Wrench | Bundled 1.5mm hexagon wrench |
