Web Content Viewer
Actions
EF-S 10-18mm f/4.5-5.6 IS STM
Ultra-Wide Zoom
Item Code: 9519B002AA
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Open new roads to creativity with the Canon Portrait & Travel 2 Lens Kit and save while doing so.
Features
  • EF-S ultra wide zoom lens with an impressive starting focal length (16mm in 35mm equivalence).
  • Compact design made possible by a new 4 group zoom optical system.
  • A stepping motor (STM) and newly-designed focus mechanism support the Canon EOS Movie Servo AF function to provide smooth and quiet continuous AF during video recording, as well as when shooting photos.
  • A large diameter element and an aspherical lens element help correct aberration to achieve higher image quality
  • One UD lens element helps reduce chromatic aberration throughout the zoom range for excellent image quality with high resolution and contrast.
  • Optical Image Stabilizer for up to four stops of correction*.
  • Enhanced lens coatings help ensure outstanding color balance while minimizing ghosting and flare.
  • Circular aperture (7 blades) creates beautiful, soft backgrounds.
  • Rear focusing system, high-speed CPU and improved AF algorithm allow high speed autofocus.
  • Full-time manual focus allows manual focus adjustment while in AF Mode.
* Based on CIPA (Camera & Imaging Products Association) standards. Testing performed using the EOS 7D Digital SLR camera at a focal length of 18mm (29mm in 35mm equivalence).
This is to make Misc appear on the page when needed.
Specifications
Focal Length & Maximum Aperture
10-18mm 1:4.5-5.6
Lens Construction
14 elements in 11 groups
Diagonal Angle of View
107°30' - 74°20'
Focus Adjustment
Rear focus system
Closest Focusing Distance
0.72 ft. / 0.22m
Filter Size
67mm diameter
Max. Diameter x Length, Weight
2.9 x 2.8 in., 8.5 oz. / 74.6 x 72.0mm, 240g
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EF-S 10-18mm f/4.5-5.6 IS STM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
Videos
Canon EF 101: STM Lenses
Canon STM lenses have stepping motors that allow you to focus quietly and follow your subject smoothly. Canon expert Jon Lorentz demonstrates the quiet smoothness of Canon's STM technology.
 Return to Top
