Compatible Printers for Chromebook™ Notebook Computer
You’ve picked out a Chromebook notebook computer. Now, it’s time to accessorize with a compatible printer! But do you know which printers are compatible with Chromebook notebook computers? Fortunately, the answer is “many!” You’ve got an abundance of options, including wireless all-in-one printers, inkjet printers, laser printers, portable printers and more. There are so many choices, it is easy to feel overwhelmed.
Canon Printers Compatible with Chromebook Notebook Computers
To help narrow down the list, we’ve selected what we think may be three of the best Canon printers compatible with Chromebook notebook computers1, each with its own perks, and each supported by a warranty. Read on and select the right wireless printer for you.
This wireless2, all-in-one printer gets the job done - whether that job involves printing, copying, scanning or all the above - with your Chromebook notebook computer. With its compact size and 2.7-inch LCD touchscreen, this inkjet printer can be a great option for home use and for home offices. It connects to a network using Wi-Fi® connectivity2 or a high-speed USB, and with its intuitive LCD touchscreen it’s easy for users to select “copy,” “scan,” or “print.” It’s a whiz when it comes to printing documents, photos, greeting cards, business cards, labels and more, and it can crank out up to 15 black-and-white pages per minute and up to 10 color pages per minute3. It’s equipped with auto two-sided printing, allowing you the option to save paper and make double-sided large print jobs a bit easier. With an auto document feeder that can hold up to 35 sheets of plain, letter-sized paper at a time, copying and scanning can feel seamless. This versatile printer comes with a one-year limited warranty4.
The Canon PIXMA TR7820 Wireless2 All-in-One Printer has been recognized for its energy efficiency, having obtained ENERGY STAR®5 certification, and it is registered EPEAT Silver.
- Wireless2 3-in-1 (Print | Copy | Scan)
- Up to 15 (BW) / 10 (COLOR) images per minute (ipm)3
- 100-sheet paper cassette + 100-sheet rear tray
- 35-sheet auto document feeder (ADF) (Plain paper, letter-sized)
- Auto 2-sided printing available (you may need to set this function up in your “page setup” settings)
- 2.7" LCD touchscreen for easy navigation
- Stable and reliable connection with dual-band Wi-Fi® (2.4GHz or 5GHz) connectivity2
- Save up to 70% on the cost of printing with PIXMA Print Plan6
- 1-year limited warranty4
Printing from your Chromebook notebook computer can be a breeze with the Canon PIXMA TS7720 Wireless2 Inkjet All-in-One Printer that prints, copies and scans. Compact and efficient, this device can print in black and white (up to 15 pages per minute) as well as color (up to 10 pages per minute)3, and with built in auto, two-sided printing available (you may need to set this function up in your “page setup” settings), it’s at the ready to print on both sides of the page. That means it can potentially simplify large double-sided print jobs and can even save paper. With a 100-sheet front paper cassette and a 100-sheet rear paper tray, you can switch between different types of paper with alternating projects. For example, you could place plain paper in the front paper tray for work reports, and photo paper in the rear paper tray for family photo print jobs. When you need to scan or copy documents, the Canon PIXMA TS7720 printer can handle those duties, as well.
At a glance, the PIXMA TS7720 printer was designed for ease of use and can handle an array of jobs that a student, family member or remote worker might have. It connects to a network using dual-band Wi-Fi® connectivity2 and can be controlled using an intuitive 2.7-inch LCD touchscreen. And it comes with a one-year limited warranty.
- Dual-band Wi-Fi® (2.4GHz or 5GHz) connectivity2
- Save up to 70% on the cost of printing with PIXMA Print Plan5
If you expect to print regularly, the Canon MegaTank PIXMA G3270 printer may the right compatible printer for you. Thanks to refillable ink tanks, this wireless2, all-in-one inkjet printer can print up to 6,000 pages in black-and-white and up to 7,700 pages in color using a single set of replacement ink bottles7. That’s serious! It means, depending on how many pages you regularly print, you won’t have to refill the ink tanks frequently, and you may even save on ink-per-page costs.
In addition to being Chromebook notebook computer-compatible1, this printer is also versatile in its output, excelling at document printing and photo printing on an array of different types of paper and paper sizes. It comes with a rear paper tray that can hold up to 100 sheets of plain, letter size paper. And with its scanning and copying capabilities, this device is ready for anything. Even with its compact size, this printer is a workhorse that can tackle your home and home-office printing needs. Like the others, it comes with a one-year limited warranty4 to help with peace of mind.
The Canon MegaTank PIXMA G3270 printer has been recognized for its energy efficiency, having obtained ENERGY STAR®5 certification, and it is registered EPEAT Silver.
- Integrated ink tanks - Up to 6,000 pages BW / 7,700 pages Color from full set of replacement ink bottles (not included)7
- 11 ipm black /6 ipm color3
- 100-sheet rear tray (plain paper, letter size)
- Single-sided printing
How to Connect Your Chromebook Notebook Computer to a Canon Compatible Printer
Wondering how you can you print from a Chromebook notebook computer? It’s easy, and just takes a few steps when using one of Canon’s compatible printers. To install a Canon printer on a Chromebook notebook computer, make sure your printer has ChromeOS Support (all three of the printers above do). Then follow the instructions below to set up your Canon printer on your Chromebook notebook computer:
| Via Wi-Fi® connectivity2 | Via USB cable |
Click the Status Tray in the bottom right corner of your Chromebook Shelf Select Settings (gear icon) in the menu to open the Settings Menu. Select Advanced, either from the side menu of the settings screen, or by scrolling to the bottom and clicking it. Scroll to the Print and Scan section and click on Printers. Click Set up on the printer you are adding to your Chromebook notebook computer. After clicking Set up, you will see your printer added to the saved printers list. |
Connect the USB cable to the printer port and to a USB port on your Chromebook notebook computer. Turn on the printer. Your Chromebook notebook computer will automatically detect the printer. Click the Settings icon (gear icon) in the status area. Click Advanced. Scroll down to the Print and Scan section and click Printers. Click Add a printer. Select your printer from the list and click Add. Your printer will be added to your Chromebook notebook computer and will be ready to use. |
Can you print wirelessly2 on your Chromebook notebook computer now? Yes, you can.
Want to learn more about Canon Printers and Chromebook notebook computers? Here are some resources to check out:
Specifications and availability subject to change without notice.
Canon U.S.A., Inc. Canon and PIXMA are registered trademarks of Canon Inc. in the United States and may be registered trademarks or trademarks in other countries. Chromebook and ChromeOS are trademarks of Google LLC. Wi-Fi is a registered trademark of the Wi-Fi Alliance. ENERGY STAR is a registered trademark owned by the U.S. Environmental Protection Agency. All other product and brand names are trademarks of their respective owners.
- Functions and features may vary by printer model. Scanning requires ChromeOS 89 or later.
- Wireless printing and scanning requires a working network with wireless 802.11b/g/n capability, operating at 2.4GHz or 5.0GHz. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
- Document print speeds are the averages of ESAT in Office Category Test for the default simplex mode, ISO/IEC 24734. Print speed may vary depending on system configuration, interface, software, document complexity, print mode, page coverage, type of paper used etc. See www.usa.canon.com/ipm for additional details.
- Warranty programs are subject to certain conditions and restrictions. See www.usa.canon.com/support for details.
- As an ENERGY STAR® Partner, Canon U.S.A., Inc. has certified this printer as meeting the ENERGY STAR energy efficiency criteria through an EPA-recognized certification body.
- Savings amount will vary depending on the monthly plan chosen and does not apply to the Pay Per Print plan. The savings claim applies to the monthly print plans available and is based on the cost per print calculated on the page yield of 400 Black / 300 Color pages per ink cartridge set and cost of $66.99 for a value pack of PG-260(XL) and CL-261(XL), the page yield of 300 Black / 300 Color pages per ink cartridge set and cost of $63.99 for a value pack of PG-275(XL) and CL-276(XL) and the page yield of 400 Black / 400 Color pages per ink cartridge set and cost of $75.99 for a value pack of PG-285(XL) and CL-286(XL) ink cartridges (using Canon Online Store prices as of May 2024). Actual page yield and cost per print will vary significantly based on content printed and other factors. Page yield is an estimated value based on Canon individual testing method using ISO/IEC 24712 test chart and continuous printing simulation with full set of ink cartridges after initial setup.
- Page yield of included ink bottles used for initial setup is lower than the replacement ink bottles, as a certain amount of ink is consumed to fill into the print head during setup (charging the print head initially). Page yield is the estimated value based on Canon individual test method using the ISO/IEC 24712 chart and continuous printing simulation with the replacement ink bottles after initial setup. Page yield of color inks is an average yield of cyan, magenta and yellow inks combined. Page yield varies significantly depending on content printed, ink levels maintained in all four reservoirs, and other factors. Up to 6,000 (black)/7,700 (color) printed page yields are approximate using `default printing mode’. A full set of MegaTank GI-21 ink bottles (pigment black, cyan, magenta, yellow) is equivalent to 30 each standard capacity Black (PG-260) and Color (CL-261, composed of cyan, magenta and yellow) ink cartridges sold individually based on print yield. Ink value savings based on MSRP (USD) of stated ink bottles and equivalent ink cartridges as of February 2023.
