Out Of Stock
imageCLASS LBP352dn
LBP352DN
As low as $1,699.00
Out Of Stock
  • Print up to 65 ppm (BW)
  • Print up to 8-1/2” x 14”
  • 3,600-sheet maximum paper capacity
  • Black-and-White
    • Compact
    • User-Friendly
    New
    Return Policy
    Main Unit Spec
    Printer Specifications
    Printer Type
    Monochrome Laser Single Function Printer
    Print Speed
    Up to 65 ppm (1-sided plain paper, letter), Up to 43ppm (2-sided plain paper, letter)1
    First Print Time
    7 seconds or less (letter)2
    Printer Language
    UFR II, PCL 5c/e, PCL6, PS, PDF, XPS
    Print Resolution
    600 x 600 dpi,
    1,200 x 1,200 dpi equivalent dpi
    Maximum Print Size
    Up to Legal
    Duplex Print
    Yes
    Print Modes
    Toner Saver, Booklet, Poster, Watermark
    Print Memory
    1 GB
    Direct Print from USB
    Print File format: JPEG, TIFF, PDF, XPS
    Paper Handling Specifications
    Standard Paper Source(s)
    500-sheet cassette, 100-sheet multipurpose tray3
    Optional Paper Source(s)
    500-sheet cassette (PF-B1), 450-sheet custom media cassette (CM-A1), 1,500-sheet paper deck (PD-G1), 75-sheet (or 200-postcard) feeder (EF-A1)3
    Paper Output
    Output tray (face down): Approx. 500 sheets, Sub-output tray (face up): 100-sheets
    Paper Weight
    16-32 lb. bond (plain paper, 500-sheet standard cassette, optional 500-sheet cassette, optional 1,500-sheet paper deck, optional 450-sheet custom media cassette), 16-36 lb. bond (plain paper, 100-sheet multipurpose tray)
    Media Sizes
    500-Sheet Standard Cassette: Letter, Legal, A4, A5, B5, Executive.
    Optional 450-Sheet Custom Media Cassette*: Letter, Legal, A4, A5, A6, B5, Statement, Executive.
    Optional 500-Sheet Cassette: Letter, Legal, A4, A5, B5, Executive.
    Optional 1,500-Sheet Paper Deck: Letter, Legal, A4.
    *Optional Custom Media Cassette can only be inserted into the standard cassette cavity and will work in place of the standard cassette to accommodate small media sizes 4" x 5.8" to 6.7" x 11.1"
    Media Types
    Plain, Heavy, Bond, Label, Envelope, Postcard
    Envelope Capacity
    75 envelopes (Optional Envelope Feeder)
    Envelope Types
    Com 10, Monarch, C5, DL
    Connectivity and Software Specifications
    Standard Interface(s)
    USB Device High-Speed 2.0, 10/100/1000 BASE-T Ethernet (Network)
    Mobile Functions
    Canon PRINT Business4, Apple® AirPrint®5, Mopria Print Service6
    Network Functions
    Print
    Embedded Web Server (Remote UI)
    Yes
    Web Browser Support for Remote UI
    Microsoft Internet Explorer 7.0 or later, Safari 9.0.3
    Print Protocols
    LPD, RAW, WSD-Print (IPv4,IPv6)
    TCP/IP Set of Application Services
    Bonjour(mDNS), HTTP, HTTPS, DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6)
    Network Management Protocols
    SNMPv1, SNMPv3 (IPv4,IPv6)
    OS Compatibility
    Windows® 10, Windows 8.1, Windows 8, Windows 7, Windows Vista®, Windows Server® 2012 R2, Windows Server® 2012, Windows Server 2008 R2, Windows Server 2008, Windows Server 2003 R2, Windows Server 2003, Mac® OS X 10.5.8 & up
    Cable Included
    Power Cord (USB not included)
    Bundled Software
    Printer driver
    Environmental Specifications
    Power Consumption
    During Operation: 880 W or less,
    During Standby: 20 W or less,
    Energy Saver Mode: 1 W Wired / 2 W USB
    Typical Energy Consumption
    0.88 kWh
    General Specifications
    Dimensions
    LBP350 Series: 16.4 inches (W) x 20.9 inches (D) x 17.3 inches (H)
    Stand Type T: 24 inches (W) x 25.5 inches (D) x 4.7 inches (H)
    Cabinet Type T1: 24 inches (W) x 25.5 inches (D) x 17.3 inches (H)
    For full configuration options and dimensions, please refer to this document.
    Unit Weight (without/with cartridge)
    54 lbs. (w/o cartridge),
    57.8 lbs (w/cartridge)
    Package Weight
    Approx. 67.3 lbs
    Cartridge Type
    Cartridge 039 Black (Yields approximately 11,000 pages)
    Cartridge 039 High Black (Yields approximately 25,000 pages)
    *Yields based on ISO/IEC Standard
    LCD Display
    5 Line LCD Panel
    Duty Cycle
    Up to 280,000 pages per month
    Department ID Management
    Yes, Up to 300 IDs
    Security
    IEEE802.1x, SNMPv3, IPSEC, IPv6
    Languages
    English, Spanish, French, Portuguese
    Warranty
    1 Year Onsite Service (Extended warranty available)7
    N/A10
    Other Features:
    EPEAT Silver Rating
    Product Disclaimer
    1. Copy/print speeds are measured based on internal testing using letter size paper copied/printed with 100% copy/print ratio to original on one-sided paper. Internal testing involved continuously copying/printing the same one page of content on plain paper (copy speed is tested by copying on the platen glass). Copy/print speeds may vary depending on paper type, paper size or paper feeding direction. The device may automatically pause or slow down in order to adjust printer condition such as controlling temperature of a certain unit or limiting impact to image quality during continuous copying/printing.
    2. May vary depending on the output environment.
    3. Based on 20 lb. bond paper.
    4. Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Users of Canon Mobile Printing can simply update the app to use Canon PRINT Business. Users who have installed Canon Mobile Scanning for Business should install Canon PRINT Business on their compatible device. After Canon PRINT Business is installed, users can re-register their Canon Mobile Scanning for Business device list and local documents. Android is a trademark of Google Inc. App Store is a service mark of Apple Inc. iPhone, iPad Air, iPad, iPad mini, are trademarks of Apple Inc., registered in the U.S. and other countries. iOS is a trademark or registered trademark of Cisco in the United States and other countries and is used under license.
    5. AirPrint functionality requires an iPad, iPad Mini, iPad 2, the new iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base Station, or Time Capsule is not supported.
    6. Mopria Print Service, available for free at the Google Play Store, requires a compatible Android KitKat 4.4 smartphone or tablet. The printer must be either wirelessly connected to the network router or with an Ethernet cable. The mobile device and printer must be connected to the same network.
    7. Google Cloud Print requires an Internet connection and Google Account. Printer firmware update may be necessary for Google Cloud Print™ function. Certain exceptions may apply. A PC running Windows XP or later or a Mac running OS 10.4.11 or later and USB cable are required to perform firmware update.
    8. Warranty program is subject to certain conditions and restrictions. See the warranty card for details.
