Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 03.05.10
File Size 6.23 MB
Date 01.01.04
File Size 500.84 KB
Date 07.11.07
File Size 4.03 MB
Date 01.01.04
File Size 500.84 KB
Date 04.19.10
File Size 10.3 KB
Camera Connect
Camera Connect
image.canon
image.canon
Power Supply (rated) 7.4 V DC
Power Consumption (While recording AF="ON") 2.6 W (using viewfinder), 3.3 W (using LCD screen)
Television System EIA standard (525 lines, 60 fields) NTSC color signal
Video Recording system 2 rotary heads, helical scanning system DV system (Consumer digital system) Digital component recording
Audio Recording system PCM digital sound: 16-bit (48 kHz/2 ch.), 12-bit (32 kHz/4 ch.)
Image Sensor 1/4.5-inch CCD, approx. 1,330,000 pixels. Effective pixels: Tape approx. 690,000 pixels; Card approx. 1,230,000 pixels
Tape Format Videocassettes bearing the MiniDV mark
Tape Speed SP: 0.74 ips (18.81 mm/s), LP: 0.49 ips (12.56 mm/s)
Maximum Recording Time (with an 80-min. cassette) SP: 80 min., LP: 120 min.
Lens f=3.5-49, f/1.8-3.1, 14x power zoom
Focusing System TTL autofocus, manual focusing possible
Focusing System 3 ft. 3 3/8 in. (1 m), 3/8 in. (1 cm), on maximum wide angle
Minimum Illumination 1.8 lx (using the night mode)
Recommended Illumination More than 100 lx
Viewfinder 0.33-inch TFT color, (approx. 113,000 pixels)
LCD Screen 2.5-inch TFT color, (approx. 123,000 pixels)
Microphone Stereo electret condenser microphone
DV Terminal Special 4-pin connector (IEEE1394 compliant)
Video Terminal 1 Vp-p/75 ohms unbalanced
S-video Terminal 1 Vp-p/75 ohms (Y signal), 0.286 Vp-p/75 ohms (C signal)
Audio Terminal Audio input: -10 dBV/40 kohms or more
Operating Temperature range 32 - 104&deg F (0 - 40&deg C)
Dimensions 3.1 x 2.9 x 5.1 in. (78 x 74 x 130 mm) excluding protrusions
Weight (not including lens and battery pack) approx. 1.1 lb. (500g)
Memory Card
Recording Media SD Memory Card, MultiMediaCard
Image Format Still image: JPEG (compression: Superfine / Fine / Normal), Movie: AVI (image data: Motion JPEG; audio data: WAVE (monaural))
File Format Design rule for Camera File system (DCF), Exif 2.2 compliant, Digital Print Order Format (DPOF) compliant (only images marked for printing or transfer)
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
