Canon Support for EOS ELAN 7/7E | Canon U.S.A., Inc.
EOS ELAN 7/7E
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Software Development Kit
SELECT ERROR CODE
Type and Major Components
Type | 35mm vertical-travel focal plane shutter SLR (Single-Lens-Reflex) camera with multi-point autofocus (Eye Controlled Focus), auto exposure with built-in flash. |
Compatible Lenses | Canon EF Lenses |
Lens Mount | Canon EF Mount (electronic signal transfer system). |
Viewfinder
Type | Fixed eye-level pentaprism with approximately 90% vertical and 92% horizontal coverage of actual picture area and 0.70x magnification with 50mm lens at infinity. Center and six outside focusing points controlled by eye movement. |
Focusing Screen | Fixed New Laser-Matte screen with 7 focusing points. |
Mirror | Quick-return half mirror (60% reflection / 40% transmission). |
Viewfinder Information | Inside Image Area: Focusing points with superimposed display. Below Image Area: (from left to right) Eye Controlled Focus indicator; AE Lock / FE Lock symbol; flash ready signal; High- Speed Sync in use signal; flash exposure compensation indicator; shutter speed and aperture indicating LEDs (blinks at 2hz when setting is unsuitable), also present DEP 1 / DEP 2 information, Calibration (Cal 1 to 5, END-1 to 3); Exposure compensation scale / manual metering scale, Red- Eye Reduction lamp on / reduction progress indicator; in- focus indicator (blinks at 2hz when focus cannot be achieved). |
Eyepiece Shutter | None. |
Autofocus
Focusing Point Selection | Selected automatically by camera or manually by user. Focusing point selection via Eye Controlled Focus available. |
Focus Modes | (1) One-Shot AF (2) Predictive AF with AI Servo AF (3) AI Focus AF (4) Manual. |
Focus Operation | (1) AF activated by pressing the shutter button halfway. (2) Pressing AE Lock button. |
AF Working Range | EV 1, 18 (at ISO 100 with the standard chart). |
Exposure Control
Metering Range | EV 1, 20 (ISO 100). |
Exposure Modes | (1) Intelligent Program AE with variable shift (2) Shutter speed-Priority AE (3) Aperture-Priority AE (4) Depth-of-Field AE (DEP) (5) Full Auto (6) Programmed Image Control: Portrait, Landscape, Close-up, Sports and Night Scene (7) Manual, (8) E-TTL Program Flash, (9) A-TTL Program Flash, (10) TTL Program Flash. |
Multiple Exposure | Up to 9 exposures can be preset. Automatically clears upon completion. All data based on Canon's Standard Test Method. Subject to change without notice. |
Exposure Compensation | (1) Auto Exposure Bracketing (AEB) to +/-2 stops in 1/2 stop increments repeatable. May be used in Intelligent Program, Shutter- Priority, Apert re-Priority, Depth-of-Field, and Manual modes only. (2) User- set expos re compensation up to +/-2 stops, in 1/2 stop increments, with Quick Control Dial. (3) Flash Exposure. |
Built-in-Flash
Type | Built-in, retractable TTL automatic flash; pops-up automatically when needed in low light/ backlight situations except when in Landscape, Sports or Creative Zone modes; manual pop- up (pull up by hand) in P, Av, Tv, M, modes. |
Guide Number | 43 (ISO 100, ft.) |
Recycling Time | Approximately two seconds. |
Film Transport
Film Loading | Automatic take-up with a sprocketless system. Film is automatically advanced to the first frame when the camera back is closed. |
Film Speed Setting | ISO 25-5000 automatically set in 1/3-stop increments according to DX code. Can also be set manually from ISO 6-6400 in 1/ 3-stop increments. High- speed infrared film cannot be used. |
Film Transport | Choice of single frame or continuous shooting at approximately 4 fps (3.5 fps in AI Servo AF), with additive frame counter. |
Film Rewind | Film is automatically rewound at the end of the roll or after 36 exposures, with a mid-roll film rewind option. Choice of high-speed (5 seconds with 24 exposure roll) or silent rewind (13 seconds with 24 exposure roll) modes. |
Power Source
Battery | Two CR123A lithium batteries (6V) loaded through the camera grip bottom. Optional battery pack BP-300: Compatible with four AA batteries or two CR123A lithium batteries. |
Battery Check | Automatic battery check when the Command Dial is released from OFF. |
Shooting Capacity | 24 exposure rolls |
Dimensions
Size (W x H x D) | 5.78 x 4.06 x 2.72 /146.7mm x 103mm x 69mm) ELAN 7E Date: 5.78"(W) x 4.06"(H) x 2.72"(D) /146.7mm(W) x 103mm(H) x 69mm(D) |
Weight | 20.3 oz / 575g ELAN 7E Date: 20.5 oz. / 580g (Add 1.12 oz. / 32g for two CR123A batteries) |
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
