Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 02.27.08
File Size 4.89 MB
Date 02.26.08
File Size 2.05 MB
Date 02.27.08
File Size 2.42 MB
Date 02.26.08
File Size 1.60 MB
Date 02.27.08
File Size 5.65 MB
Date 02.27.08
File Size 4.88 MB
Date 02.27.08
File Size 497.55 KB
Date 12.27.11
File Size 678.67 KB
Products Windows 7 Windows 8 Windows 10 Windows 10s
i560 Series 1
Print Speed (up to) Black:22 ppm (approximately 2.7 seconds per page)*Color:15 ppm (approximately 4 seconds per page)*4x6 borderless photo: approximately 50 seconds*
Number of Nozzles Black: 320; Color: 512 x 2 (C, M), 256 (Y)
Print Resolution (Up to) Black:600 x 600 dpi Color:4800 x 1200 dpi**
OS Compatibility Windows&reg;7, Windows&reg; XP, Windows 2000/Me/98/95, Windows NT 4.0, Mac&reg; OS (8.6 to 9.x) and Mac OS X v 10.2.1 to 10.2.x&#134;&#134;&#134;
Standard Interfaces USB 2.0, IEEE 1284 Parallel Port and Direct Print Port (cables not included)
Ink Compatibility BCI-6C Cyan ink tank, BCI-6M Magenta ink tank, BCI-6Y Yellow ink tank, BCI-3eBk Black ink tank
Buffer Ram 46KB
Paper Sizes Letter, legal, A4, A5, 4" x 6", 5" x 7", U.S. #10 or European envelopes
Automatic Sheet Feeder 150 sheets @ paper weight 17 lb.
Paper Compatibility Plain paper, Envelopes, Glossy Photo Paper, High Resolution Paper, Matte Photo Paper, Photo Paper Plus Glossy For Borderless Printing (4" x 6"), Photo Paper Plus Glossy (5" x 7"), Photo Paper Plus Glossy (8.5" x 11"), Photo Paper Pro (4" x 6"), Photo Paper Pro For Borderless Printing (4" x 6"), Photo Paper Pro (8.5" x 11"), Transparencies, T-Shirt Transfers
Paper Handling Plain Paper - 150 sheets Envelopes - 10 Glossy Photo Cards (4" x 6") - 20 sheets Glossy Photo Paper (8.5" x 11") - 1 sheet High Resolution Paper (8.5" x 11") - 80 sheets Matte Photo Paper (8.5" x 11") - 10 sheets Photo Paper Plus Glossy For Borderless Printing (4" x 6") - 20 sheets Photo Paper Plus Glossy (5" x 7") - 10 sheets Photo Paper Plus Glossy (8.5" x 11") - 10 sheets Photo Paper Pro (4" x 6") - 20 sheets Photo Paper Pro For Borderless Printing (4" x 6") - 20 sheets Photo Paper Pro (8.5" x 11") - 10 sheets Transparencies (8.5" x 11") - 30 sheets
Noise Level Approx 39 dB(A) in best quality mode
Physical Dimensions 16.5" W x 6.8" H x 10.8" D
Weight 7.5 lbs.
Power Source 120V AC, 60Hz
Warranty 1-year limited warranty with InstantExchange warranty program (InstantExchange warranty program is subject to certain conditions and restrictions. See www.canontechsupport.com for details.)
Software Included CD-ROM including Printer Driver, Setup Software and User's Guide, Quick Start Guide, PictBridge Instruction Sheet, Electronic User's Guide, Photo Application Guide, e-registration, Easy-PhotoPrint (Windows/Mac), PhotoRecord (Windows), ZoomBrowser EX (Windows), ImageBrowser (Mac), PhotoStitch (Windows/Mac), Easy-WebPrint (Windows, requires Microsoft Internet Explorer version 5.5, version 6.0 recommended)
 Prices and specifications subject to change without notice. Actual prices are determined by individual dealers and may vary.
* PPM print speed based on highest speed printer driver setting. 4" x 6" photo print speed based on default printer driver mode using Canon Photo Paper Pro. Print speeds will vary depending on system configuration, software, document complexity, print mode and page coverage.
** Resolution may vary based on printer driver setting. Ink droplets can be placed with a minimum pitch of 1/4800 inch.
*** Will vary based on composition of images/documents printed.
 For a listing of select Canon digital cameras and camcorders featuring Bubble Jet Direct or PictBridge direct printing technology, visit www.usa.canon.com/consumer/directprint. To determine if a non-Canon brand camera or camcorder is PictBridge-compatible please consult the manufacturer.
&#134;&#134;&#134; Easy-PhotoPrint, ImageBrowser and PhotoStitch are not supported on Mac OS 8.6. Easy-WebPrint, Easy-PhotoPrint and PhotoStitch are compatible with Windows XP and Windows 2000/Me/98 only. Easy-WebPrint requires Microsoft&reg; Internet Explorer version 5.5, version 6.0 recommended. See www.canontechsupport.com for updated compatibility.
 System requirements vary by application.
Limited Warranty & Repair Program Details Canon U.S.A., Inc. Limited Warranty --- (USA Only)
The limited warranty set forth below is given by Canon U.S.A., Inc. ("Canon USA") with respect to the new or refurbished Canonbrand product ("Product") packaged with this limited warranty, when purchased and used in the United States only.
The Product is warranted against defects in materials and workmanship under normal use and service (a) for a period of one (1) year from the date of original purchase when delivered to you in new condition in its original container or (b) for (1) year from the date of original purchase for refurbished Products. Product returned to a Canon USA repair facility or a Canon USA Authorized Service Facility ("ASF"), and proven to be defective upon inspection will be (a) repaired utilizing new, remanufactured, repaired and/or recycled parts (b) exchanged for new or; © exchanged for a refurbished Product, as determined by the Canon USA repair facility or the ASF. Warranty repair or replacement shall not extend the original warranty period of the Product. A dated proof of purchase is required at the time of warranty service. A copy of your dated bill of sale will satisfy this requirement. This warranty does not cover any accessories, or any consumables, such as paper or ink cartridges, as to which there shall be no warranty or replacement.
This limited warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software. Canon USA shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty ("Separate Warranty"). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. NonCanon brand equipment and software that may be distributed with the Product are sold "as is" and without warranty of any kind by Canon USA, including any implied warranty regarding merchantability or fitness for a particular purpose, and all such warranties are disclaimed. The sole warranty, if any, with respect to such non-Canon brand items is given by the manufacturer or producer thereof.
(a) Loss of or damage to the Product due to abuse, neglect, mishandling, improper packaging by you, alteration, accident, electrical current fluctuations, improper use, failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon USA's user's manual or other documentation, or services performed by someone other than a Canon USA repair facility or ASF. Without limiting the foregoing, dropping the Product, scratches, and abrasions will be presumed to have resulted from misuse, abuse or failure to operate the Product as set forth in the user's manual or other documentation for the Product.(b) Use of parts, media, software or supplies (other than those sold by Canon USA), including non-Canon ink cartridges or refilled ink cartridges, that cause damage to the Product or cause abnormally frequent service calls or service problems.© If the Product has had its serial number or dating defaced, altered or removed.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE DISKETTES OR CDROMS ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD "AS IS" AND WITHOUT WARRANTY BY CANON USA. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
Canon USA offers a full range of customer technical support* options:
Interactive troubleshooting, e-mail technical support, the latest driver downloads and answers to frequently asked questions (www.usa.canon.com/support)    Toll-free live technical support within the limited warranty Monday—Friday (excluding holidays) at 1-800-OK-CANON (1-800-652-2666)  Telephone Device for the Deaf (TDD-1-855-270-3277)  Repair or Exchange Service Options: In the event service is required for the Product during the limited warranty period, Canon USA offers two hardware support options:
Authorized Service Facility Carry—In / Mail-In Service
Canon USA's Carry-In/Mail-In Service provides repair or exchange, at Canon USA's option, through Canon USA's Authorized Service Facility (ASF) network. The name and telephone number of the ASF(s) near you may be obtained from Canon USA's Web site at www.usa.canon.com/support or by calling the Canon USA Customer Care Center at 1-800-828-4040, or any time while speaking to a technical support person. A Product covered by this limited warranty will be repaired or exchanged, as determined by Canon USA, and returned without charge by the ASF.
InstantExchange Service **
A Canon Customer Care Center or ASF technician will attempt to diagnose the nature of the problem and, if possible, correct it over the telephone. If the problem cannot be corrected over the telephone, and you elect the InstantExchange option, a reference number will be issued to you. You will be asked for the Product serial number and other information pertaining to your Product and for a ship—to location for the replacement Product (must include street address).
The Canon USA repair facility will ship out the replacement Product prepaid by Canon USA. After receipt of the replacement Product (with instructions and a prepaid waybill), follow the enclosed instructions on how to ship your product to the Canon USA repair facility. Your Product must be returned in the shipping carton in which the replacement Product was packed and include the reference number, A COPY OF YOUR DATED PROOF OF PURCHASE (BILL OF SALE), and a complete explanation of the problem. DO NOT INCLUDE ANY OTHER ITEMS WITH THE YOUR PRODUCT IN THE RETURN SHIPPING CARTON, AND BE SURE TO RETAIN YOUR PRINTHEAD, INK CARTRIDGE(S) AND TANK(S).
InstantExchange Service exchanges your Product with a replacement Product, which will normally be shipped the same day if your request for this service is by 3 p.m. E.T. Monday through Friday, except holidays. Canon USA does not guarantee same day shipment in the event of the occurrence of factors beyond its reasonable control. The replacement Product you receive may be a refurbished or reconditioned unit and will be covered for the balance of the period remaining on your original limited warranty. NOTE THAT BY USING THIS SERVICE YOU WILL KEEP THE REPLACEMENT PRODUCT THAT IS SENT TO YOU. CANON USA WILL RETAIN THE PRODUCT THAT YOU ORIGINALLY PURCHASED, WHICH SHALL BECOME THE PROPERTY OF CANON USA. InstantExchange warranty program service is available only during the express limitedwarranty period for your Product and only in the continental United States, Alaska and Hawaii during such period.
InstantExchange warranty service is subject to the availability of refurbished or new replacement units.
Canon U.S.A., Inc.
One Canon Park
Melville, NY 11747
USA
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
