Canon Support for imageCLASS D1320 | Canon U.S.A., Inc.
imageCLASS D1320
Technical support for this product is provided exclusively through our FAQs and Knowledge Base.
Please click FAQs or Knowledge Base and enter your search term to find a resolution to your inquiry.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
SELECT ERROR CODE
WINDOWS
macOS X
imageCLASS D1320 |
Products | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 | Tahoe 26 |
imageCLASS D1320 |
Printer Specifications
Printer Type | Monochrome Laser |
Print Speed | Up to 17 ppm (2-sided plain paper letter)2 Up to 35 ppm (1-sided plain paper letter)2 |
First Print Time | 6 seconds or less (letter) |
Printer Language | UFR II LT (Host-based) |
Print Resolution | Up to 600 x 600 dpi (1200 x 600 dpi quality) |
Maximum Print Size | Up to Legal |
Duplex Print | Yes |
Print Modes | Poster, Booklet, Watermark, Toner Save, Page Composer |
Print Memory | 128 MB (Shared) |
Direct Print from USB | JPEG, TIFF |
Copier Specifications
Copy Type | Monochrome Laser |
Copy Speed | Up to 35 ppm (letter) |
Duplex Copy Speed | Up to 17 cpm (letter) |
Copy Resolution | Up to 600 x 600 dpi |
Original Type | Text, Text/Photo, Text/Photo+, Photo |
Halftones | 256 Levels |
Warm-up Time | Approx. 17 seconds |
First Copy Time | Less than 8 seconds3 |
Recovery Time | 5 seconds or less |
Maximum Number of Copies | 99 copies |
Duplex Copy/Bind Time | 1 to 2 / Book, Calendar |
Reduction/Enlargement | 25%, 50%, 64%, 78% / 129%, 200%, 400% |
Zoom | 25 - 400% in 1% increments |
Copy Size | Platen: Up to Legal ADF: 5.5" x 5" to Legal |
Copy Features | Memory Sort 2 on 1 4 on 1 ID Card Copy |
Copy Memory | 128 MB (shared) |
Scanner Specifications
Scan Type | Color Contact Image Sensor (CIS) |
Color Depth | 24-bit |
Scan Resolution | Up to 600 x 600 dpi (optical) 9600 x 9600 (interpolated) |
Scan Size | Platen: Up to Legal ADF: 5.5" x 5" to Legal |
Duplex Scan | Yes |
Compatibility | TWAIN, WIA |
Output File Formats | Hi-Compression PDF, Searchable PDF, PDF, JPEG, TIFF, BMP, PNG4 |
Scan Features | Scan to USB Host 1.1 (PDF, JPEG, TIFF), Rotate Image |
Pull Scan | USB and Network |
Push Scan (Scan to pC) | USB and Network |
Paper Handling Specifications
Standard Paper Source(s) | 500-sheet cassette plus 50-sheet multipurpose tray1 |
Optional Paper Source(s) | 500-sheet cassette1 |
Document Feeder | 50-sheet duplex1 |
Paper Output | 150 sheets (face down) |
Paper Weight | 16-32 lb. bond (cassette) 16-51 lb. bond (multipurpose tray) |
Media Sizes | Letter, Legal, A4, A5, B5, Statement, Executive |
Media Types | Plain Paper, Heavy Paper, Bond Paper, Label, Small Documents (i.e. Index Card) |
Envelope Capacity | 5 envelopes (multipurpose tray) |
Envelope Types | Com 10, Monarch, DL, C5, B5 |
Connectivity and Software Specifications
Standard Interface(s) | USB Device 2.0 Hi-Speed5, 10/100 Base-T Ethernet |
Embedded Web Server (Remote UI) | Yes |
Web Browser Support for Remote UI | Microsoft Internet Explore 6.0 or higher, Safari 1.3.2 or higher |
Print Protocols | LPD, RAW, WSD |
Supported Network Protocols | TCP/IP v4, TCP/IP v6 (print only) |
TCP/IP Set of Application Services | DHCP, BOOTP, RARP, ARP+PING, Auto IP, Bonjour, HTTP, SHTTP, NetBIOS |
Network Management Protocols | SNMPv1, SNMPv36 |
MIB | RFC1213 (MIB-II), RFC1514 (Host Resources MIB), RFC1759 (Printer MIB), Canon MIB |
OS Compatibility | Windows® 8, Windows 7, Windows Server® 2008, Windows Vista®, Windows Server 2003, Windows XP/2000, Mac® OS X 10.4.9 & up, Linux (print only) |
Cable Included | Power Cord (USB not included) |
Bundled Software | Canon Drivers, MF Toolbox, Document Management & OCR Software |
Environmental Specifications
Power Consumption | Max: Approx. 1,100W During Operation: Approx. 550W Standby: Approx. 9W Energy Saver: Approx. 2.3W |
Typical Energy Consumption | 1.5kWh |
General Specifications
Dimensions | 17.8" (W) x 18.6" (D) x 18.4" (H) |
Unit Weight (without/with cartridge) | 45.3 lbs. (w/o cartridge) 47.1 lbs. (w/cartridge) |
Package Weight | Approx. 61.7 lbs. |
Cartridge Type | Cartridge 120 (Yields approximately 5,000 pages*) Single Cartridge System *Yields based on ISO/IEC Standard |
Department Counter | Yes |
LCD Display | 5-row backlit LCD w/ animation (fax installation, toner installation, paper jam) |
Duty Cycle | Up to 20,000 pages per month |
Department ID Management | Up to 300 IDs |
Security | IP Filtering, MAC Address Filtering |
Languages | English, French, Spanish, Portuguese |
Warranty | 1 year limited exchange/carry-in warranty7 (Extended warranty available) |
CANON imageCLASS SERIES EXCHANGE/CARRY-IN PRODUCT LIMITED WARRANTY
CARTRIDGES FOR THE PRODUCT (EXCEPT THE CARTRIDGE BUNDLED WITH THE PRODUCT, FOR WHICH THERE IS NO WARRANTY) ARE COVERED BY A SEPARATE WARRANTY. ACCORDINGLY, THIS LIMITED WARRANTY DOES NOT COVER ANY CARTRIDGES FOR THE PRODUCT, WHETHER SHIPPED WITH THE PRODUCT OR PURCHASED THEREAFTER.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads, and email support at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. Eastern Time (excluding holidays).
If the service or exchange is performed, and (1) the Product malfunction is not covered by this limited warranty, or (2) the applicable warranty period has expired or has not been sufficiently established by appropriate documentation, then you will be charged for such service at the then current service rates of Canon USA or the Service Provider, or for such exchange, as applicable. This warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment, and software. Canon USA shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty ("Separate Warranty"). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON USA, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
This warranty shall be void and of no force and effect if the Product is damaged as a result of (a) abuse, neglect, mishandling, alteration, electric current fluctuation or accident, (b) improper use, including failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon USA's operator's manual or other documentation, (c) installation or repair by other than authorized service representatives qualified by Canon USA who are acting in accordance with Canon USA's service bulletins, (d) use of supplies or parts (other than those distributed by Canon USA) which damage the Product or cause abnormally frequent service calls or service problems, or (e) use of the Product with non-compatible computers, peripheral equipment or software, including the use of the Product in any system configuration not recommended in any manual distributed with the Product. Nor does this warranty extend to any Product on which the original identification marks or serial numbers have been defaced, removed, or altered. ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE CD-ROM'S ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD "AS IS" AND WITHOUT WARRANTY BY CANON USA. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
NEITHER CANON USA NOR ANY SERVICE PROVIDER SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA, INCLUDING, WITHOUT LIMITATION, STORAGE CHARGES OR OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON USA OR ANY SERVICE PROVIDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA OR ANY SERVICE PROVIDER BE GREATER IN AMOUNT THAN THE PURCAHSE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER. THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT AND STATES SUCH PURCHASER'S EXCLUSIVE REMEDY.
Support options are subject to change without notice.
Click Here to download the D1300 Series Warranty Card.
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
