Canon Support for imageRUNNER 1643i | Canon U.S.A., Inc.
imageRUNNER 1643i
At Canon U.S.A., your satisfaction is our highest priority. To help you maintain business continuity, this product is supported directly by Canon U.S.A. as well as our Canon Authorized Dealer Network, which delivers high-quality service backed by Canon-certified technicians using Canon Genuine parts. For service and support, please contact your Canon representative or use the support finder below. Thank you.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
Model Name | imageRUNNER 1643i |
Type | Monochrome A4 Laser Multifunctional |
Functions | Print, Copy, Scan, Send |
Operation Panel | 5" TFT LCD WVGA Color Touch Panel |
Imaging System | Canon Dual Custom Processor (Shared) |
Image Server Memory | 1.0 GB RAM |
Network Interface Connection | 1000Base-T/100Base-TX/10-Base-T, Wireless LAN (IEEE 802.11 b/g/n), NFC (only 1643iF), Wi-Fi Direct Connection |
Other Interface | USB 2.0 (Host) x2, USB 2.0 (Device) x1 |
Max Mailboxes Supported | LDAP (50)/Local (300)/Speed Dial (281) |
Max Copy Reservation | Up to 600 x 600 |
Scanning Resolution | Up to 600 x 600 |
Printing Resolution | 600 × 600 |
Warm Up Time | From Power On: 14 seconds or Less2 From Sleep Mode: 4 Seconds or Less |
Power Requirements | 120-127 V, 60 Hz, 7.1 A |
Power Consumption | Maximum: 1,500 W Sleep Mode: 0.9W or Less5 |
Plug | NEMA 5-15P |
Dimension | 18-7/8" x 23-1/2" x 17-3/4" (480 mm x 595 mm x 452 mm) |
Installation Space | 27-3/8" x 43-1/2" (694 mm x 1105 mm) |
Weight | Approx. 41.9 lb. (19 kg) 3 |
Basic Copy Features | Preset R/E Ratios by Area, Paper Setting, Favorite Setting, Two-Sided, Density Adjustment, Original Type Selection |
Special Copy Features | Two-sided Original, Sort, Job Build, N on 1, Different Size Originals, Density Adjustment, Original Type Selection, Sharpness, Erase Frame, Copy ID Card |
Environmental Features | ENERGY STAR® Certified Rated EPEAT® Gold1 |
Advanced Box
Common Protocol | File: FTP (TCP/IP), SMB (TCP/IP) Email: SMTP, POP3 |
Max. Number of Concurrent Connections | One |
Memory Media
Standard | USB |
Scan Specifications
Network TWAIN Scan | Standard |
Network Scan Utility | ScanGear MF |
Copy/Print Speed (BW/Color)
Letter | Up to 45 ppm |
Legal | Up to 36 ppm |
Copy Specifications
First Copy Time | As fast as 6.0 Seconds (via Platen) |
Multiple Copies | Up to 999 |
Magnification | 25% - 400% (1% Increments) from Platen Glass |
Preset Reductions | 25%, 50%, 64%, 78% |
Preset Enlargements | 129%, 200%, 400% |
Acceptable Originals | Sheet, Book, 3-Dimensional Objects |
Maximum Original Size | Up to 8-1/2" x 1 |
Standard Paper Capacity | 550-sheet Paper Cassette |
Optional | 550-sheet PAPER FEEDER PF-C1 (up to 3) |
Manual Bypass | 100-sheet Stack Bypass |
Maximum Paper Capacity | 2,300 Sheets |
Output Paper Capacity | Maximum: 250 Sheets |
Output Sizes
Cassette | Letter, Legal, Statement, Executive |
Bypass | Letter, Legal, Statement, Executive, Custom size (3" x 5" to 8-1/2" x 14"), Envelope (C5/DL/ COM-10/Monarch) |
Acceptable Paper Weights
Cassette | 16 lb. Bond to 32 lb. Bond (60 to 120 g/m2) |
Bypass | 16 lb. Bond to 73 lb. Cover (60 to 199 g/m2) |
Duplexing
Duplexing | Duplexing Automatic Document Feeder |
Paper Size | 4-1/8" x 5" to 8-1/2" x 14" |
Paper Weight | Simplex: 13 lb. to 28 lb. Bond (50 to 105 g/m2) Duplex: 17 lb. to 28 lb. Bond (64 to 105 g/m2) |
Security Features
Standard | Authentication: Department ID Authentication and embedded Universal Login Manager with uinFLOW Online/Online Express,4 IP/ Mac Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication before SMTP, Secure Print, Encrypted PDF, Device Signature |
Optional | Authentication: uniFLOW |
Estimated Toner Yield | (Estimated Yield @ 5% Coverage) 20,500 Images |
