Canon Support for imageRUNNER 1670F | Canon U.S.A., Inc.
imageRUNNER 1670F
At Canon U.S.A., your satisfaction is our highest priority. To help you maintain business continuity, this product is supported directly by Canon U.S.A. as well as our Canon Authorized Dealer Network, which delivers high-quality service backed by Canon-certified technicians using Canon Genuine parts. For service and support, please contact your Canon representative or use the support finder below. Thank you.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
Model Name | imageRUNNER 1670F |
Type | Digital, Multifunction Imaging System |
Imaging System | Indirect Electrostatic Transfer |
Developing System | Dry Monocomponent Toner Projection |
Fixing System | Canon RAPID Fusing System |
Duty Cycle | Up to 20,000 impressions/month |
Image Server Memory | 16MB Standard/Max |
Max Copy Reservation | Up to memory capacity |
Scanning Resolution | 600 dpi x 600 dpi |
Printing Resolution | 600 dpi x 600 dpi |
Interpolated Resolution | 1200 dpi x 600 dpi (Copy) 2400 dpi x 600 dpi (Print) |
Halftone | 256 Gradations of Gray |
Letter | 16 cpm/ppm |
First Copy Time | 13 Seconds |
Multiple Copies | 1-99 |
Magnification | 50%-200%, in 1% increments |
Preset Reductions | 50%, 64%, 78% |
Preset Enlargements | 129%, 200% |
Acceptable Originals | Sheets, Books, 3 Dimensional Items (up to 4.4 lbs.) |
Maximum Original Size | 8-1/2"x14" |
Standard Paper Capacity | 1 x 500 Sheets |
Manual Bypass | 100 Sheets |
Maximum Paper Capacity | 600 Sheets |
Acceptable Paper Weights
Cassette | 17-20 lb. Bond |
Bypass | 15-32 lb. Bond |
Warm Up Time | 4.5 Seconds (From Power Plug-in) 1 Second (From Energy Saver Mode) |
Power Requirements | 120V/60Hz, 3.8A |
Dimension | 15-1/8" x 18-3/4" x 17-3/8" (384mm x 475mm x 442mm) |
Weight | 52.9 lb. |
Toner | GPR-10 Black Toner |
Estimated Toner Yield | 5,300 Images |
Drum | GPR-10 Drum Unit |
Estimated Drum Yield | 24,000 Impressions |
Feeders
Description | Automatic Document Feeder (Standard) |
Acceptable Originals | Statement to Legal |
Capacity | 30 Sheets |
Paper Weights | 14-32 lb. Bond |
Power Source | Directly from Main Unit |
ADDITIONAL SUPPORT
CONTACT US
