Canon Support for imageRUNNER 2525 | Canon U.S.A., Inc.
imageRUNNER 2525
At Canon U.S.A., your satisfaction is our highest priority. To help you maintain business continuity, this product is supported directly by Canon U.S.A. as well as our Canon Authorized Dealer Network, which delivers high-quality service backed by Canon-certified technicians using Canon Genuine parts. For service and support, please contact your Canon representative or use the support finder below. Thank you.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
| Model Name | imageRUNNER 2525 |
| Type | Monochrome Digital Multifunction Imaging System Functions Standard: Copy, Print (UFR II LT), Scan Optional: Print (PCL, PostScript 3 Emulation), Send (Color Send, Searchable PDF), Fax Operation Panel 5.7" QVGA Black-and-White LCD Touch-Screen |
| Image Server Memory | Standard: 512MB RAM Maximum: 512MB RAM Network Interface Connection Ethernet 10/100Base-TXOther Interface Standard: USB 2.0 (Host)x1, USB 2.0 (Device)x1 Optional: USB 2.0 (Host)×3 (USB Application 3-Port Interface Kit-A1), Serial Interface, Copy Control Interface |
| Letter | Up to 25 ppm |
| Legal | Up to 13 ppm |
| Ledger | Up to 15 ppm |
| First Copy Time | 5.4 Seconds (Letter) |
| Multiple Copies | 1 to 999Copy Exposure Automatic or Manual (9 Levels) |
| Magnification | 25% - 400% (1% Increments) |
| Preset Reductions | 25%, 50%, 64%, 73%, 78% |
| Preset Enlargements | 121%, 129%, 200%, 400%Basic Copy Features Preset R/E Ratios by Area, Finishing, Two-sided, Exposure Adjustment, Original Type Selection Special Copy Features ID Card Copy, Two-page Separation, Image Combination, Frame Erase, Different Size Original, Sharpness, Mode Memory, Booklet |
| Standard Paper Capacity | (20 lb. Bond): Dual 550-sheet Paper Cassettes 100-sheet Stack Bypass Optional: Dual 550-sheet Paper Cassettes |
| Maximum Paper Capacity | 2,300 Sheets Output Paper Capacity (20 lb. Bond): Standard: 250 Sheets (Inner Tray) Maximum: 1,100 Sheets (w/Inner Finisher-B1 and Inner Finisher Additional Tray-B1) |
Output Sizes
| Cassette | Cassette 1/3/4: 11" x 17", Legal, Letter, Letter-R, Statement-R, Executive Cassette 2: 11" x 17", Legal, Letter, Letter-R, Statement-R, Executive, Envelopes (COM10 No.10/Monarch/DL/ISO-B5/ISO-C5)* |
| Bypass | 11" x 17", Legal, Letter, Letter-R, Statement-R, Executive, Envelopes, Custom Size |
Acceptable Paper Weights
| Cassette | 17 lb. Bond to 24 lb. Bond |
| Bypass | 17 lb. Bond to 34 lb. Bond Special Media Support Cassette 2: Envelopes Bypass: Transparencies, Labels, Envelopes |
| Warm Up Time | From Power On: 30 Seconds or Less From Sleep Mode: 1 Second or Less |
| Power Requirements | 120V AC, 60Hz, 6.9APlug NEMA 5-15PPower Consumption Maximum: 1,473W; Sleep Mode: 1W |
| Dimension | (with DADF): 35-1/4" x 22-1/4" x 27-1/4" (with Platen Cover): 31-3/4" x 22-1/4" x 26-3/4"Installation Space (W x D) 42-1/2" x 56-3/4" (with no optional equipment attached) 54" x 56-3/4" (with optional Inner Finisher-B1 attached) |
| Weight | Approximately 156 lb. (Main Unit)** Approximately 172 lb. (with DADF)** |
| Estimated Toner Yield | 14,600 Copies/Bottle (Estimated @ 6% Coverage) Scan Specifications Network TWAIN Scan Standard Network Scan Utility Color Network Scan Gear Print Features Watermark, Page Border, Header/Footer, Page Layout, Two-sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing on Transparencies, Front/Back Covers, Toner Reduction, Poster Printing, Generic PCL 6 Driver Security Specifications Department ID Management, User ID Management, IPv6, Restricting Features (Restricting the Send Function, Restricting New Addresses on Address Book, Address Book Password, Allow Fax Driver TX, Restrict Recall, Confirm Entered Fax Numbers, Restrict Sequential Broadcast), SNMPv1, MAC/IP Address Filtering, SMTP Authentication, POP Authentication before SMTP Environmental Information EPEAT Silver ENERGY STAR® Qualified RoHS Compliant Ecomark Blue Angel WEEE Directive |
Feeders
| Description | DADF-AB1• |
| Acceptable Originals | 11" x 17", Legal, Letter, Letter-R, or Statement Scan Method: Duplexing Automatic Document Feeder |
| Scanning Speed | (BW/Color; Letter): Copy: 25 ipm (600 dpi) Scan: 35/25 ipm (300 dpi) |
| Capacity | 50 Sheets (Letter) |
| Paper Weights | 14 lb. Bond to 28 lb. Bond 28 lb. Bond to 34 lb. Bond when scanning a single-page document |
| Power Source | From the Main Unit/Approximately 27.1W (Maximum) |
| Dimensions | 5" x 21-3/8" x 22-1/4" |
| Weight | Approximately 15.4 lb. |
Paper Supply Options
| Description | Cassette Feeding Unit-AE1 |
| Paper Capacity | 550 Sheets x 2 Cassettes (20 lb. Bond) |
| Paper Sizes | 11" x 17", Legal, Letter, Letter-R, Statement-R, Executive Acceptable Paper Type: Plain, Recycled, Color, Pre-Punched |
| Paper Weights | 17 lb. Bond to 24 lb. Bond |
| Power Source | From the Main Unit/Approximately 17.4W (Maximum) |
| Dimensions | 9-3/4" x 22-1/4" x 26-3/4" |
| Weight | Approximately 52.9 lb. |
| Description | Envelope Feeder Attachment-D1†† |
| Paper Capacity | 50 Sheets (or 30mm in height) |
| Paper Sizes | (Acceptable Envelope Size:) COM10 No.10, Monarch, DL, ISO-B5, ISO-C5 Print Speed: Up to 10 ppm |
next to your download
