Canon Support for imageRUNNER ADVANCE C356iF II | Canon U.S.A., Inc.
At Canon U.S.A., your satisfaction is our highest priority. To help you maintain business continuity, this product is supported directly by Canon U.S.A. as well as our Canon Authorized Dealer Network, which delivers high-quality service backed by Canon-certified technicians using Canon Genuine parts. For service and support, please contact your Canon representative or use the support finder below. Thank you.
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
SELECT ERROR CODE
Model Name | imageRUNNER ADVANCE C356iF II |
Type | Color Laser Multifunctional |
Functions | Print, Copy, Scan, Send, Store, Fax (Line One Standard, Line Two Optional) |
Operation Panel | 10.1" TFT LCD WSVGA Color Flat-panel |
Image Server Memory | 3.0 GB RAM |
Hard Disk Drive | 250 GB |
Network Interface Connection | 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 b/g/n) |
Other Interface | Standard: USB 2.0 x1 (Host), USB 3.0 x1 (Host), USB 2.0 x1 (Device) Optional: Serial Interface, Copy Control Interface |
Max Mailboxes Supported | 100 User In-boxes, 1 Memory RX In-box, 50 Confidential Fax In-boxes |
Max Pages Stored | 30,000 Maximum Pages Stored |
Warm Up Time | From Power On: 30 Seconds From Sleep Mode: 10 Seconds Quick Startup Mode: 4 Seconds1 |
Power Requirements | 120-127V AC 60 Hz, 6.9 A |
Power Consumption | Maximum: Approx. 1.5 kWh Standby: Approx. 38.9 W Sleep Mode: Approx. 0.8 W9 0.7 kWh |
Plug | NEMA 5-15P |
Dimension | Standard(Desktop):20-1/8" x 25-5/8" x 25-1/8"(511 mm x 651 mm x 639 mm) With CassetteFeeding Unit-AJ1 or AK1:20-1/8" x 25-5/8" x 41-7/8(511 mm x 651 mm x 1,064 mm) |
Installation Space | Basic: 33-1/2" x 35-3/4" (852 mm x 908 mm) With Staple Finisher-Z1: 55-3/8" x 35-3/4" (1,407 mm x 908 mm) |
Weight | Standard (Desktop): Approx. 108 lb. (49 kg) With Cassette Feeding Unit- AJ1: Approx. 143.3 lb. (65 kg) With Cassette Feeding Unit- AK1: Approx. 149.9 lb. (68 kg) With Cassette Module AE-1: Approx. 130.1 lb. (59 kg)2 |
Basic Copy Features | Preset Reduction/Enlargement Ratios by Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two- Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel |
Special Copy Features | Two-Sided Original, Finishing, Job Build, N on 1, Density Adjustment, Original Type Selection, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Job Done Notice, Copy ID Card, Multi Sheet Feed Detection |
Advanced Box
Available Disk Space | Approx. 16 GB |
Common Protocol | SMB or WebDAV |
Supported Client PC | Windows (Windows Vista/7/8/8.1/10) |
Max. Number of Concurrent Connections | SMB: 64 WebDAV: 3 (Active Sessions) |
Advanced Box Features | Disabling Advanced Box, Storage Filtering, Authentication for Advanced Box Log-in, Search Function, Sort Function, Printing a PDF File with a Password, imageWARE Secure Audit Manager Support |
Memory Media
Standard | Standard: USB |
Copy/Print Speed (BW/Color)
Letter | Up to 36 ppm |
Legal | Up to 29 ppm |
Copy Specifications
First Copy Time | As fast as 6.9 seconds (BW)/ 9.4 seconds (Color) |
Multiple Copies | Up to 999 copies |
Copy Exposure | Automatic or Manual (9 Levels) |
Magnification | 25%-400% (1% Increments) |
Preset Reductions | 25%, 50%, 64%, 78% |
Preset Enlargements | 129%, 200%, 400% |
Acceptable Originals | Sheet, Book, 3-Dimensional Objects [Up to 4.4 lb. (2 kg)] |
Standard Paper Capacity | 650 Sheets |
Maximum Paper Capacity | 2,300 Sheets |
Output Paper Capacity | (LTR, 20 lb. Bond): Standard: 250 Sheets Maximum: 500 Sheets (with STAPLE FINISHER-Z1) |
Output Sizes
Cassette | Legal, Letter, Executive, Statement, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (3-7/8" x 7-1/2" to 8-1/2" x 14") |
Bypass | Legal, Letter, Executive, Statement, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Envelope Custom Size (3-7/8" x 5-7/8" to 8-1/2" x 14"), Custom Size (3-7/8" x 5-7/8" to 8-1/2" x 14") |
Other Option | Cassette Module-AE1: Legal, Letter, Executive, Statement, Custom Size (3-7/8" x 7-1/2" to 8-1/2" x 14") Cassette Feeding Unit-AJ1: Legal, Letter, Executive, Statement, Custom Size (3-7/8" x 7-1/2" to 8-1/2" x 14") Cassette Feeding Unit-AK1: Legal, Letter, Executive, Statement, Custom Size (3-7/8" x 7-1/2" to 8-1/2" x 14") |
Acceptable Paper Weights
Cassette | 16 lb. Bond to 60 lb. Cover (60 to 163 g/m2) |
Bypass | 16 lb. Bond to 80 lb. Cover (60 to 220 g/m2) Duplexing: 16 lb. Bond to 60 lb. Cover (60 to 163 g/m2) |
Duplexing
Duplexing | Single-pass Duplexing Automatic Document Feeder |
Paper Size | Legal, Letter, Statement |
Paper Weight | BW Original: 13 lb. Bond to 34 lb. Cover (50 to 128 g/m2) CL Original: 17 lb. Bond to 34 lb. Cover (64 to 128 g/m2) |
Toner | GPR-58 Toner |
Estimated Toner Yield | (Estimated @ 5% Coverage): Black: 23,000 Images Color (C,M,Y): 18,000 Images FOOTNOTES: Time from device power-on to when copy jobs can be programmed. Includes consumables. PDF print from Web sites is supported. Requires the optional PCL International Font Set-A1. Requires the optional Barcode Printer Kit-D1. Other operating systems and environments including AS/400, UNIX, Linux and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative. 0.8 W sleep mode not available in all circumstances due to certain settings. For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net. Will launch at a later date. Used for corner/double stapling only. 2 cartridges per case. 5,000 staples per cartridge. |
