Canon Support for LX-D1300 Dye-Based Inkjet Label Printer | Canon U.S.A., Inc.
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 10.12.23
File Size 8.44 MB
Date 01.14.25
File Size 6.72 MB
Date 05.17.18
File Size 7.15 MB
Date 01.14.25
File Size 8.41 MB
Date 01.14.25
File Size 7.77 MB
Date 10.12.23
File Size 7.99 MB
Printer
Printing Method Dye-based Inkjet
Print Speed (up to) First Print Out Time: 2" x 3" Label: 8 seconds or less1
Default Print Speed: 120 mm/second (4.7 inches/second)1
Range: 50 - 120 mm/s1
Preset Options: 120, 80, 70, 60, 50 mm/s
Number of Nozzles 2,816 dots
Print Resolution (Up to) 1200x1200 dpi
Ink Compatibility 4 (1 x Black, 1 x Cyan, 1 x Magenta, 1 x Yellow)
Paper Sizes Width: 28.4 - 63.0 mm
Length: 25.4 - 400.0 mm
Maximum Printable Area Width: Up to 56 mm
Length: Up to 397 mm
Minimum Margin Top/Bottom Margin: 1.5 mm
Left/Right Margin: 3.5 mm
Paper Thickness 0.145 - 0.255 mm
Paper Compatibility Label Roll Media with Roll Holder (IJ Coated: Matte or Glossy)
Roll Paper Maximum Outer Diameter Outer Diameter: Up to 75 mm, Core/Inner Diameter: Up to 25.4 m
Body Durability 300,000 Sheets / 5 Years2
Estimated Output Number Approx. 4,000 Sheets per cartridge set2
General
OS Compatibility Windows 10 (64/32 bit), 8.1 (64/32 bit), 7 SP1 (64/32 bit)3
Standard Interface USB 2.0
Ethernet (10/100/1000Base-T)
Power Source AC 100-240v, 50/60 Hz
Power Consumption (approx.) Maximum: Approx. 85.0 W
Operating: Approx. 22.0 W (Average)
Sleep Mode: Approx. 6.0 W or Less
Dimension (W x D x H) 5.3" (W) x 9.8" (D) x 9.8" (H)
Weight 11.02 lbs.
Operating Temperature: Temperature: 41&deg; - 95&deg;F (5&deg; - 35&deg;C)
Operating Humidity: Humidity: 10-90% RH (Non-Condensing)
Noise Acoustic Information
Operating Noise (Max.): 50dB or less4
Standby Noise: 30dB or less4
Warranty 1 Year Warranty5
Auto Cutter Unit Built-In
Cartridge Fill Volume Black / Cyan / Magenta / Yellow: 14.5 ml
Maintenance Cartridge Info & Fill Volume WT-X201 Maintenance Cartridge2Approx. 45,000 Sheets2
Operational Method LCD: No
Buttons/LEDs: 2 Buttons / 7 LEDs
Optional Hardware Module RH-L02 Roll Holder
CANON LX-SERIES LABEL PRINTER LIMITED WARRANTY
The limited warranty set forth below is given by Canon U.S.A., Inc. ("Canon") with respect to the Canon LX-D5500/LX-P5510/LX-P1300/LX-D1300 Inkjet Label Printer packaged with this limited warranty and Canon branded accessories and options designed for use with the Canon LX-D5500 LX-P5510/LX-P1300/LX-D1300 Inkjet Label Printer (collectively, the "Product"). Canon warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of one (1) year after delivery to the original purchaser (“Purchaser”) by Canon or its authorized dealer. During the relevant warranty period, Canon shall, in its sole discretion and without charge, repair or replace any defective part with a new or comparable rebuilt part or replace the Product with a new or rebuilt Product. Warranty replacement shall not extend the warranty period of the defective Product. This warranty does not cover consumable parts or consumables, such as paper and ink cartridges, as to which there shall be no warranty or replacement.
For remote diagnostic assistance for operation and support of the Product, call:
  • Your local Service Provider; or
  • 1-855-852-2666, Monday through Friday from 8 a.m. to 8 p.m. ET (excluding Canon holidays).
You must cooperate with Canon in remotely diagnosing the Product’s malfunction. Canon may attempt to correct the malfunction remotely, with your assistance. If Canon cannot fix your Product’s malfunction through remote diagnostics, Canon shall schedule an on-site service call by an independent authorized Canon Service Provider (the "Service Provider") or Canon will send you a replacement part for any defective user replaceable item. You will be charged at the then-current service call rates of Canon or the Service Provider if the defects in the Product are not covered by this limited warranty, or if the applicable warranty period for the Product has expired or warranty coverage has not been sufficiently established by appropriate documentation.
This warranty shall only apply if this Product is used in conjunction with compatible computers, peripheral equipment and software, as to which items Canon shall have no responsibility. NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
THIS WARRANTY SHALL BE VOID AND OF NO FORCE AND EFFECT IF THE PRODUCT IS DAMAGED AS A RESULT OF (A) ABUSE, NEGLECT, MISHANDLING, ALTERATION, ELECTRIC CURRENT FLUCTUATION OR ACCIDENT, (B) IMPROPER USE, INCLUDING FAILURE TO FOLLOW OPERATING OR MAINTENANCE INSTRUCTIONS IN, OR ENVIRONMENTAL CONDITIONS PRESCRIBED IN, CANON’S USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT, (C) REPAIR BY OTHER THAN SERVICE REPRESENTATIVES QUALIFIED BY CANON WHO ARE ACTING IN ACCORDANCE WITH CANON’S SERVICE BULLETINS (D) USE OF SUPPLIES OR PARTS (OTHER THAN THOSE DISTRIBUTED BY CANON), INCLUDING NON-CANON INK CARTRIDGES OR REFILLED INK CARTRIDGES, WHICH DAMAGE THE PRODUCT OR CAUSE ABNORMALLY FREQUENT SERVICE CALLS OR SERVICE PROBLEMS OR (E) USE OF THE PRODUCT WITH NON-COMPATIBLE COMPUTERS, PERIPHERAL EQUIPMENT OR SOFTWARE, INCLUDING THE USE OF THE PRODUCT IN ANY SYSTEM CONFIGURATION NOT RECOMMENDED IN ANY USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT. NOR DOES THIS WARRANTY EXTEND TO ANY PRODUCT ON WHICH THE ORIGINAL IDENTIFICATION MARKS OR SERIAL NUMBERS HAVE BEEN DEFACED, REMOVED, OR ALTERED.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE MEDIA ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD “AS IS” AND WITHOUT WARRANTY BY CANON. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
CONDITIONS OF WARRANTY
Canon U.S.A., Inc.
One Canon Park
Melville, NY 11747
USA
Canon is a registered trademark of Canon Inc.
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
