Canon Support for MultiPASS MP390 | Canon U.S.A., Inc.
MultiPASS MP390
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
MultiPASS MP390 User's Guide
File Name
MultiPASS MP390 Software Guide
File Name
MultiPASS MP390 Set-Up Sheet
File Name
MultiPASS MP390 Photo Application Guide
SELECT ERROR CODE
Printer
Printing Method | Color Bubble Jet |
Print Speed (up to) | Black:18 ppm Color:12 ppm* |
Print Resolution (Up to) | Black:600 x 600 dpi Color:4800 x 1200 dpi** |
Ink Compatibility | BCI-24 Black Ink Tank, BCI-24 Color Ink Tank |
Paper Sizes | Letter, legal, 4" x 6", 5" x 7", U.S. #10 envelopes |
Paper Handling | Plain Paper - 100 sheets Transparencies - 30 sheets Envelopes - 10 Photo Paper Pro 4" x 6" - 20 sheets Photo Paper Pro 8.5" x 11" - 10 sheets |
Copier
Copy Resolution (up to) | 600 x 600 dpi |
Copy Speed (up to) | 18 cpm |
Reduction / Enlargement | 25% to 400% |
Copy Features | Borderless Copy, 2 on 1, Image Repeat, Fit-to-Page |
Scanner
Scanning Element | CCD |
Max. Resolutions | Optical:1200 x 2400 dpi Interpolated:9600 x 9600 dpi |
Color Depth | Max. 48-bit internal |
Max. Document Size | 8.5" x 11.7" |
Fax
Modem Speed | up to 33.6 Kbps |
Transmission Speed (approx.) | Black - approx. 3 seconds/page***; Color - approx. 1 minute/page**** |
Memory Capacity | 200 pages (based on ITU-T Chart #1, standard mode) |
Fax Resolution | Black - 203 x 196 dpi (fine mode); Color - 200 x 200 dpi |
Speed Dialing | Speed Dials - 40 Directory Dials |
Receive Mode | Fax only, Fax/Tel Auto Switch, Manual, Answering, DRPD |
Photo Connect
Interface | Built-in memory card slots, Bubble Jet Direct or PictBridge direct printing |
Media Card Support | CompactFlash®, SmartMedia®, SD Secure Digital, Memory Stick®, MultiMediaCard, MicroDrive®, xD-Picture Card, and miniSD card |
General
OS Compatibility | Windows® 7, Windows ® XP/2000/Me/98 |
System Requirements | Windows: Windows XP: Pentium® 300Mhz/64MB RAM Windows 2000: Pentium 233MHz/64MB RAM Windows Me: Pentium 233MHz/64MB RAM Windows 98: Pentium 233MHz/64MB RAM Common:Microsoft® Internet Explorer 4.01/SP2 65MB hard-disk space |
Standard Interface | USB 2.0 Hi-Speed;, Direct Print Port |
Software Included | Setup CD Includes: MP Driver, MP Toolbox, Easy-PhotoPrint, Easy-PhotoPrint Plus, Easy-WebPrint (requires Microsoft Internet Explorer version 5.5, version 6.0 recommended), ArcSoft® PhotoStudio®, ScanSoft® OmniPage® SE (OCR), electronic Software Guide and Photo Application Guide |
Dimension (W x D x H) | 17.9" x 21.5" x 11.3" (with attachments); 17.9" x 14.1" x 9.8" (without attachments) |
Weight | 18.1 lbs (with attachments) |
Warranty | 1-year telephone support (90 days toll free from time of first call). Subject to certain terms and conditions. See www.canontechsupport.com for details. |
Prices and specifications subject to change without notice. Actual prices are determined by individual dealers and may vary. * PPM print speed based on the highest printer driver setting. Print speed will vary depending on system configuration, software, document complexity, print mode and page coverage. ** Ink droplets can be placed with a pitch of 1/4800 inch at minimum. Resolution may vary based on printer driver setting. *** Approximate 3-seconds-per-page fax transmission time is based on ITU-T Chart #1 (MMR/standard mode) at 33.6 Kbps modem speed when transmitting to another V.34 fax machine. The Public Switch Telephone Network (PSTN) currently supports 28.8 Kbps modem speed or lower depending on telephone line conditions. **** Based on Canon Color Fax Test Sheet. CPM copy speed based on fast mode when copying a letter sized document. USB 2.0 Hi-Speed performance requires Windows XP Service Pack 1 or Windows 2000 Service Pack 4 with pre-installed USB 2.0 port. Requires xD Picture Care to Compact Flash adapter and miniSD card requires miniSD to SD Secure Digital card adapter. Based on Canon Inc. industry-standard testing, using a Pentium 4, 1.7GHz, 256MB RAM, scanning an approximate 8.5" x 11" image at 600 dpi. Results may vary. |
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
