Canon Support for Optura 40 | Canon U.S.A., Inc.
Optura 40
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
DV Messenger Ver 1.0 Instruction Manual
File Name
OPTURA40 OPTURA30 Instruction Manual
File Name
File Name
optura30_40_inst.pdf
SELECT ERROR CODE
Power Supply (rated) | 7.4 V DC |
Power Consumption (While recording AF="ON") | 3.4 W (using viewfinder) |
Power Consumption | 4.2 W (using LCD screen) |
Television System | EIA standard (525 lines, 60 fields) NTSC color signal |
Video Recording system | 2 rotary heads, helical scanning system DV system (Consumer digital VCR SD system) |
Digital Component Recording | Yes |
Audio Recording system | PCM digital sound:16-bit (48 kHz/2 ch.) 12-bit (32 kHz/4 ch.) |
Image Sensor | 1/3.4-inch CCD, approx. 2,200,000 pixels Effective pixels: tape approx. 1,230,000 pixels, card approx. 2,000,000 pixels |
Tape Format | Videocassettes bearing the MiniDV mark |
Tape Speed | SP: 3/4 ips (18.81 mm/sec.) LP: 1/2 ips (12.56 mm/sec.) |
Maximum Recording Time (with an 80-min. cassette) | SP: 80 min. LP: 120 min. |
Fast Forward/Rewind Time | 2 min. 20 sec. (with a 60-min. cassette) |
Lens | Optura 40: f=4.8-67.2, f/1.8-3.0, 14x power zoom; Optura 30: f=4.8-57.6, f/1.8-3.0, 12x power zoom |
Focusing System | TTL autofocus, manual focusing possible |
Focusing System | 3.3 ft (1 m); 0.39 in. (1 cm) on maximum wide angle |
Minimum Illumination | 1.1 lx (using the Night mode) |
Recommended Illumination | More than 100 lx |
Filter Diameter | 34 mm |
Viewfinder | 0.33-inch TFT color, approx. 113,000 pixels |
LCD Screen | 2.5-inch TFT color, approx. 123,000 pixels |
Microphone | Stereo electret condenser microphone |
DV Terminal | Special 4-pin connector (based on IEEE 1394) |
Video Terminal | 1 Vp-p/75 ohms unbalanced |
S-video Terminal | 1 Vp-p (Y signal), 0.286 Vp-p (C signal) |
Audio Terminal | Input level: -10 dBV/40 kohms or more, Output level: -10 dBV (47 kohm load)/3 kohms or less |
Operating Temperature range | 32 - 104° F (0 - 40° C) |
Dimensions | 3.0 x 3.2 x 5.3 in. (77 x 82 x 134 mm) |
Weight (not including lens and battery pack) | Approx. 1.3 lb. (585g) (camcorder body only) |
Memory Card
Recording Media | MultiMediaCard, SD Memory Card |
Image Format | Still image: JPEG (compression: Superfine/Fine/Normal) Movie: AVI (image data: Motion JPEG; audio data: WAVE (monaural)) |
File Format | Design rule for Camera File system (DCF), Exif 2.2 compliant, Digital Print Order Format (DPOF) compliant (only images marked for printing or transfer) |
ADDITIONAL SUPPORT
CONTACT US
