Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 03.05.10
File Size 6.23 MB
Date 01.01.04
File Size 500.84 KB
Date 07.11.07
File Size 4.50 MB
Date 01.01.04
File Size 454.90 MB
Date 01.01.04
File Size 500.84 KB
Date 04.19.10
File Size 277.0 KB
Date 04.19.10
File Size 4.0 MB
Date 04.19.10
File Size 375.0 KB
Date 04.19.10
File Size 402.0 KB
Date 04.19.10
File Size 3.46 MB
Date 04.19.10
File Size 416.0 KB
Date 04.19.10
File Size 359.0 KB
Date 04.19.10
File Size 1.16 MB
Power Supply (rated) 7.4 V DC (Battery). 8.4 V DC ( DC IN)
Power Consumption 4.5 W (using viewfinder); 5.7 W (using LCD screen)
Television System EIA standard (525 lines, 60 fields) NTSC color signal
Video Recording system 2 rotary heads, helical scanning system DV system (Consumer digital VCR-SD system) Digital component recording
Audio Recording system PCM digital sound: 16-bit (48 kHz/2ch); 12-bit (32 kHz/4ch)
Image Sensor 1/3.4" CCD (charge coupled device); ox 2,200,000 pixels (approx. 1,230,000 effective pixels-tape), (approx. 2,000,000 effective pixels-card)
Tape Format Videocassettes bearing the MiniDV mark
Tape Speed Sp: 3/4 ips (18.81 mm/sec); LP: 1/2 ips (12.56 mm/sec)
Maximum Recording Time (with an 80-min. cassette) SP: 80min; LP:120 min
Fast Forward/Rewind Time 2 min. 20 sec (with a 60 min cassette)
Lens f1.6-1.9, 11 x power zoom, f=4.2-47 mm (16.9 mode: F1.6 - 1.9, 10 x power zoom, f=4.7-47mm) (Tape); F1.8-2.8, 9x power zoom, f=5.2- 47mm (Card)
Focusing System TTL autofocus, manual focusing possible
Focusing System Tele: 3.3 ft (1m); Wide; 0.79 in (2cm), Card: 2.4 in. (6cm)
Minimum Illumination 1.3 Lux using the Night Mode during tape recording
Recommended Illumination More than 100 Lux
Filter Diameter 46mm
Viewfinder 0.33 in, color LCD (approx. 113,000 pixels)
LCD Screen 3.5 in. measured diagonally (approx. 246,000 pixels)
Microphone Stereo electret condenser microphone
DV Terminal Special 4-pin connector (based on IEEE 1394)
Video Terminal 1 Vp-p/75 ohms unbalanced
S-video Terminal 1Vp-p ( Y signal), 0.286 Vp-p (C signal)
Audio Terminal Input level: -10 dBV/40 kohm, unbalanced; Output level: -10 dBV, less than 3 kohms, unbalanced
Operating Temperature range 32-104&deg F (0-40&deg C)
Dimensions 3.2 x 3.5 x 7.9in (80 x 90 x 201 mm)
Weight (not including lens and battery pack) 1.6 lbs (725g)
Memory Card
Recording Media MultiMediaCard, SD Memory Card
Image Format Design rule for Camera File System (DCF)
Print Order format Digital Print Order Format (DPOP)
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
CONTACT US
