Canon Support for Speedlite EL-5 | Canon U.S.A., Inc.
Speedlite EL-5
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Software Development Kit
SELECT ERROR CODE
| Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
| Compatible Cameras | For compatibility information, please click here. | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Flash Coverage (Focal length; for 35mm full-frame) |
| Guide Number | The Guide No. is approximately 48.6 ft./14m at ISO 100. - When the extendable wide panel is pulled out, the flash coverage is 14mm. The maximum Guide No. is approximately 196.9 ft./60m at ISO 100 and 200mm flash coverage. - When the extendable wide panel is pulled out, the flash coverage is 14mm. |
| Maximum Energy | 76Ws | ||||||||||||||||||||||||||||||||||||||||||||||||||
| Flash Modes (Exposure Control Modes) |
* 1: Set automatically when the camera shooting mode is set to Basic Zone modes. * 2: Can only be set when the Speedlite is used as a sender in radio transmission wireless operation. * 3: Only groups set to E-TTL II / E-TTL autoflash. |
| Flash Exposure Compensation | ±3 stops, in 1/3-stop or 1/2-stop*1 increments. * The Speedlite's flash exposure compensation takes precedence if flash exposure compensation is performed by both the Speedlite and the camera. Users who prefer to enable flash exposure compensation by the camera should set flash exposure compensation by the Speedlite to 0. * 1: Corresponds to exposure level increments on the camera. |
| FEB | ±3 stops, in 1/3-stop or 1/2-stop*¹ increments. * FEB is automatically deactivated after three shots. * Can be used with flash exposure compensation and FE lock. * 1: Corresponds to exposure level increments on the camera. |
| FE Lock | Supported | ||||||||||||||||||||||||||||||||||||||||||||||||||
| FE Memory | Supported Stores the flash output of E-TTL II / E-TTL autoflash and automatically sets the stored output level if users switch the flash mode to manual flash. * Flash output may vary slightly between E-TTL autoflash and manual flash. Colors may vary between E-TTL autoflash and manual flash under the following conditions: * When the color temperature of the Speedlite light differs greatly from that of ambient lighting and flash exposure compensation is set toward the negative end. * When E-TTL balance is set to [Ambience priority]. Differences in colors between E-TTL autoflash and manual flash may be reduced by taking one of the follow steps: * Using the provided color filter. * Setting white balance to an option other than AWB. Set in P.Fn-04
| Number of Flashes | Approx. 3502,450 flashes. * With a fully charged Battery Pack LP-EL. * Based on Canon Testing Standards. |
| Recharge Time |
| Flash Range | Effective flash range with EF 50mm f/1.4 lens at ISO 100 [Light distibution: Standard]
| AF Assist Beam | System: LED AF-assist beam Compatible AF System:- Dual Pixel CMOS AF Light emitted: Visible Light (white LEDs) Effective Range (Approx.): At center: 2.032.8 ft./0.610.0m |
| Modeling Lamp | Supported The modeling lamp (LED turns on under the following conditions
Higher LED temperatue from prolonged illumination triggers the following safety functions
| Wireless Settings |
| Communication Functions |
* 2: Transmission range may be shorter depending on factors such as how units are arranged, the surrounding environment, and weather conditions. |
| Transmission Status Display |
| Wireless Firing Control | Wireless firing control via radio transmission
| E-TTL II / ETTL autoflash details |
| Manual flash details |
* 1: Minimum of 1/128 for high-speed sync. * 2: Speedlites not supporting minimum flash output of 1/1024 fire at a level close to 1/1024. |
| Stroboscopic flash details |
| Group firing details | Enables separate configuration of flash firing control conditions 1-3 below for each
groups (A, B, C, D, E), to combine multiple methods of flash firing control.
* Flash exposure compensation ±3 stops |
| Test flash | Available (Sender/Receiver) | ||||||||||||||||||||||||||||||||
| Modeling flash | Not available | ||||||||||||||||||||||||||||||||
| Modeling lamp | Available (Sender only) | ||||||||||||||||||||||||||||||||
| Remote control from a receiver | Functions on sender units that can be controlled remotely from receiver units: Remote release Test flash Modeling flash*1,2 * Sub-senders cannot be controlled remotely *1. Modeling flash is available with R6 Mark II serving as a receiver used both with other Speedlites featuring sender functionality and with cameras supporting modeling flash that are equipped with a conventional accessory shoe, such as the EOS-1D X Mark III. 2. In the arrangement described above, modeling flash can be activated from the camera (DOF preview button) |
| Type | Reflective memory LCD (normally black) |
| Size | Approx. 1.89(H) x 1.04(V) in. |
| Display Format | Dot-matrix display |
| Dot Count | Approx. 56,000 dots (320x176) |
| Power Source | Battery Pack LP-EL * AA/LR6 Alkaline Batteries and Ni-MH batteries cannot be used. |
| Battery Charger | Battery Charger LC-E6 /LC-E6E (sold separately) Car Battery Charger CBC-E6 (sold separately) |
| External Power Source | Not Supported |
| PC Terminal | Not Supported |
| Modeling Lamp - Illumination Time | Approx 4 hrs. 300 min. Continously * With Ph P.Fn-07 set to [2], and using a fully charged Battery Pack LP-EL |
| Dust-and-Water Resistance | Supported * Water-resistant performance to EOS R5 |
| Dimensions (W x H x D) | Approx 3.2" x 5.5" x 4.9" |
| Weight (Approx.) | 17.3 oz. (Body Only) 21.4 oz. (Body and Battery) |
| Light Distribution | Set in C.Fn-21
| Custom Functions | 14 Functions
| Personal Functions | 9 Functions
Canon Flashes Limited International Warranty
The Limited Warranty set forth below is given by Canon U.S.A., Inc. with respect to Canon Photographic Products purchased in the United States.
This Limited Warranty is only effective upon presentation of this warranty card and proof of purchase.
This Canon equipment is warranted against defective materials or workmanship for one year from the date of original purchase and is limited to repair, adjustment and/or replacement of defective parts.
Equipment covered by this Warranty will be repaired in the United States, WITHOUT CHARGE, by our Service Centers and Authorized Service Facilities.
When returning equipment for warranty service, the shipping charges must be prepaid and the equipment should be shipped in its original carton or box, or an equivalent, properly packed to withstand the hazards of shipment and be fully insured. A bill of sale, copy of this warranty card or other proof of purchase should be enclosed, as well as a description of the problem, film samples, etc. Repairs will be made and the equipment will be return shipped at NO CHARGE.
This warranty covers all defects encountered in normal use of the equipment, and does not apply in the following cases:
- loss of or damage to the equipment due to abuse causing deterioration, mishandling, accident or failure to follow operating instructions.
- if equipment is defective as a result of leaking batteries or liquid damage.
- if equipment has been serviced or modified by other than our Authorized Agents.
- Malfunction resulting from the use of accessories, attachments, product supplies, parts or devices (including, without limitation, batteries, film, lenses, flash attachments and other accessories) with this Canon photographic equipment that do not conform to Canon specifications.
- Damage resulting during shipment. (Claim must be presented and examined by the shipper.)
Equipment covered by this Warranty will be repaired in other countries:
a) by Service Centers located outside of the United States and Canada WITHOUT CHARGE. List of international service facilities included with equipment. b) by the participating Warranty Service Facilities located outside of the United States and Canada WITHOUT CHARGE, except for insurance, transportation, and handling charges. List of participating international service facilities included with equipment.
NO IMPLIED WARRANTY, INCLUDING MERCHANTABILITY, APPLIES TO THIS EQUIPMENT AFTER THE ONE YEAR PERIOD STATED ABOVE, AND NO OTHER EXPRESS WARRANTY OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THIS EQUIPMENT SHALL BIND THE UNDERSIGNED. SOME STATES DO NOT ALLOW LIMITATIONS ON HOW LONG AN IMPLIED WARRANTY LASTS. SO THE ABOVE LIMITATION MAY NOT APPLY TO YOU. NEITHER THE UNDERSIGNED NOR ANY OTHER PERSON, FIRM OR CORPORATION IS RESPONSIBLE FOR LOSS OF FILM OR PROJECTION BULB, OTHER LOSSES, EXPENSE OR INCONVENIENCES, OR FOR ANY CONSEQUENTIAL DAMAGES CAUSED BY THE EQUIPMENT. SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE LIMITATION OR EXCLUSION MAY NOT APPLY TO YOU. THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THIS EQUIPMENT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT.
This warranty gives you specific legal rights, and you may also have other rights which vary from stat to state.
This warranty is given by Canon U.S.A., Inc., with respect to equipment purchased in the United States.
next to your download
