Say goodbye to time-consuming post-editing and hello to perfect shots every time with our latest Cropping Guide feature. Designed to enhance your photography experience, Canon’s Cropping Guide provides on-screen guidelines that help you position your subjects with precision, ensuring consistent and professional results.
Why Cropping Guide?
  • Consistency: Whether you're capturing school photos, sports events, or any scenario where subjects need to stand in the same spot repeatedly, Cropping Guide ensures everyone is perfectly positioned.
  • Efficiency: Reduce the need for extensive post-editing. With on-screen guidelines, you can align your shots perfectly in real-time.
  • Versatility: Suitable for both vertical and horizontal compositions, Cropping Guide adapts to various shooting scenarios.
How It Works
  • Send Device: Send device to Canon’s service center for Cropping Guide to be unlocked.
  • Activate Cropping Guide: Simply select the Cropping Guide option from the menu.
  • Choose Your Guide: Select from different guides to suit your needs:
crop-marks
  • Guide 1: Top and bottom guidelines to fit the head size.
  • Guide 2: Smaller head size option.
  • Guide 3: Choose from three different head sizes.
  • Guide 4: Left and right guidelines for positioning fixtures like balls or rackets.
Picture Frame Compatibility
The outer frame of each guide corresponds to standard picture frame sizes (8"x10" or 5"x7"), making it easier to prepare your images for print.
Print Perfect Guides
For the 5" x 7" (left image) magenta lines show the sides, and cyan lines show the top/bottom and for the 8" x 10" (right image) the image goes all the way to the sides of the frame, and the  cyan top/bottom guides let you know how your image will come out on certain standard print sizes.
Crop Marks for your Feet
Perfect Foot Positioning
Use the bottom guideline for precise foot positioning, ensuring your subjects are always correctly aligned.
Enhance Your Workflow
The Cropping Guide feature is designed to streamline your workflow, making it ideal for professional photographers who require consistency and precision in every shot. Experience the ease and efficiency of on-the-spot alignment, and take your photography to the next level.
foots
Compatible Cameras
Cropping Guide is available for the R50, R10, R8, R7 and R6 Mark II camera models, ensuring you have access to this powerful tool no matter your equipment.
How to Get the Canon Cropping Guide Feature
Get it Pre-installed
Purchase one of the cameras below with the Cropping Guide firmware pre-installed.
Upgrade your Existing Camera
Send your camera in to a Canon Factory Service Center to purchase and install the Cropping Guide firmware.
