Firmware Notice: EOS C70: Version 1.0.7.1
Firmware Version 1.0.7.1 incorporates the following enhancements:
1. The following features are enabled when the following lenses are attached: CN-E14-35mm T1.7 L S:
‐ Displaying metadata, such as the model name and the focal distance of the lens attached.
- Displaying T number.
‐ Support for Peripheral Illumination Correction and Chromatic Lens Aberration Correction.
- Support for [Dual Pixel Focus Guide].
2. Enhances Clear Scan resolution.
3. Enables to change WFM size.
4. Enables to change Vector scope gain by touch.
5. Enables to change WFM/Vector scope transparency.
6. Improves AF performance.
- Enables tracking frame to change variably depending on subject.
- Enables to detect heads facing sideways or backwards, or in situations such as when wearing a helmet.
7. Adds [Select Subject] assignable function via control ring/dial.
Caution:
- Please use a commercially available SD/SDHC/SDXC memory card that is 512MB or greater to perform the firmware update.
- Firmware version 1.0.7.1 is for updating cameras running firmware version 1.0.0.1 - 1.0.6.1.If your camera's firmware is already version 1.0.7.1, it is not necessary to update the firmware. Once the camera is updated to the latest version, it cannot be restored to a previous version.
- Please refrain from loading menu settings generated using the most recent firmware version to a product running an old firmware version, as doing so may affect camera operations.
Support
Download Firmware Version 1.0.7.1.00 for the EOS C70.
To help obtain optimal performance of this camera, we recommend that you also download and install the most recent versions of Canon Software.
If you have not already done so, please register the EOS C70. By registering, we will be able to notify you via email about future announcements.
This information is for residents of the United States and its five territories only. If you do not reside in the USA or its five territories, please contact the Canon Customer Support Center in your region.
Thank you,
Customer Support Operations
Canon U.S.A., Inc.
Contact Information for Inquiries
Phone: 1-855-CINE-EOS (toll free) / 1-855-246-3367
TDD: 1-855-270-3277
Email: Canon4K@cits.canon.com
For additional support options: usa.canon.com/support
