Canon Support for Color imageCLASS MF628Cw | Canon U.S.A., Inc.
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 09.22.17
File Size 2.92 MB
Date 12.20.23
File Size 476.17 KB
Date 12.24.20
File Size 2.92 MB
Date 08.27.25
File Size 1.32 MB
Date 09.17.24
File Size 2.27 MB
Date 01.31.23
File Size 144.76 KB
Date 12.22.17
File Size 809.44 KB
Date 09.25.23
File Size 1.20 MB
Date 04.24.19
File Size 815.66 KB
Date 09.01.25
File Size 2.27 MB
Date 04.24.19
File Size 647.96 KB
Date 01.31.23
File Size 2.92 MB
Date 04.20.22
File Size 1.50 MB
Date 10.04.19
File Size 815.82 KB
Date 09.17.24
File Size 1.20 MB
Date 02.04.20
File Size 652.13 KB
Date 03.24.23
File Size 1.60 MB
Date 09.25.23
File Size 2.27 MB
Date 10.04.19
File Size 2.92 MB
Date 12.20.23
File Size 1.32 MB
Date 04.24.19
File Size 2.92 MB
Date 04.27.23
File Size 2.27 MB
Date 07.20.23
File Size 154.27 KB
Date 09.17.24
File Size 1.32 MB
Date 12.24.20
File Size 819.56 KB
Date 07.13.21
File Size 652.14 KB
Date 01.31.23
File Size 1.63 MB
Date 12.22.17
File Size 647.92 KB
Date 04.27.23
File Size 460.45 KB
Date 04.27.23
File Size 1.72 MB
Date 08.28.15
File Size 6.20 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
Wireless Setup How-To Videos
Products High Sierra V10.13 Mojave V10.14 Catalina V10.15 Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15
Printer Specifications
Printer Type Color Laser MFP
Print Speed Color/Black: Up to 14 ppm (1-sided, plain paper letter)1
First Print Time Color/Black: 18 seconds (letter)2
Printer Language UFR II LT (Host Based)
Print Resolution 600 x 600 dpi,
1200 x 1200 dpi equivalent
Maximum Print Size Up to Legal
Print Modes Poster, Watermark, Page Composer, Toner Saver
Print Memory 512 MB (shared)
Direct Print from USB via USB Host v1.1 Print File format: JPEG, TIFF
Copier Specifications
Copy Type Color Laser
Copy Speed LTR/A4: Up to 14ppm (1-sided, Black/Color )1
Copy Resolution Up to 600 x 600 dpi
Original Type Text/Photo/Map
Halftones 256 Levels
Warm-up Time 23 sec or less from power-on
First Copy Time Color/Black: Approx. 19 seconds (letter/A4)3
Recovery Time Approx. 8 sec
Maximum Number of Copies Up to 99 copies
Reduction/Enlargement 25 - 400% in 1% increments
Zoom 25 - 400% in 1% increments
Copy Size Platen: Up to Letter,
ADF: 5.5" x 5" to Legal
Copy Features Frame Erase,
Memory Sort,
2 on 1,
4 on 1,
ID Card Copy
Copy Memory 512 MB (shared)
Fax Specifications
Modem Speed Up to 33.6 Kbps4
Fax Resolution Up to 406 x 391 dpi
Transmission Time JBIG (approx. 3 seconds)
Memory Capacity Up to 512 pages5
Speed Dials Up to 281 dials
Group Dialing Max. 199 dials / Max. 199 destinations
Sequential Broadcasting Max. 310 destinations
Receive Modes FAX Only, Manual, Answering, Fax/Tel Auto Switch
Fax Features FAX Forwarding, Dual Access, Remote Reception, PC FAX(TX only), DRPD, ECM, Auto Redial, Fax Activity Reports, Fax Activity Result Reports, Fax Activity Management Reports, iFax Simple
Memory Backup Permanent fax memory backup. ( Backup with flash memory)
Activity Reports Activity Result & Activity Management
Fax Forwarding FAX -> FAX
Scanner Specifications
Scan Type Color Contact Image Sensor (CIS)
Color Depth 24-bit
Scan Resolution Optical: Up to 600 x 600 dpi
Driver(digital): Up to 9600 x 9600 dpi
Scan Size Platen: Up to Letter
Compatibility TWAIN, WIA (Scan Driver Compatibility)
Output File Formats JPEG, TIFF, PDF, Compact PDF, PDF (OCR)
Scan Features Scan to USB
Pull Scan Yes, USB and Network
Push Scan (Scan to pC) Yes, USB and Network
Paper Handling Specifications
Standard Paper Source(s) 150-sheet cassette, 1-sheet multipurpose tray6
Document Feeder 50-sheet simplex6
Paper Output 125 sheets (face down)
Paper Weight 16-58 lb. bond (cassette / multipurpose tray)
Media Sizes Letter, Legal, A4, A5, B5, Executive
Media Types Plain, Heavy, Recycled, Color, Coated,Transparency, Label, Envelope, Index
Envelope Capacity 10 envelopes (cassette), 1 envelope (multipurpose tray)
Envelope Types Com 10, Monarch, DL, C5, B5
Connectivity and Software Specifications
Standard Interface(s) USB Device 2.0 High-Speed, 10/100 Base-T Ethernet, Wi-Fi 802.11b/g/n Wireless7
WiFi Access Mode Infrastructure Mode
WiFi Authentication Methods Open System, Shared Key, WPA-PSK, WPA2-PSK
WiFi Encryption Modes WEP (64/128 bit), TKIP, AES
WPS Easy Setup Support Methods Push-button mode, PIN code mode
Mobile Functions Canon PRINT Business8, Apple AirPrint&trade;9, Mopria Print Service10, Google Cloud Print&trade;11
Network Functions Print, Copy, Scan, Fax, PC Fax, Print/Scan to USB
Embedded Web Server (Remote UI) Yes
Web Browser Support for Remote UI Microsoft Internet Explore 7.0 or higher, Safari 3.2.1 or higher
Print Protocols LPD, RAW, WSD-Print (IPv4,IPv6), WSD-Scan(IPv4,IPv6)
TCP/IP Set of Application Services Bonjour(mDNS), HTTP, HTTPS, DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6)
Network Management Protocols SNMPv1, SNMPv3 (IPv4,IPv6)
OS Compatibility Windows® 10, Windows® 8.1, Windows® 8, Windows® 7, Windows Server® 2012R2, Windows Server® 2012, Windows Server® 2008 R2, Windows Server® 2008, Windows Vista®, Windows Server® 2003, Mac® OS X 10.5.8 & up, Linux (print only)
Cable Included Power Cord, Telephone Cable (USB not included)
Bundled Software Printer driver, Fax driver, Scanner driver, Network Scan Utility, MF Scan Utility, Presto! PageManager
Environmental Specifications
Power Consumption Max: 900W or less.
During Operation: Approx. 400W
Standby: Approx. 20W.
Energy Saver: Approx. 2W
Typical Energy Consumption 0.4 kWh
General Specifications
Dimensions 17" (W) x 19.1"(D) x 16.9"(H)
Unit Weight (without/with cartridge) 52.9 lbs. (w/o cartridge),
57.3 lbs (w/cartridge)
Package Weight Approx. 67.2 lbs.
Cartridge Type Cartridge 131 H Black (Yields approximately 2,400 sheets)
Cartridge 131 Black (Yields approximately 1,400 pages)
Cartridge 131 YMC (Yields approximately 1,500 pages)
*Yields based on ISO/IEC Standard
LCD Display 7-line QVGA Color Touch LCD
Duty Cycle Up to 30,000 pages per month
Department ID Management Yes, Up to 300 ID's
Security IEEE802.1x, SNMPv3, HTTPS, IPSEC, Department ID Management
Languages English, French, Spanish, Portuguese
One-Touch Keys Favorites Settings
Warranty 1 Year Exchange / Carry-in (Extended warranty available)12
Scanning Software Included: MF Scan Utility
Sending Method: SMB, E-mail, FTP, iFAX Simple
Color Mode: Full Color, Grayscale, Monochrome
Scan Resolution: 300 x 300 dpi, 200 x 200 dpi
Other Features: EPEAT Silver Rating
CANON imageCLASS SERIES EXCHANGE/CARRY-IN PRODUCT LIMITED WARRANTY
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads, and email support at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. Eastern Time (excluding holidays).
Click Here to download the Color imageCLASS MF624Cw, Color imageCLASS MF628Cw, Color imageCLASS MF726Cdw, Color imageCLASS MF729Cdw Warranty Card.
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Support | Service Notice: Windows Scanning for imageCLASS
Advisory Type
Date 07.11.16
Title Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date 05.31.22
Advisory Type
Date 03.29.15
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
