Canon Support for Color imageCLASS MF634Cdw | Canon U.S.A., Inc.
Protect your investment with our eCarePAK Extended Service Plans. Learn More
Looking for help with your order? Order Help
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
Wireless Setup
- USB Setup Instructions for Windows
- Wireless Setup Instructions for Windows
- Wireless Setup Instructions for Macintosh
Wireless Setup How-To Videos
SELECT ERROR CODE
WINDOWS
macOS X
Products | High Sierra V10.13 | Mojave V10.14 | Catalina V10.15 | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 |
Tech. Specs. Detailed PDF | View Full Details of Technical Specifications |
Printer Specifications
Printer Type | All in One, Color, Wireless, Duplex Laser Printer |
Print Speed | Up to 19 ppm (1-sided plain paper letter), Up to 11 ppm (2-sided plain paper letter)1 (bw / color) |
First Print Time | 12 seconds or less (letter)2 |
Printer Language | UFR II (Host Based) |
Print Resolution | Up to 600 x 600 dpi, 1200 x 1200 dpi equivalent |
Maximum Print Size | Up to Legal |
Duplex Print | Yes |
Print Modes | Poster, Booklet, Watermark, Toner Saver, Page Composer |
Print Memory | 1 GB (Shared) |
Direct Print from USB | JPEG, TIFF, PDF |
Copier Specifications
Copy Type | Color Laser |
Copy Speed | Up to 19 ppm (letter) |
Duplex Copy Speed | Up to 11 ppm (letter) |
Copy Resolution | Up to 600 x 600 dpi |
Original Type | Text/Photo, Text, Photo |
Halftones | 256 Levels |
Warm-up Time | 13 seconds or less from power on |
First Copy Time | Approximately 11.7 / 13.8 seconds (bw/color, letter)3 |
Recovery Time | Approximately 6 seconds |
Maximum Number of Copies | Up to 999 copies |
Reduction/Enlargement | 25 - 400% in 1% increments |
Copy Size | Platen: Up to Letter / DADF: Up to Legal |
Copy Features | Frame Erase, Memory Sort, 2 on 1, 4 on 1, ID Card Copy |
Copy Memory | 1 GB (Shared) |
Fax Specifications
Modem Speed | Up to 33.6 Kbps (Super G3)4 |
Fax Resolution | Up to 406 x 391 (Ultrafine) |
Transmission Time | Approx. 3 seconds |
Memory Capacity | Up to 512 sheets5 |
Speed Dials | 19 one-touch speed dials, Up to 262 coded dials |
Group Dialing | 199 destinations |
Sequential Broadcasting | 310 destinations |
Duplex Fax | Yes |
Receive Modes | FAX Only, Manual, Answering, Fax/Tel Auto Switch |
Fax Features | Fax Forwarding, Dual Access, Remote Reception, PC Fax (TX only), Distinctive Ring Pattern Detection, Error Detection Mode, Auto Redial, Fax Activity / Activity Result Reports, Fax Activity Management Reports |
Memory Backup | Permanent fax memory backup (Backup with flash memory) |
Scanner Specifications
Scan Type | Color Contact Image Sensor (CIS) |
Color Depth | 24-bit |
Scan Resolution | Up to 600 x 600 dpi (optical), 9600 x 9600 dpi (software interpolated resolution) |
Scan Size | Platen: Up to Letter / ADF: Up to to Legal |
Duplex Scan | Yes (Single-Pass) |
Compatibility | TWAIN, WIA 2.0, ICA |
Output File Formats | JPEG, TIFF, PDF, Compact PDF, PDF (OCR) |
Scan Features | Push Scan, Pull Scan, Scan to USB |
Pull Scan | USB and Network |
Push Scan (Scan to pC) | USB and Network |
Paper Handling Specifications
Standard Paper Source(s) | 150-sheet cassette plus 1-sheet manual feed slot6 |
Document Feeder | 50-sheet duplex6 |
Paper Output | 100 sheets (face down) |
Paper Weight | 14-43 lb. bond (cassette/manual feed slot) |
Media Sizes | Letter, Legal, A4, A5, B5, Statement, Executive |
Media Types | Plain / Heavy / Recycled / Color Paper, Label, Postcard, Envelope |
Envelope Capacity | 1 envelope (manual feed slot) |
Envelope Types | Com 10, Monarch, DL, C5 |
Connectivity and Software Specifications
Standard Interface(s) | USB Device 2.0 Hi-Speed, 10/100/1000 Base-T Ethernet (Network), Wi-Fi 802.11 b/g/n7 |
WiFi Access Mode | Infrastructure Mode, WPS easy Setup, Wi-Fi® Direct Connection8 |
WiFi Authentication Methods | WEP 64/128 bit, WPA-PSK (TKIP, AES), WPA2-PSK (AES), 802.1x (LEAP, EAP-FAST, PEAP, EAP-TLS, EAP-TTLS) |
WiFi Encryption Modes | WEP (64/128 bit), WPA-PSK (TKIP, AES), WPA2-PSK (AES) |
WPS Easy Setup Support Methods | Push-button mode, PIN code mode |
Mobile Functions | Canon PRINT Business9, Apple® AirPrint®10, Mopria™ Print Service11, Google Cloud Print™12 |
Network Functions | Print, Scan (SMB, E-mail, FTP), PC Fax |
Embedded Web Server (Remote UI) | IE 9.0 or higher, Safari 5.0.6 or higher |
Print Protocols | LPD, RAW, WSD-Print (IPv4, IPv6) |
TCP/IP Set of Application Services | Bonjour (mDNS), HTTP, HTTPS, DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6) |
Network Management Protocols | SNMPv1, SNMPv3 (IPv4, IPv6) |
OS Compatibility | Windows® 10, 8.1, 8, 7, Windows Server® 2016, Windows Server® 2012, 2012 R2, 2008 R2, 2008,Windows Vista®, Mac OS 10.7.5 or later |
Cable Included | Power Cord, Phone Cable (USB not included) |
Bundled Software | Printer Driver, Fax Driver, Scanner Driver, Network Scan Utility, MF Scan Utility, AddressBook Tool, Toner Status |
Environmental Specifications
Power Consumption | Approx: 340 W (during operation), 12.8 W (standby), Energy Saver Mode: Less than 1 W (USB/wired/wireless) |
Typical Energy Consumption | 0.5 kWh |
General Specifications
Dimensions | 17.8 inches (W) x 18.1 inches (D) x 15.7 inches (H) |
Unit Weight (without/with cartridge) | 44 lbs. (w/o cartridge), 48.4 lbs. (w/cartridge) |
Package Weight | Approx. 63.8 lbs. |
Cartridge Type | Cartridge 045 CMY (Yields approx. 1,300 pages), K (Yields approx. 1,400 pages) / Cartridge 045 Hi-Capacity CMY (Yields approx. 2,200 pages), Hi-Capacity Black (Yields approx. 2,800 pages) Single Cartridge System *Yields based on ISO/IEC Standard |
LCD Display | 5 Inch, Color Touch LCD |
Duty Cycle | Up to 30,000 pages per month |
Department ID Management | Up to 300 IDs |
Security | IP / MAC Address Filtering, HTTPS, SNMPv3, IEEE802.1x |
Languages | English, Japanese, French, Spanish, German, Italian, Portuguese, Chinese, Korean |
Warranty | 3 year limited exchange/carry-in warranty (Extended warranty available)13 |
Other Features: Send Specifications Sending Method: SMB, E-mail, FTP, iFAX Simple Color Mode: Full Color, Monochrome Scan Resolution: 300 x 300 dpi, 200 x 200 dpi Recommended Monthly Print Volume:200-2,500 pages Operating Temperature: 50-86°F Operating Humidity: 20-80% RH (no condensation) |
PRODUCT LIMITED WARRANTY
Canon USA warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of three years after delivery to the original purchaser ("Purchaser") by Canon USA or its authorized Reseller. During the relevant warranty period, and in its sole discretion, Canon USA shall, or shall cause its authorized service provider ("Service Provider"), to, without charge, repair, or replace any defective part with a new or comparable rebuilt part, or exchange the Product with a new or refurbished Product. Warranty replacement shall not extend the warranty period of the malfunctioning Product. This warranty shall not extend to consumables, such as paper, as to which there shall be no warranty or replacement.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions and the latest driver and firmware downloads available at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday (excluding holidays).
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
