Canon Support for Color imageCLASS MF726Cdw | Canon U.S.A., Inc.
Technical support for this product is provided exclusively through our FAQs and Knowledge Base.
Please click FAQs or Knowledge Base and enter your search term to find a resolution to your inquiry.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
Wireless Setup How-To Videos
SELECT ERROR CODE
WINDOWS
macOS X
Products | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 | Tahoe 26 |
Printer Specifications
Printer Type | Color Laser MFP |
Print Speed | Up to 10ppm (2-sided plain paper letter) Up to 21ppm (1-sided plain paper letter)1 |
First Print Time | 14.3 seconds or less (letter)2 |
Printer Language | UFR II LT (Host-based) |
Print Resolution | Up to 1200 x 1200 dpi (9600 x 600 dpi quality) |
Maximum Print Size | Up to Legal |
Duplex Print | All mode (Print, Scan, Copy, Fax) |
Print Modes | Poster, Booklet, Watermark, Page Composer, Toner Saver |
Print Memory | 1GB (shared) |
Direct Print from USB | via USB Host v1.1 Print File format: JPEG, TIFF, PDF |
Copier Specifications
Copy Type | Color Laser |
Copy Speed | LTR: Up to 21ppm (Black/Color)1 A4: Up to 20ppm (Black/Color )1 |
Duplex Copy Speed | LTR/A4: Up to 10ppm (Black/Color)1 |
Copy Resolution | Up to 600 x 600 dpi |
Original Type | Text/Photo/Map |
Halftones | 256 Levels |
Warm-up Time | 23 sec or less from power-on |
First Copy Time | Black/Color: Approx. 15.5/16.2sec (A4), 15.3/16.0 sec (LTR)3 |
Recovery Time | Approx. 8 sec |
Maximum Number of Copies | Up to 99 copies |
Duplex Copy/Bind Time | Yes |
Reduction/Enlargement | 25 - 400% in 1% increments |
Zoom | 25 - 400% in 1% increments |
Copy Size | Platen: Up to Letter, ADF: 5.5" x 5" to Legal |
Copy Features | Frame Erase, Memory Sort, 2 on 1, 4 on 1, ID Card Copy |
Copy Memory | 1GB (shared) |
Fax Specifications
Modem Speed | Up to 33.6 Kbps4 |
Fax Resolution | Up to 406 x 391 dpi |
Transmission Time | JBIG (approx. 3 seconds) |
Memory Capacity | Up to 512 pages5 |
Speed Dials | Up to 281 dials |
Group Dialing | Max. 199 dials / Max. 199 destinations |
Sequential Broadcasting | Max. 310 destinations |
Duplex Fax | Yes |
Receive Modes | FAX Only, Manual, Answering, Fax/Tel Auto Switch |
Fax Features | FAX Forwarding, Dual Access, Remote Reception, PC FAX(TX only), DRPD, ECM, Auto Redial, Fax Activity Reports, Fax Activity Result Reports, Fax Activity Management Reports |
Memory Backup | Permanent fax memory backup. ( Backup with flash memory) |
Activity Reports | Activity Result & Activity Management |
pC Fax | Sending only |
Fax Forwarding | SMB, E-mail, FTP, iFax Simple |
Scanner Specifications
Scan Type | Color Contact Image Sensor (CIS) |
Color Depth | 24-bit |
Scan Resolution | Optical: Up to 600 x 600 dpi Driver(digital): Up to 9600 x 9600 dpi |
Scan Size | Platen: Up to Letter ADF: 5.5" x 5" to Legal |
Duplex Scan | Yes |
Compatibility | TWAIN, WIA (Scan Driver Compatibility) |
Output File Formats | JPEG, TIFF, PDF, Compact PDF, PDF (OCR), PDF (Device Support) |
Scan Features | Yes |
Pull Scan | Yes, USB and Network |
Push Scan (Scan to pC) | Yes, USB and Network |
Paper Handling Specifications
Standard Paper Source(s) | 250-sheet cassette, 50-sheet multipurpose tray6 |
Optional Paper Source(s) | 250-sheet cassette |
Document Feeder | 50-sheet duplex |
Paper Output | 125 sheets (face down) |
Paper Weight | 16-58 lb. bond (cassette / multipurpose tray) |
Media Sizes | Letter, Legal, A4, A5, B5, Executive |
Media Types | Plain, Heavy, Recycled, Color, Coated, Transparency, Label, Envelope, Index |
Envelope Capacity | 10 envelopes (cassette), 5 envelopes (manual feed slot) |
Envelope Types | Com 10, Monarch, DL, C5, B5 |
Connectivity and Software Specifications
Standard Interface(s) | USB Device 2.0 High-Speed, 10/100 Base-T Ethernet, Wi-Fi 802.11b/g/n Wireless7 |
WiFi Access Mode | Infrastructure Mode |
WiFi Authentication Methods | Open System, Shared Key, WPA-PSK, WPA2-PSK |
WiFi Encryption Modes | WEP (64/128 bit), TKIP, AES |
WPS Easy Setup Support Methods | Push-button mode, PIN code mode |
Mobile Functions | Canon PRINT Business8, Apple AirPrint™9, Mopria Print Service10, Google Cloud Print™11 |
Network Functions | Print, Copy, Scan, Fax, PC Fax, Print/Scan to USB |
Embedded Web Server (Remote UI) | Yes |
Web Browser Support for Remote UI | Microsoft Internet Explore 7.0 or higher, Safari 3.2.1 or higher |
Print Protocols | LPD, RAW, WSD-Print (IPv4,IPv6), Email, SMB, WSD-Scan (IPv4,IPv6) |
TCP/IP Set of Application Services | Bonjour(mDNS), HTTP, HTTPS, POP before SMTP (IPv4,IPv6), DHCP, BOOTP, RARP, ARP+PING, Auto IP, WINS (IPv4), DHCPv6 (IPv6) |
Network Management Protocols | SNMPv1, SNMPv3 (IPv4,IPv6) |
OS Compatibility | Windows® 10, Windows® 8.1, Windows 8, Windows 7, Windows Vista®, Windows Server® 2012R2, Windows Server 2012, Windows Server 2008 R2, Windows Server 2008, Windows Server 2003, Mac OS X® 10.5.8 & up, Linux (print only) |
Cable Included | Power Cord, Telephone Cable (USB not included) |
Bundled Software | Printer driver, Fax driver, Scanner driver, Network Scan Utility, MF Scan Utility, Presto! PageManager |
Environmental Specifications
Power Consumption | Max: 1,200W or less. During Operation: Approx. 450W. Standby: Approx. 23W. Energy Saver: Approx. 2W |
Typical Energy Consumption | 0.9 kWh |
General Specifications
Dimensions | 17" (W) x 19.2" (D) x 18.9" (H) |
Unit Weight (without/with cartridge) | 63.1 lbs. (w/o cartridge), 68.3 lbs (w/cartridge) |
Package Weight | Approx. 81.6 lbs |
Cartridge Type | Cartridge 118 VP Black (Yields approximately 6,800 pages) Cartridge 118 Black (Yields approximately 3,400 pages) Cartridge 118 YMC (Yields approximately 2,900 pages) *Yields based on ISO/IEC Standard |
LCD Display | 7-line QVGA Color Touch LCD |
Duty Cycle | Up to 40,000 pages per month |
Department ID Management | Yes, Up to 300 ID's |
Security | Native Secured Print, IEEE802.1x, SNMPv3, HTTPS, IPSEC, LDAP |
Languages | English, French, Spanish, Portuguese |
One-Touch Keys | Favorites Settings |
Warranty | 1 Year Exchange / Carry-in (Extended warranty available)12 |
Scanning Software Included: MF Scan Utility Sending Method: SMB, E-mail, FTP, iFAX Simple Color Mode: Full Color, Grayscale, Monochrome Scan Resolution: 300 x 300 dpi, 200 x 200 dpi Other Features: EPEAT Silver Rating, NFC13 Capability |
CANON imageCLASS SERIES EXCHANGE/CARRY-IN PRODUCT LIMITED WARRANTY
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads, and email support at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. Eastern Time (excluding holidays).
Click Here to download the Color imageCLASS MF624Cw, Color imageCLASS MF628Cw, Color imageCLASS MF726Cdw, Color imageCLASS MF729Cdw Warranty Card.
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
