Canon Support for Color imageCLASS MF741Cdw | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 12.24.20
File Size 2.92 MB
Date 09.12.25
File Size 1.32 MB
Date 09.17.24
File Size 2.27 MB
Date 01.31.23
File Size 144.76 KB
Date 07.20.23
File Size 405.58 KB
Date 09.12.25
File Size 2.27 MB
Date 04.24.19
File Size 408.63 KB
Date 01.31.23
File Size 2.92 MB
Date 10.04.19
File Size 815.82 KB
Date 09.25.23
File Size 2.27 MB
Date 10.04.19
File Size 2.92 MB
Date 12.20.23
File Size 1.32 MB
Date 07.20.23
File Size 146.85 KB
Date 04.27.23
File Size 2.27 MB
Date 07.20.23
File Size 154.27 KB
Date 09.17.24
File Size 1.32 MB
Date 12.24.20
File Size 819.56 KB
Date 01.31.23
File Size 1.63 MB
Date 04.27.23
File Size 1.72 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
Products High Sierra V10.13 Mojave V10.14 Catalina V10.15 Big Sur V11.0 Monterey V12.0 Ventura V13.0 Sonoma V14 Sequoia 15
Products ChromeOS
Color imageCLASS MF741Cdw Spec Sheet
MAIN UNIT
CORE FUNCTIONS
Print, Copy, Scan, Send (Lite)
ITEM CODE
3101C015
PROCESSOR
Canon Custom Processor
CONTROL PANEL
5" Color Touch Panel
MEMORY
1 GB
STANDARD INTERFACE CONNECTION
USB 2.0 x2 (Host), USB 2.0 x1 (Device) High-Speed, 10/100/1000Base-T Ethernet (Network), Wi-Fi 802.11b/g/n, Wi-Fi® Direct Connection
PAPER CAPACITY (LETTER, 20 LB. BOND)
300 Sheets
PAPER SOURCES (LETTER, 20 LB. BOND)
Standard: 250-sheet Paper Cassette, 50-sheet Stack Bypass
Optional: 550-sheet Paper Cassette (Cassette Unit AF-1)
Maximum: 850 Sheets
PAPER OUTPUT CAPACITY (LETTER, 20 LB. BOND)
75 Sheets
SUPPORTED MEDIA TYPES
Cassettes: Thin, Plain, Recycled, Color, Thick, Coated, Label, Letter
Stack Bypass: Thin, Plain, Recycled, Color, Thick, Coated, Label, Letter
SUPPORTED MEDIA SIZES
Cassettes: A4, A5, B5, Letter, Legal, Statement, Executive, Envelope: COM10, Monarch, C5, DL, Custom (Min. 3" x 5" to Max. 8.5" x 14")
Stack Bypass: Letter, Legal, Statement, Executive
SUPPORTED MEDIA WEIGHTS
Cassettes: 16 lb. Bond to 53 lb. Bond ( 60 to 200 g/m2)
Stack Bypass: 16 lb. Bond to 53 lb. Bond ( 60 to 200 g/m2)
WARM-UP TIME
From Power On: 13 Seconds or Less;
From Sleep Mode: 6.1 Seconds or Less
DIMENSIONS (W x D x H)
Standard (Desktop): 18.8" x 18.8" x 18.4" (478 mm x 478 mm x 467 mm)
Box: 23.7" x 18.9" x 23.2" (602 mm x 479 mm x 589 mm)
INSTALLATION SPACE (W x D x H)
Standard (Desktop): 21.4" x 43.8" x 29" (544 mm x 1,112 mm x 736 mm)
Fully Configured: 21.4" x 43.8" x 34.1" (544 mm x 1,112 mm x 866 mm)
WEIGHT2
Unit: Approx. 64 lb. (29.0 kg)
Boxed Weight: Approx. 76.1 lb.(35 kg)
SUPPORTED OS
Windows 7/Windows 8.1/Windows 10/Windows Server 2008/Windows Server 2008 R2/Windows Server 2012/ Windows Server 2012 R2/Windows Server 2016 / Mac OS X v10.9.5 (or later)
WHAT COMES IN THE BOX
MF741Cdw Product, Cartridge 055 CMY Starter: 1,200 Yield/Black Standard: 2,300 Yield, Power Cord, Starter Guide, User Software DVD-ROM, Warranty Card5
PRINT SPECIFICATIONS
PRINTING METHOD
Laser Beam Printing
PRINT SPEED3
Up to 28 ppm (Letter); Up to 22.9 ppm (Legal)
FIRST PRINT-OUT TIME
Approx. 7.5 Seconds
RECOMMENDED MONTHLY PAGE VOLUME
750 - 4,000 Pages
PRINT RESOLUTION (dpi)
600 x 600
STANDARD PAGE DESCRIPTION LANGUAGES
UFR II
DOUBLE-SIDED PRINTING
Automatic (Standard)
DIRECT PRINT
Available from USB Memory (JPEG, TIFF, PDF)
PRINTING FROM MOBILE AND CLOUD-BASED SERVICES4
Apple® AirPrint,® Canon PRINT Business, Mopria™ Print
Service
COPY SPECIFICATIONS
COPY SPEED
FIRST COPY-OUT TIME (LETTER)
Platen: 9.5 seconds/11.1 seconds (BW/Color)
ADF: 9.9 seconds/11.8 seconds (BW/Color)
COPY RESOLUTION (dpi)
600 x 600
COPY SIZE
Platen: Up to Letter;
ADF: Up to Legal
MULTIPLE COPIES
Up to 999 Copies
MAGNIFICATION
25% - 400% (1% Increments)
PRESET REDUCTIONS
25%, 50%, 64%, 78%
PRESET ENLARGEMENTS
129%, 200%, 400%
COPY FEATURES
Paper Setting, Favorite Setting, Two-sided, Original Type Selection, Cancel, N-on-1, Density Adjustment, Sharpness, Erase Frame, Collate, Copy ID Card
SCAN SPECIFICATIONS
TYPE
Simplex Automatic Document Feeder
DOCUMENT FEEDER PAPER CAPACITY
50 Sheets (20 lb. Bond)
DOCUMENT FEEDER SUPPORTED MEDIA SIZES
Legal, Letter, Statement
DOCUMENT FEEDER SUPPORTED MEDIA WEIGHTS
13-28 lb. Bond (50-105 g/m2)
PLATEN ACCEPTABLE ORIGINALS
Sheet, Book
PULL SCAN
ScanGear MF for TWAIN, and WIA
SCAN RESOLUTION (dpi)
Push Scan: Up to 300 x 600
Pull Scan: Up to 600 x 600
SCAN TO MOBILE DEVICES
SCAN SPEED (LETTER)
Single-sided: 14/28 ipm (300 x 600 dpi) (Color/BW)
MEMORY MEDIA
Standard USB Memory (JPEG, TIFF, PDF)
SEND SPECIFICATIONS
DESTINATION
Email/Internet FAX (SMTP), SMB, FTP
ADDRESS BOOK
LDAP (50)/Local (300)/Speed Dial (281)
SEND RESOLUTION (dpi)
600 x 600 (Pull Scan), 196 x 204 (iFax), 300 x 300 (Other)
COMMUNICATION PROTOCOL
File: FTP, SMB
Email/iFax:: SMTP, POP3, iFax (Simple)
FILE FORMAT
Standard: TIFF, JPEG, PDF (Compact, Searchable)
Optional: PDF (Encrypted, Digital Signature)
SECURITY SPECIFICATIONS
AUTHENTICATION
Standard: Department ID Authentication
NETWORK
Standard: IP/MAC Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X(Wired Only), IPv6, SMTP Authentication, POP Authentication, POP Authentication before SMTP
DOCUMENT
Standard: Secure Print
WI-FI® AUTHENTICATION METHODS
Wi-Fi Infrastructure Mode: WEP 64/128 bit, WPA-PSK (TKIP/AES) WPA2-PSK (AES)
Wi-Fi Access Point: WPA2-PSK (AES)
ENVIRONMENTAL SPECIFICATIONS
OPERATING ENVIRONMENT
Temperature: 50 to 86º F;
Humidity: 20 to 80% RH (no condensation)
POWER REQUIREMENTS
AC 120-127 V:6.5 A, 60 Hz
POWER CONSUMPTION
Maximum: Approx. 1470 W
Standby: Approx. 20.5 W
Sleep Mode: Approx. 0.6 W
Typical Electricity Consumption (TEC) Rating: 0.31 kWh
STANDARDS
ENERGY STAR® Qualified, Rated EPEAT Silver1
FOOTNOTES
1 For latest EPEAT ratings (Gold/Silver/Bronze), please visit www.epeat.net.
2 Includes consumables.
3 Print speed is based on internal testing. Print speed may vary, depending on the number of copies selected as well as the settings for size, type, and orientation of paper.
4 Canon PRINT Business is a free app available on the App Store® and Google Play™ Store. For more information, including compatibility, please visit https://www.usa.canon.com/mobile-app. Please see the respective websites for Apple AirPrint and Mopria Print Service for compatibility and additional information.
5 Warranty program is subject to certain conditions and restrictions. See warranty card for details.
PRODUCT LIMITED WARRANTY
Canon USA warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of three years after delivery to the original purchaser ("Purchaser") by Canon USA or its authorized Reseller. During the relevant warranty period, and in its sole discretion, Canon USA shall, or shall cause its authorized service provider ("Service Provider"), to, without charge, repair, or replace any defective part with a new or comparable rebuilt part, or exchange the Product with a new or refurbished Product. Warranty replacement shall not extend the warranty period of the malfunctioning Product. This warranty shall not extend to consumables, such as paper, as to which there shall be no warranty or replacement.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions and the latest driver and firmware downloads available at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday (excluding holidays).
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printer measure against buffer overflow
Advisory Type
Date 05.31.22
Title Canon Support | Service Notice: Google Termination of Support for Google Cloud Print
Advisory Type
Date 12.01.20
Advisory Type
Date 03.29.15
Title Service Notice: Toner Cartridge Auto Replenishment Service (ARS) will be down for planned server maintenance
Advisory Type Service Notice
Date 03.03.23
Title Regarding Vulnerability Against Buffer Overflow for Canon Laser Printer and Small Office Multifunctional Printers
Date 11.18.22
Title Service Notice: Vulnerabilities Remediation Against Buffer Overflow for Canon Laser Printer/Inkjet Printer and Small Office Multifunctional Printers
Date 04.19.23
Title Service Notice: Vulnerability Mitigation/Remediation for Small Office Multifunctional Printers and Laser Printers
Date 03.15.24
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
