Canon Support for Color imageCLASS MF8180c | Canon U.S.A., Inc.
Technical support for this product is provided exclusively through our FAQs and Knowledge Base.
Please click FAQs or Knowledge Base and enter your search term to find a resolution to your inquiry.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
SELECT ERROR CODE
WINDOWS
Printer
Printing Method | Color Laser |
Print Speed (up to) | Black:Up to 20 ppm Color:Up to 4 ppm |
Print Resolution (Up to) | 600 x 600 dpi; 2400 x 600 dpi quality |
Ink Compatibility | Canon EP-87 Cartridge (Yield: 4,000/3,000 pages*) Maximum Monthly Duty Cycle: 30,000 pages *yield is based on 5% coverage document |
Paper Weights | 17 to 34 lb. |
Copier
Copy Resolution (up to) | 600 x 600 dpi |
Copy Speed (up to) | Black: Up to 20 cpm / Color: Up to 4 cpm |
Type | Color Laser |
Halftones | 256 Levels |
First Copy Time | Black: Less than 22 sec. / Color: Less than 46 sec.1 |
Reduction / Enlargement | 50%, 64%, 78% / 129%, 200% |
Document Feeder | 50-sheet |
Copy Size | Platen: Up to 8.5" x 11.7" ADF: Up to 8.5" x 14" |
Copy Features | Memory Copy, Toner Saver Mode |
Scanner
Scanner Type | Flatbed |
Scanning Element | CCD (Charged-Coupled Device) |
Max. Resolutions | Up to 1200 x 2400 dpi (optical via platen) Up to 9600 x 9600 dpi (enhanced) |
Color Depth | 48-bit (internal) / 24-bit (output) |
Max. Document Size | Platen: Up to 8.5" x 11.7" ADF: Up to 8.5" x 14" |
Fax
Modem Speed | Up to 33.6 Kbps (Super G3) |
Fax Resolution | Up to 406 x 391 dpi |
Memory Capacity | Up to 256 pages Memory Backup: Standard, Up to 40 minutes2 |
Speed Dialing | 19 one-touch speed dials / 100 coded dials |
Receive Mode | Fax Only Manual, Answering, DRPD, Fax/Tel Auto Switch |
Fax Features | Memory Back-up, Remote Receive, Polling Receive |
Other Features | PC Fax (sending only) |
General
OS Compatibility | Windows® 8, Windows® XP, 2000, Me, 98, Server 2003 |
Standard Interface | USB 2.0 Hi-Speed Internal (10/100 Base T)3 |
Software Included | Canon drivers for Windows®, ScanSoft®, OmniPage® SE (OCR), NewSoft® Presto! PageManager, Canon Remote UI |
Power Consumption (approx.) | 1100W (Max), 5W (Energy Saver Mode) |
Dimension (W x D x H) | 20.1"(W) x 20.2"(D) x 25.2"(H) |
Weight | 79.4 lbs. |
Warranty | 1 year limited warranty with on-site service4 |
1Letter size from the platen glass, after being restored from energy saver mode. 2Based on ITU-T #1 Chart (standard mode) 3USB 2.0 Hi-Speed performance requires Windows XP Service Pack 1 or Windows 2000 Service Pack 4 with pre-installed USB 2.0 port. 4Warranty program is subject to certain conditions and restrictions. See the warranty card for full details. |
Canon Color imageCLASS MF8100 SERIES LIMITED WARRANTY
The limited warranty set forth below is given by Canon U.S.A., Inc. ("Canon USA") with respect to the Canon Color imageCLASS MF8100 Series product and accessories packaged with this limited warranty (collectively, the "Product") when purchased and used in the United States.
THIS LIMITED WARRANTY DOES NOT COVER THE EP SERIES TONER CARTRIDGE OR EP DRUM CARTRIDGE FOR WHICH A SEPARATE WARRANTY IS GIVEN. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE EP SERIES TONER CARTRIDGE OR EP DRUM CARTRIDGE LIMITED WARRANTY.
Canon USA warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of one year after delivery to the original purchaser or the person for whom it was purchased as a gift (the "Purchaser") by Canon USA or its authorized dealer. During the relevant warranty period, Canon USA shall repair or replace, without charge, any defective part with a new or comparable rebuilt part. Warranty replacement shall not extend the original warranty period of the Product. This warranty shall not extend to consumables, such as paper, as to which there shall be no warranty or replacement.
Canon USA shall provide assistance for installation, operation and support of the Product as follows: (a) Toll-free telephone support for troubleshooting issues at 1-800-828-4040, between 8 a.m. and 8 p.m. ET, Monday through Friday, except holidays (b) E-mail support via our Web site at www.usa.canon.com. If Canon USA's remote assistance cannot fix your Product's malfunction, Canon USA shall schedule an on-site service call, except where the malfunction involves a user replaceable item, in which case Canon USA will send you a replacement part with installation instructions. You will be responsible for installing the user replaceable items in your Product.
If on-site service is performed, and (1) the Product malfunction is not covered by this limited warranty, or (2) the applicable warranty period has expired or has not been sufficiently established by appropriate documentation, then you will be charged for such service at the then-current service call rates of Canon USA or any authorized Canon USA service provider (the "Service Provider").
This warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment and software. Canon USA shall have no responsibility for such items except for compatible Canon brand peripheral equipment covered by a separate warranty ("Separate Warranty"). Repairs of such Canon brand peripheral equipment shall be governed by the terms of the Separate Warranty. NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH, OR FOR THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON USA, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
This warranty shall be void and of no force and effect if the Product is damaged as a result of (a) abuse, neglect, mishandling, alteration, electric current fluctuation or accident, (b) improper use, including failure to follow operating or maintenance instructions in, or environmental conditions prescribed in, Canon USA's operator's manual or other documentation, (c) installation or repair by other than authorized service representatives qualified by Canon USA who are acting in accordance with Canon USA's service bulletins, (d) use of supplies or parts (other than those distributed by Canon USA) which damage the Product or cause abnormally frequent service calls or service problems or (e) use of the Product with non-compatible computers, peripheral equipment or software, including the use of the Product in any system configuration not recommended in any manual distributed with the Product. Nor does this warranty extend to any Product on which the original identification marks or serial numbers have been defaced, removed, or altered.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE MEDIA ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY UTILITY SOFTWARE DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD "AS IS" AND WITHOUT WARRANTY BY CANON USA. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON USA IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
NEITHER CANON USA NOR ANY ASF SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY ASF), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, STORAGE CHARGES, LOSS OR CORRUPTION OF DATA, OR FOR ANY OTHER SPECIAL, INCIDENTAL, OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED, AND EVEN IF CANON USA OR ANY ASF HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA OR ANY ASF BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESION, USE, MISUSE OR INABILITY TO USE THE PRODUCT SOLD BY CANON USA NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY ASF. (SOME STATES DO NOT ALLOW THE EXCLUSION OR LIMITATION OF INCIDENTAL OR CONSEQUENTIAL DAMAGES, SO THE ABOVE LIMITATION OR EXCLUSION MAY NOT APPLY TO YOU.) THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE PURCHASER OF THE PRODUCT OR THE PERSON FOR WHOM IT WAS PURCHASED AS A GIFT AND STATES YOUR EXCLUSIVE REMEDY.
This warranty gives you specific legal rights, and you may have other rights, which vary from state to state.
Click Here to download the imageCLASS MF8170c/MF8180c Warranty Card.
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
ADDITIONAL SUPPORT
How-To Videos
Knowledge Base
CONTACT US
