Canon Support for Color imageCLASS MF8380Cdw | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 09.11.25
File Size 1.20 MB
Date 09.16.24
File Size 1.32 MB
Date 02.03.20
File Size 652.13 KB
Date 01.30.23
File Size 2.92 MB
Date 12.23.20
File Size 819.56 KB
Date 04.19.22
File Size 1.50 MB
Date 12.21.17
File Size 809.44 KB
Date 09.16.24
File Size 1.20 MB
Date 07.12.21
File Size 652.14 KB
Date 04.23.19
File Size 2.92 MB
Date 04.23.19
File Size 647.96 KB
Date 04.26.23
File Size 2.27 MB
Date 04.26.23
File Size 1.72 MB
Date 09.16.24
File Size 2.27 MB
Date 02.27.13
File Size 4.08 MB
Date 12.19.23
File Size 1.32 MB
Date 09.24.23
File Size 2.27 MB
Date 10.23.11
File Size 14.26 MB
Date 03.23.23
File Size 1.60 MB
Date 12.21.17
File Size 647.92 KB
Date 01.30.23
File Size 1.63 MB
Date 10.03.19
File Size 815.82 KB
Date 12.23.20
File Size 2.92 MB
Date 10.23.11
File Size 11.40 MB
Date 10.03.19
File Size 2.92 MB
Date 10.23.11
File Size 4.26 MB
Date 04.23.19
File Size 815.66 KB
Date 09.21.17
File Size 2.92 MB
Date 09.24.23
File Size 1.20 MB
Date 09.11.25
File Size 2.27 MB
Date 09.11.25
File Size 1.32 MB
Canon PRINT - iOS
Canon PRINT - iOS
Canon PRINT - Android
Initial Setup
Setting up additional computers
Finding your Network Key/Password
Re-establishing Printer Connection After A Network Change?
Need additional information or assistance?
Printer
Printing Method Color Laser
Print Speed (up to) Default Print Mode: 2-sided
Up to 10 ppm (2 -sided, plain paper letter)7
Up to 21 ppm (1-sided, plain paper letter)7
First Print Time
Approx. 15.3/16.0 sec (black/color) (letter)
Print Resolution (Up to) Up to 600 x 600 dpi
2400 x 600 dpi quality
Toner Compatibility (for Laser MFP) Cartridge 118 (Yields: 2,900 CMY/3,400 Black pages*)
Maximum Monthly Duty Cycle: 40,000 pages
*Yield is based on ISO/IEC Standard
Printer Features Printer Language
Canon UFR II LT (Host-based)
Print Modes
Poster, Booklet, Watermark, Toner Saver, Page Composer
Print Memory
256MB (shared)
Paper Weights 16 to 43 lbs. bond (cassette)
16 to 58 lbs. bond (multipurpose tray)
Output Tray Capacity 125 sheets (facedown)
Copier
Copy Resolution (up to) Up to 600 x 600 dpi
Copy Speed (up to) Up to 21 cpm color/monochrome (letter)
Duplex: Up to 10 cpm color/monochrome (letter)
Type Color Laser
Zoom 25-400% in 1% increments
Halftones 256 levels
First Copy Time Approx. 15.3/16.0 sec (black/color) (letter)
Reduction / Enlargement 25%, 50%, 64%, 78%
>129%, 200%, 400%
Document Feeder 50-sheet4
Copy Size Platen: Up to Letter
ADF: 5.5" x 5" to Legal
Copy Features Frame Erase, Memory Sort, 2 on 1, 4 on 1, ID Card Copy
Duplex Copy / Bind Type:
1 to 2 (Up to 10 ppm color/monochrome letter) / Book, Calendar
Scanner
Scanner Type Color Contact Image Sensor (CIS)
Max. Resolutions Up to 600 x 600 dpi (optical)
Up to 9600 x 9600 dpi (interpolated)2
Scanner Features Rotate, Push Scan, Pull Scan, Duplex Scan,
Scan to USB: USB Host 1.1 (PDF, JPEG, TIFF),
Scan to Email (PDF)
Scan to SMB (PDF, JPEG, TIFF)
Color Depth 24-bit
Max. Document Size Platen: Up to Letter
File Format Hi-Compression PDF, Searchable PDF, PDF, JPEG, TIFF, BMP, PNG3
Fax
Modem Speed Up to 33.6 Kbps (Super G3)
Transmission Speed (approx.) JBIG (2.6 seconds)
Fax Resolution Up to 406 x 391 dpi (ultra fine)
Memory Capacity Up to 512 pages1
Speed Dialing 19 favorite dials
181 coded dials
Group Dialing Group Dialing: 199 destinations
Receive Mode Fax Only, Manual, Answering, Fax/Tel Auto Switch
Fax Features Remote RX, Dual Access, Distinctive Ring Pattern Detection, Error Correction Mode, Auto Redial, Fax Activity Reports
Other Features PC Fax (sending only)
Fax Forwarding: Fax/I-Fax to Fax, Email, SMB
Memory Backup (5 minutes)
General
OS Compatibility Windows&reg; 8, Windows 7, Windows Server&reg; 2008 (R1/R2), Windows Vista&reg;, Windows Server 2003, Windows XP/2000, Mac&reg; OS X 10.4.9 & up
Standard Interface USB Device 2.0 Hi-Speed
10/100 Base-T Ethernet (Network)
IEEE 802.11 b/g/n Wireless
Software Included Canon Drivers, MF Toolbox, Document Management & OCR Software
Power Consumption (approx.) Max: 1200W
Energy Saver: 1.4 (wired), 2.2 (wireless)
Standby: 23W
Dimension (W x D x H) 17.0" (W) x 19.2" (D) x 18.9" (H)
Weight Approx. 68.4 lbs.
Operating Temperature: 50F - 86F
Operating Humidity: 20%-80% RH (no condensation)
Warranty 1 year limited exchange/carry-in warranty5
(Extended warranty available)
Canon imageCLASS MF8080Cw/MF8380Cdw LIMITED WARRANTY
CARTRIDGES FOR THE PRODUCT (EXCEPT THE CARTRIDGE BUNDLED WITH THE PRODUCT, FOR WHICH THERE IS NO WARRANTY) ARE COVERED BY A SEPARATE WARRANTY. ACCORDINGLY, THIS LIMITED WARRANTY DOES NOT COVER ANY CARTRIDGES FOR THE PRODUCT, WHETHER SHIPPED WITH THE PRODUCT OR PURCHASED THEREAFTER.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads, and email support at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. Eastern Time (excluding holidays).
NEITHER CANON USA NOR ANY SERVICE PROVIDER SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA, INCLUDING, WITHOUT LIMITATION, STORAGE CHARGES OR OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON USA OR ANY SERVICE PROVIDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA OR ANY SERVICE PROVIDER BE GREATER IN AMOUNT THAN THE PURCAHSE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER. THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT AND STATES SUCH PURCHASER'S EXCLUSIVE REMEDY.
Click Here to download the imageCLASS MF8080Cw/MF8380Cdw Warranty Card.
Cartridge Warranty
** In Canada
CAUTION:
Title Canon Support | Service Notice: Windows Scanning for imageCLASS
Advisory Type
Date 07.11.16
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
How-To Videos
How-To Videos
Knowledge Base
Knowledge Base
CONTACT US
