Canon Support for Color imageCLASS MF8580Cdw | Canon U.S.A., Inc.
Technical support for this product is provided exclusively through our FAQs and Knowledge Base.
Please click FAQs or Knowledge Base and enter your search term to find a resolution to your inquiry.
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Tahoe v26
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
Canon PRINT - iOS
Canon PRINT - Android
SELECT ERROR CODE
WINDOWS
macOS X
| Products | Windows 7 | Windows 8 | Windows 10 | Windows 10s | Windows 11 |
| Products | Big Sur V11.0 | Monterey V12.0 | Ventura V13.0 | Sonoma V14 | Sequoia 15 | Tahoe 26 |
Printer Specifications
| Printer Type | Color Laser |
| Print Speed | Up to 10ppm (2-sided plain paper letter)1 Up to 21ppm (1-sided plain paper letter)1 |
| First Print Time | 14.3 seconds or less (letter)2 |
| Printer Language | UFR II LT (Host-based), PCL6(5e,XL) |
| Print Resolution | Up to 1200 x 1200 dpi (2400 x 600 dpi quality) |
| Maximum Print Size | Up to Legal |
| Duplex Print | Yes, Automatic |
| Print Modes | Watermark, Toner Save, Page Composer, Poster, Booklet |
| Print Memory | 512 MB (Shared) |
Copier Specifications
| Copy Type | Color Laser |
| Copy Speed | Up to 21cpm (letter) |
| Duplex Copy Speed | Up to 10cpm (letter) |
| Copy Resolution | Up to 600 x 600 dpi |
| Original Type | Text/Photo/Map |
| Halftones | 256 Levels |
| Warm-up Time | Approximately 23 seconds |
| First Copy Time | Black: Approx. 15.3 seconds (letter)3 Color: Approx. 16.0 seconds (letter)3 |
| Recovery Time | Approximately 8 seconds |
| Maximum Number of Copies | 99 copies |
| Duplex Copy/Bind Time | Yes |
| Reduction/Enlargement | 25 - 400% in 1% increments |
| Zoom | 25 - 400% in 1% increments |
| Copy Size | Platen: Up to Letter ADF: 5.5" x 5" to Legal |
| Copy Features | Collate 2 on 1 4 on 1 ID Card Copy Frame Erase |
| Copy Memory | 512 MB (Shared) |
Fax Specifications
| Modem Speed | Up to 33.6 Kbps (Super G3)4 |
| Fax Resolution | Up to 406 x 391 dpi (super fine) |
| Transmission Time | JBIG (approx. 3 seconds) |
| Memory Capacity | Up to 512 sheets5 |
| Speed Dials | 181 coded dials |
| Group Dialing | 199 destinations |
| Sequential Broadcasting | 210 destinations |
| Duplex Fax | Yes (TX & RX) |
| Receive Modes | FAX Only, Manual, Answering, Fax/Tel Auto Switch |
| Fax Features | Remote RX, Dual Access, Distinctive Ring Pattern Detection, Error Correction Mode, Auto Redial |
| Activity Reports | Activity Result & Activity Management |
| pC Fax | Sending only |
| Fax Forwarding | FAX -> FAX, EMAIL, SMB |
Scanner Specifications
| Scan Type | Color Contact Image Sensor (CIS) |
| Color Depth | 24-bit |
| Scan Resolution | Up to 600 x 600 dpi (optical) 9600 x 9600 (interpolated) |
| Scan Size | Platen: Up to Letter ADF: 5.5" x 5" to Legal |
| Duplex Scan | Yes |
| Compatibility | TWAIN, WIA |
| Output File Formats | PDF(Compact), PDF, JPEG, TIFF |
| Scan Features | Scan to USB |
| Pull Scan | USB and Network |
| Push Scan (Scan to pC) | USB and Network |
Send Specifications
| Scan to Email | Yes (PDF, Compact PDF) |
| Scan to SMB | Yes (JPEG, TIFF, PDF, Compact PDF) |
Paper Handling Specifications
| Standard Paper Source(s) | 250-sheet cassette plus 50-sheet multipurpose tray6 |
| Optional Paper Source(s) | 250-sheet cassette6 |
| Document Feeder | 50-sheet duplex6 |
| Paper Output | 125 sheets (face down) |
| Paper Weight | 16-58 lb. bond (cassette) 16-58 lb. bond (multipurpose tray) |
| Media Sizes | Letter, Legal, A4, A5, B5, B6, Statement, Executive |
| Media Types | Plain Paper, Heavy Paper, Recycled, Transparency, Label, Envelope, Index, Color, Coated |
| Envelope Capacity | 10 envelopes |
| Envelope Types | Com 10, Monarch, DL, C5, B5 |
Connectivity and Software Specifications
| Standard Interface(s) | USB Device 2.0 Hi-Speed, 10/100 Base-T Ethernet, 802.11 b/g/n Wireless7 |
| WiFi Access Mode | Infrastructure Mode |
| WiFi Authentication Methods | Open System, Shared Key, WPA-PSK, WPA2-PSK |
| WiFi Encryption Modes | WEP (64/128 bit), TKIP, AES |
| WPS Easy Setup Support Methods | Push-button mode, PIN code mode |
| Mobile Functions | Canon Mobile Printing9, Google Cloud Print™10, Apple AirPrint™11 |
| Network Functions | Print, Copy, Scan, Fax, PC Fax, Print/Scan to USB |
| Embedded Web Server (Remote UI) | Yes |
| Web Browser Support for Remote UI | Microsoft Internet Explore 7.0 or higher, Safari 3.2.1 or higher |
| Print Protocols | LPD, RAW, WSD-Print (IPv4,IPv6) |
| TCP/IP Set of Application Services | DHCP, BOOTP, RARP, Auto IP, Bonjour(mDNS), DHCPv6 (IPv6), HTTP, HTTPS, POP before SMTP (IPv4,IPv6), ARP+PING, WINS (IPv4) |
| Network Management Protocols | SNMPv1, SNMPv3 (IPv4,IPv6) |
| OS Compatibility | Windows® 8, Windows 7, Windows Server® 2012, Windows Server 2008 R2, Windows Server 2008, Windows Vista®, Windows Server 2003, Windows® XP, Mac® OS X 10.5.8 & up, Linux(Print only) |
| Cable Included | Power Cord (USB not included) |
| Bundled Software | Printer driver, Fax driver, Scanner driver, Network Scan Utility, MF Toolbox, Presto! PageManager |
Environmental Specifications
| Power Consumption | Max: Approx. 1,200W During Operation: Approx. 450W Standby: Approx. 23W Energy Saver: Approx. 1W |
| Typical Energy Consumption | 0.9kWh |
General Specifications
| Dimensions | 17" (W) x 19.1" (D) x 18.9" (H) |
| Unit Weight (without/with cartridge) | 63.1 lbs. (w/o cartridge) 68.3 lbs. (w/cartridge) |
| Package Weight | Approx. 81 lbs. |
| Cartridge Type | Cartridge 118 Black (Yields approximately 3,400 pages) Cartridge 118 YMC (Yields approximately 2,900 pages) *Yields based on ISO/IEC Standard |
| LCD Display | 7-line QVGA Color LCD |
| Duty Cycle | Up to 40,000 pages per month |
| Department ID Management | Yes, Up to 300 ID's |
| Security | Native Secured Print, IEEE802.1x, SNMPv3, HTTPS, IPSEC |
| Languages | English, French, Spanish, Portuguese |
| Warranty | 1 year limited exchange/carry-in warranty8 (Extended warranty available) |
Canon imageCLASS MF8580Cdw LIMITED WARRANTY
CARTRIDGES FOR THE PRODUCT (EXCEPT THE CARTRIDGE BUNDLED WITH THE PRODUCT, FOR WHICH THERE IS NO WARRANTY) ARE COVERED BY A SEPARATE WARRANTY. ACCORDINGLY, THIS LIMITED WARRANTY DOES NOT COVER ANY CARTRIDGES FOR THE PRODUCT, WHETHER SHIPPED WITH THE PRODUCT OR PURCHASED THEREAFTER.
(a) On-line troubleshooting via a searchable Knowledgebase, answers to frequently asked questions, the latest driver and firmware downloads, and email support at www.cusa.canon.com/support. (b) Toll free telephone support at 1-800-OK-CANON (652-2666), Monday through Friday from 8:00 a.m. to 8:00 p.m. Eastern Time (excluding holidays).
NEITHER CANON USA NOR ANY SERVICE PROVIDER SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA, INCLUDING, WITHOUT LIMITATION, STORAGE CHARGES OR OTHER SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON USA OR ANY SERVICE PROVIDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON USA OR ANY SERVICE PROVIDER BE GREATER IN AMOUNT THAN THE PURCAHSE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON USA OR ANY SERVICE PROVIDER. THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT AND STATES SUCH PURCHASER'S EXCLUSIVE REMEDY.
Click Here to download the imageCLASS MF8580Cdw Warranty Card.
Cartridge Warranty
** In Canada
CAUTION:
Click here to download the Warranty Card.
next to your download
