Canon Support for colorWAVE T60/T65 | Canon U.S.A., Inc.
Firmware Results
0 of 0
Filter & Sort
Download Type
Language
0 of 0
Date 09.18.24
File Size 3.67 MB
Description Large format black & white and color on one productive system
Imaging Technology CrystalPoint technology
Toner TonerPearls for CYMK, 500 grams per color
Speed B&W: CAD: 225 D size//hr.
Color: CAD: 212 D size//hr.
Resolution 600 dpi
Configuration Printer only or all-in-one / single footprint multi-functional
Size Main Engine (W x D x H) 82.7" x 34.5" x 63.2"
Weight Main Engine 556 lbs. (252 kg) - 829 lbs. (376 kg)
Paper Rolls 2 - 6 rolls
Maximum Paper Capacity 3,900 ft., 650 ft. on a roll (1200 m, 200 m per roll)
Paper Weight 16 - 40 lb. bond (60 - 160 g/m2); up to 8 mil specialty media
Roll Width 11" - 42" (297 - 1067 mm)
Output Delivery Top delivery tray, Stacker Select, Folder Express 3011, take-up unit
Media Type Paper: Plain 75-90-120-160g (Bond), Recycled, Colored, Fluorescent, Blueback Specialties: Polyester film, Self-adhesive film/paper, Tyvek, Roll up film, Soft banner, Vellum
Description POWERsync controller
Client Operating System Support Windows® 2000 / XP / Windows Vista® / 7 / Windows 11 / Windows Server® 2003 / Windows Server® 2008, Terminal Server, Citrix® MetaFrame, Mac OS® 9 / Mac OS X®
Processor 4 Core, 4 Thread Core i3-8100
6 Core, 6 Thread Core i5-8500
Memory 2 8 GB DDR4, for a total of 16 GB of memory
Hard Disk 2 x 500 gb
Interface 10/100/1000 Base-T with RJ45
Page Description Language HP-GL, HP-GL/2, TIFF, JPEG, Adobe PostScript 3/PDF/APPE, CALS-I, NIRS, ASCII, CalComp, C4
New Set of Security Features New Set of Security Features Whitepaper
Options Adobe Postscript 3 / PDF/APPE printing
Adobe fonts: Chinese Traditional / Chinese Simplified / Japanese / Korean
Description Contact Image Sensor (CIS) with Color Image Logic Technology
Scan Resolution 600 x 600 dpi
Scan Speed Monochrome Scanning: Up to 10 inches/second
Copying: Up to 6 inches/second
Color Scanning: Up to 3 inches/second
Scan Format TIFF, PDF, PDF/A, JPEG, CALS, multi-page PDF, multi-page PDF/A and multi-page TIFF
Scan Destination Local USB flash drive, FTP, SMB, Controller, mobile device via Océ Mobile WebTools
Original Width 8.2" - 36" (208 - 914 mm)
Original Length 8.2" - 52.5 ft. (208 mm - 16 m)
Original Thickness Maximum 0.03" (0.8 mm) non-rigid documents
Zoom Scale to standard format Custom: 10 - 1,000%
Preset Modes Lines & text, Lines & text draft, Folded lines & text, Photo, Colored, Dark original, Blueprint
Size Scanner (W x D x H) 43" x 12" x 5.5" (1,097 x 308 x 140 mm)
Weight Scanner 46 lbs. (24.5 kg)
Hardware Stacker Select, take-up unit
Software Repro Desk Studio, Repro Desk Select, Repro Desk Professional and Direct Print software
Canon ColorWave T60/T65
Limited Warranty
Canon U.S.A., Inc. (“Canon”) warrants the Canon ColorWave T60/T65 products (“Product”) to be free from material defects in workmanship and material under normal use and service for a period of ninety (90) days after delivery to the original end user customer (“Customer”), or for the first 15,000 square feet of output, whichever occurs first. Customer shall give prompt written notice to Canon of any such defect by the last day of the warranty period. In such event and upon receipt of necessary documentation, Canon shall replace, without charge, any defective part with a new or comparable rebuilt part. This warranty shall not extend to consumables such as paper, chemicals, and toner, as to which there shall be no warranty or replacement. Warranty replacement shall not extend the original warranty period of the Product. This limited warranty shall only apply if the Product is used in conjunction with compatible computers, peripheral equipment, and software.
This warranty shall be void and of no force and effect if the Product is damaged as a result of (a) abuse, neglect, relocation, mishandling, alteration, electric current fluctuation, or accident, (b) improper use, including failure to follow operating or maintenance instructions or environmental conditions prescribed in Canon's operator's manual or other documentation, (c) installation or repair by other than authorized service representatives qualified by Canon who are acting in accordance with Canon's service bulletins, (d) use of supplies or parts (other than those distributed by Canon) which damage the Product or cause abnormally frequent service calls or service problems, or (e) use of the Product with non-compatible computers, peripheral equipment or software, including the use of the Product in any system configuration not recommended in any manual distributed with the Product. Nor does this warranty extend to any Product on which the original identification marks or serial numbers have been defaced, removed, or altered. A Product performing to published specifications is not materially defective.
Non-Canon brand equipment that may be distributed with the Product is sold "AS IS" and without warranty of any kind by Canon, including any implied warranty regarding merchantability or fitness for a particular purpose, and all such warranties are disclaimed. The sole warranty, if any, with respect to such non-Canon brand items is given by the third-party supplier or producer thereof.
ANY SOFTWARE THAT IS DISTRIBUTED WITH THE PRODUCT HAS AN ASSOCIATED END USER AGREEMENT AND IS LICENSED AND WARRANTED (IF AT ALL) SOLELY ACCORDING TO THE TERMS OF THAT AGREEMENT, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREIN. CANON TAKES NO RESPONSIBILITY, AND AT ALL TIMES CUSTOMER REMAINS RESPONSIBLE, FOR STORAGE OF DATA (IF AND AS APPLICABLE) ON THE PRODUCT’S HARD DISK DRIVE OR SOLID-STATE DRIVE, AND FOR DUPLICATION OR BACK-UP FOR PREVENTION OF LOSS IN THE EVENT OF FAILURE OR OTHER MALFUNCTION OF THE HARD DISK DRIVE.
THE ABOVE WARRANTIES ARE IN LIEU OF ALL OTHER WARRANTIES AND CONDITIONS, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTIES AND CONDITIONS REGARDING MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, RELATING TO THE USE OR PERFORMANCE OF A PRODUCT OR ANY ASSOCIATED COMPONENT, AND ALL SUCH OTHER WARRANTIES AND CONDITIONS ARE DISCLAIMED. NO OTHER EXPRESS WARRANTY, CONDITION OR GUARANTY, EXCEPT AS MENTIONED ABOVE, GIVEN BY ANY PERSON, FIRM OR CORPORATION WITH RESPECT TO THE PRODUCT SHALL BIND CANON, ANY SUPPLIER, OR ANY AUTHORIZED SERVICE PROVIDER. NO WARRANTY IS GIVEN ON ANY USED PRODUCT.
NEITHER CANON NOR ITS SUPPLIERS NOR ANY AUTHORIZED SERVICE PROVIDER SHALL BE LIABLE FOR PERSONAL INJURY OR PROPERTY DAMAGE (UNLESS CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF, AS APPLICABLE, CANON OR SUCH SUPPLIER OR AUTHORIZED SERVICE PROVIDER), LOSS OF REVENUE OR PROFIT, FAILURE TO REALIZE SAVINGS OR OTHER BENEFITS, EXPENDITURES FOR SUBSTITUTE EQUIPMENT OR SERVICES, LOSS OR CORRUPTION OF DATA (INCLUDING, WITHOUT LIMITATION, DATA STORED ON THE PRODUCT'S HARD DISK DRIVE), STORAGE CHARGES, OR OTHER SPECIAL, INCIDENTAL, OR CONSEQUENTIAL DAMAGES CAUSED BY THE USE, MISUSE, OR INABILITY TO USE THE PRODUCT, REGARDLESS OF THE LEGAL THEORY ON WHICH THE CLAIM IS BASED AND EVEN IF CANON OR ITS SUPPLIERS OR ANY AUTHORIZED SERVICE PROVIDER HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES. NOR SHALL RECOVERY OF ANY KIND AGAINST CANON OR ITS SUPPLIERS OR ANY AUTHORIZED SERVICE PROVIDER BE GREATER IN AMOUNT THAN THE PURCHASE PRICE OF THE PRODUCT CAUSING THE ALLEGED DAMAGE. WITHOUT LIMITING THE FOREGOING, THE PURCHASER ASSUMES ALL RISKS AND LIABILITY FOR LOSS, DAMAGE OR INJURY TO PERSONS AND PROPERTY OF THE PURCHASER OR OTHERS ARISING OUT OF THE POSSESSION, USE, MISUSE, OR INABILITY TO USE THE PRODUCT NOT CAUSED SOLELY AND DIRECTLY BY THE NEGLIGENCE OF CANON OR ANY SUPPLIER OR AUTHORIZED SERVICE PROVIDER. THIS WARRANTY SHALL NOT EXTEND TO ANYONE OTHER THAN THE ORIGINAL PURCHASER OF THE PRODUCT AND STATES SUCH PURCHASER'S EXCLUSIVE REMEDY.
Defective parts must be returned to Canon or a Canon Authorized Service Provider with all necessary documentation and will become the property of Canon.
THIS WARRANTY APPLIES TO PRODUCTS SOLD AND USED IN THE U.S.A.
SUPPLIES & ACCESSORIES
