Canon Support for CX-G6400 Card & Badge Printer | Canon U.S.A., Inc.
Sort
Firmware Results
0 of 0
Filter & Sort
Download Type
0 of 0
Date 09.24.24
File Size 5.52 MB
Date 10.12.23
File Size 3.81 MB
Date 09.24.24
File Size 6.07 MB
Date 01.14.25
File Size 4.15 MB
Date 04.01.25
File Size 4.77 MB
Printer
Printing Method Dye-based Inkjet
Print Mode Single Sided (Simplex)
Print Speed (up to) First Print Out Time: Business Card: 12 seconds or less1
Business Card: 100 Cards/minute (6,000 Cards Per Hour (CPH)) 1
Plastic Card (CR80): 45 Cards/minute (2,700 Cards Per Hour (CPH)) 1
4"x6" Postcard: 45 Cards/minute (2,700 Cards Per Hour (CPH)) 1
Envelope: 28 Envelopes/minute
Number of Nozzles 5,185 dots
Print Resolution (Up to) 1200x1200 dpi
Ink Compatibility 4 (1 x Black, 1 x Cyan, 1 x Magenta, 1 x Yellow) (105 ml of each color)
Maximum Printable Area Width: 107.8 mm / 4.2"
Length: 297.0 mm / 11.7"
Minimum Margin Top/Bottom: 1.5 mm
Left/Right: 2.0 mm
Paper Thickness Paper/Plastic: 0.21 - 0.76 mm / 8.27 - 30 mil
Envelope: 0.24 - 0.48 mm / 9.45 - 18.9 mil
Automatic Sheet Feeder Paper feed capacity2
Plastic & Paper Card: 400 Cards
Envelope: 100 Envelopes
Inkjet Media Compatibility Inkjet Paper Card: Business Cards, Credential, Envelope, Postcard
Inkjet Plastic Card: 2" x 3.5"
Custom Size: Paper/Plastic within Maximum Printable Size & Up to 30 mil"
Body Durability 1.5 Million Cards / 5 Years
Estimated Output Number Approx. 24,000 Cards per cartridge set2
Maximum Paper Size Width: 85.0 - 120.0 mm / 3.3 - 4.7"
Length: 49.0 - 300 mm / 1.9 - 11.8"
General
OS Compatibility Windows 10, 11 (64/32 bit), 8.1 (64/32 bit), 7 SP1 (64/32 bit)3
Standard Interface USB 2.0
Ethernet (10/100/1000Base-T)
Power Source AC 100v - 240v, 50/60 Hz
Power Consumption (approx.) Maximum: Approx. 229 W
Operating: Approx. 135 W
Sleep Mode: Approx. 8.5 W or Less
Dimension (W x D x H) 23.4" (W) x 16.1" (D) x 18.3" (H)6
Weight 55.1lbs.6
Operating Temperature: Temperature: 41° - 95°F (5° - 35°C)
Operating Humidity: Humidity: 10-90% RH (Non-Condensing)
Noise Acoustic Information4:
Operating Noise (Max.): 58dB or less
Standby Noise: 35dB or less
Cartridge Fill Volume Black / Cyan / Magenta / Yellow: 105 ml of each color
Maintenance Cartridge Info & Fill Volume WT-X401 Maintenance Cartridge 1
Approx. 72,000 Cards1
Operational Method LCD: No
Buttons/LEDs: 3 Buttons / 8 LEDs
Warranty 1 Year Warranty5
CANON CX-G6400 INKJET CARD PRINTER LIMITED WARRANTY
The limited warranty set forth below is given by Canon U.S.A., Inc. ("Canon") with respect to the Canon CX-G6400 Inkjet Card Printer packaged with this limited warranty and Canon branded accessories and options designed for use with the Canon CX-G6400 Inkjet Card Printer ("Product"). Canon warrants the Product to be free from defects in workmanship and materials under normal use and service for a period of one (1) year after delivery to the original purchaser (“Purchaser”) by Canon or its authorized dealer. During the relevant warranty period, Canon shall, in its sole discretion and without charge, repair or replace any defective part with a new or comparable rebuilt part or replace the Product with a new or rebuilt Product. Warranty replacement shall not extend the warranty period of the defective Product. This warranty does not cover the print head and other consumable parts or consumables, such as paper and ink cartridges, as to which there shall be no warranty or replacement.
For remote diagnostic assistance for operation and support of the Product, call:
·        Your local Canon authorized service provider (the “Service Provider”); or
·        1-855-852-2666, Monday through Friday (excluding Canon holidays).
You must cooperate with Canon in remotely diagnosing the Product’s malfunction. Canon may attempt to correct the malfunction remotely, with your assistance. If Canon cannot fix your Product’s malfunction through remote diagnostics, Canon shall schedule an on-site service call by the Service Provider, or Canon will send you a replacement part for any defective user replaceable item. You will be charged at the then-current service call rates of Canon or the Service Provider if the defects in the Product are not covered by this limited warranty, or if the applicable warranty period for the Product has expired or warranty coverage has not been sufficiently established by appropriate documentation.
This warranty shall only apply if this Product is used in conjunction with compatible computers, peripheral equipment and software, as to which items Canon shall have no responsibility. NON-CANON BRAND COMPUTERS, PERIPHERAL EQUIPMENT AND SOFTWARE WHICH MAY BE DISTRIBUTED WITH THE PRODUCT ARE SOLD AS IS, WITHOUT WARRANTY OF ANY KIND BY CANON, INCLUDING ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE.
The sole warranty, if any, with respect to such non-Canon brand item is given by the manufacturer or producer thereof.
THIS WARRANTY SHALL BE VOID AND OF NO FORCE AND EFFECT IF THE PRODUCT IS DAMAGED AS A RESULT OF (A) ABUSE, NEGLECT, MISHANDLING, ALTERATION, ELECTRIC CURRENT FLUCTUATION OR ACCIDENT, (B) IMPROPER USE, INCLUDING FAILURE TO FOLLOW OPERATING OR MAINTENANCE INSTRUCTIONS IN, OR ENVIRONMENTAL CONDITIONS PRESCRIBED IN, CANON’S USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT, INCLUDING BUT NOT LIMITED TO DAMAGE CAUSED BY INK LEAKAGE RESULTING FROM MOVING OR TRANSPORTING OF THIS PRODUCT AFTER THE INKS HAVE BEEN INSTALLED AND THE INITIAL SETUP IS COMPLETE. (C) REPAIR BY OTHER THAN SERVICE REPRESENTATIVES QUALIFIED BY CANON WHO ARE ACTING IN ACCORDANCE WITH CANON’S SERVICE BULLETINS
(D) USE OF SUPPLIES OR PARTS (OTHER THAN THOSE DISTRIBUTED BY CANON), INCLUDING NON-CANON INK CARTRIDGES OR REFILLED INK CARTRIDGES, WHICH DAMAGE THE PRODUCT OR CAUSE ABNORMALLY FREQUENT SERVICE CALLS OR SERVICE PROBLEMS OR (E) USE OF THE PRODUCT WITH NON-COMPATIBLE COMPUTERS, PERIPHERAL EQUIPMENT OR SOFTWARE, INCLUDING THE USE OF THE PRODUCT IN ANY SYSTEM CONFIGURATION NOT
RECOMMENDED IN ANY USER'S GUIDE OR OTHER DOCUMENTATION FOR THE PRODUCT. NOR DOES THIS WARRANTY EXTEND TO ANY PRODUCT ON WHICH THE ORIGINAL IDENTIFICATION MARKS OR SERIAL NUMBERS HAVE BEEN DEFACED, REMOVED, OR ALTERED.
ANY SYSTEM SOFTWARE (WHETHER FACTORY LOADED ON THE PRODUCT OR CONTAINED ON THE SOFTWARE MEDIA ENCLOSED WITH, OR ACCOMPANYING, THE PRODUCT), AND ANY
UTILITY SOFTWARE, DISTRIBUTED WITH OR FOR THE PRODUCT, IS SOLD “AS IS” AND WITHOUT WARRANTY BY CANON. THE SOLE WARRANTY WITH RESPECT TO SUCH SOFTWARE IS CONTAINED IN THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT DISTRIBUTED THEREWITH, INCLUDING ANY LIMITATIONS AND DISCLAIMERS THEREON. PLEASE CONTACT CANON IMMEDIATELY IF YOU HAVE NOT RECEIVED A COPY OF THE SOFTWARE MANUFACTURER'S LICENSE AGREEMENT.
CONDITIONS OF WARRANTY
Canon U.S.A., Inc. One Canon Park, Melville, NY 11747 – 3336 Canon is a registered trademark of Canon Inc.
SUPPLIES & ACCESSORIES
ADDITIONAL SUPPORT
image icon
How-To Videos
image icon
image icon
Knowledge Base
CONTACT US
