Canon Support for Elura 50 | Canon U.S.A., Inc.
Elura 50
Firmware Results
0 of 0
2. Select the Version
- Windows 11
- Windows 10 (x64)
- Windows 10
- Windows 8.1 (x64)
- Windows 8.1
- Windows 8 (x64)
- Windows 8
- Windows 7 (x64)
- Windows 7
- Windows Vista (x64)
- Windows Vista
- Windows Me
- Windows XP (x64)
- Windows XP
- Windows 98
- Windows 95
- Windows Server 2022
- Windows Server 2019 (x64)
- Windows Server 2016 (x64)
- Windows Server 2012 (x64)
- Windows Server 2008 (x64)
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- macOS Sequoia v15
- macOS Sonoma v14
- macOS Ventura v13
- macOS Monterey v12
- macOS Big Sur v11.0
- macOS Catalina v10.15
- macOS Mojave v10.14
- macOS High Sierra v10.13
- macOS Sierra v10.12
- OS X El Capitan v10.11
- OS X Yosemite v10.10
- OS X Mavericks v10.9
- OS X Mountain Lion v10.8
- OS X Lion v10.7
- Mac OS X Snow Leopard v10.6
- Mac OS X v10.1
- Mac OS 9
- Linux ARM
- Linux MIPS
- Linux 64bit
- Linux 32bit
- SAP
- Windows Server 2025
- Windows NT
- Linux
0 of 0
File Name
DV Messenger Ver 1.0 Instruction Manual
File Name
ELURA50 Instruction Manual
File Name
Zoom Remote Controller ZR-1000
File Name
Power Adapter CBC-NB2 Instruction Manual
File Name
BP-2L12 PDF
File Name
Tele-converter Lenses TL-28
File Name
Filter Sets FS-28U
File Name
File Name
Elura 50 Software Instruction Manual
File Name
Video Light VL-10Li
Camera Connect
image.canon
SELECT ERROR CODE
Power Supply (rated) | 7.4 V DC (Battery); 7.2 V DC (DC IN) |
Power Consumption | 3.1 W (using viewfinder); 4.1 W (using LCD screen) |
Television System | EIA standard (525 lines, 60 fields) NTSC color signal |
Video Recording system | 2 rotary heads, helical scanning system, DV system (Consumer digital system); Digital component recording |
Audio Recording system | PCM digital sound: 16 bit (48 kHz/2 ch); 12-bit (32 kHz/4 ch); 2 x SP and 3x SP: 12-bit only (32 kHz/2 ch.) |
Image Sensor | 1/6" CCD (charge coupled device); approx. 680,000 pixels; (approx. 630,000 effective pixels) |
Tape Format | Videocassettes bearing the MiniDV mark |
Tape Speed | Sp: 3/4 ips (18.81mm/sec); LP: 1/2 ips (12.56mm/sec) |
Maximum Recording Time (with an 80-min. cassette) | SP: 80 min; LP: 120 min |
Fast Forward/Rewind Time | 2 min. 20 sec (with a 60 min cassette) |
Lens | f/1.8 - 2.3, 10x power zoom, 2.5 -25.0 mmm |
Focusing System | TTL autofocus, manual focusing possible |
Focusing System | 3ft. 3 3/8 in (1m); 3/8 in (1cm) on maximum wide angle |
Minimum Illumination | 2.4 lux using the Night Mode program |
Recommended Illumination | More than 100 lux |
Viewfinder | 0.5 in., color LCD (approx 113,000 pixels) |
LCD Screen | 2.0 in. measured diagonally (approx 130,000 pixels) |
Microphone | Stereo electret condenser microphone |
DV Terminal | Special 4-pin connector (based on IEEE 1394) |
Video Terminal | 1 Vp-p/75 ohms unbalanced |
Output Levels | -10 dBV, less than 3 kohm, unbalanced |
S-video Terminal | 1 Vp-p (Y signal), 0.286 Vp-p (C signal) |
Input Levels | -10 dBV/47 kohm, unbalanced |
Operating Temperature range | 32-104° F (0-40° C) |
Dimensions | 2.0 x 4.4 x 3.5 in. (50 x 111x 89mm) |
Weight (not including lens and battery pack) | 13.4 oz (380g) |
Memory Card
Recording Media | MultiMediaCard, SD Memory Card |
Image Format | Design rule for Camera File System (DCF) |
Print Order format | Digital Print Order Format (DPOP) |
ADDITIONAL SUPPORT
CONTACT US
